Allan G
Allan G
West Yorkshire
Why are ‘oddies ’ so pricey?
#797316 02/02/20 6:24 pm
Danam Offline OP
It’s ridiculous how much they want for these little things? Occasionally I will see one for As low as $4 but with $12 shipping. I so wish I had a lathe I would crank these out by the bucket load!!
Rant over, thank you.
Re: Why are ‘oddies ’ so pricey?
Danam #797318 02/02/20 6:36 pm
If you are ordering from Britain, the charges are indeed outrageous. Years ago it wasn't that way.
I suspect Her Majesty's Royal Mail is now using the mails as a "revenue enhancer" instead of as a "service."
If from the USA, eBay is probably setting the rates, again as a "revenue enhancer," but for eBay.
Some of the sellers in the USA will send the parts outside of the eBay system at considerably less cost.
Danam #797332 02/02/20 7:58 pm
So you recon you would crank these out by the bucket load eh
Perhaps then you would get some idea of what a multi operation these would be to make .........1 turn diameter 2 form pointed end 3 form large radius on head 4 mill flats (or forge them under a press , another machine and tooling) 5 mill slot 6 polish 7 chrome and Send to supplier at probably around $2 allowing them a 100% mark up ..............even if you were making these by the 1000 on an auto lathe or cnc they would be a tricky little job, to make a buck out of. .........i recon $4 is cheep .........sure with a cnc or auto you could spit them out pretty quick onceyou had set the machine .......you would need to be making quite a few per hour to hit a cnc charge out rate.
I spent my working life in the production turning industry so i can see the value in such a small thing.
The post is another matter so i relate to that .
Ignoramus #797339 02/02/20 8:39 pm
This is a good description of the process and the costs involved.
But you've got me thinking "Why is it, then, that I can buy Schrader valve cores, that are turned, machined, have an internal spring, bearing surfaces, and a sealing surface for about $.04 apiece .... ?"
"Why do you wear that thing, Dobby?" "This, sir? It is the sign of a house-elves enslavement."
Danam #797341 02/02/20 8:43 pm
I have absolutely no idea what this thread is about
Danam #797343 02/02/20 8:56 pm
Have you tried Kyle @ CBS a vendor here? has the BSA style logo above the MAP logo
Lannis #797345 02/02/20 9:00 pm
because every tire in the world uses a schraeder valve, (presta excepted, i know. . . ) so you can do production runs of billions and sell them all.
what sorts of idiots need oddies any more?
having said that i had to buy three or four last year, but that's still not billions.
I would rather be ashes than dust
Danam #797350 02/02/20 9:21 pm
Fir Andy H. in Lancs.
"Oddies" refers to the dzus fasteners used to hold the fiberglass (later steel) side covers onto BSA A50 and A65 bikes, 1962-1970.
Danam #797351 02/02/20 9:29 pm
Lannis commented :
"...But you've got me thinking "Why is it, then, that I can buy Schrader valve cores, that are turned, machined, have an internal spring, bearing surfaces, and a sealing surface for about $.04 apiece .... ?"
I doubt they are turned , they are probably a one hit forging (never studied one so not sure) .....they would no doubt be made on an ongoing basis by a "dedicated" production line which does nothing else ........no doubt a fully automated set up . You know on going contract to supply X thousand per week/month for perpetuity (where X is a very large number) ..........but yeah i hear you on 4 cents seems mindbogglingly .......but who can understand how it is possible to make anything to the prices they do in Asia .....i sure cant.
Danam #797353 02/02/20 9:36 pm
It seems a lot of vendors make extra income with the postage or else mailing requires a lot of overhead. I bought a couple of off-the-shelf gears for an oil pump, weights less than one pound shipped from the US and the shipping was $32 plus an $8 processing fee. A small Priority mail box is free, ships up to four pounds and costs $8.30.
I think most any 60's British bike used Oddies to mount the side covers.
How many Schrader valves are in the world compared to British bikes? Economy of scale. Probably made in China too.
My take on what it takes to make them:
Put rod in the lathe, turn the shank, leave material on the head for the next operation
Put blank in rotary on the mill and cut the two angled flats
Put the blank back in the lathe and cut the head
Put blank back in the mil to saw cut the slot.
If you want the slot indexed to the flats a special jig is needed.
Irish Swede #797358 02/02/20 10:05 pm
Some of the sellers in the USA will send the parts outside of the EBAY system at considerably less cost.
Sadly its the same ordering into the UK from the USA too, if the seller doesn't use the eBay global shipping program it gets quite expensive, where this way it skips UK customs.... Sadly if its a 2 bob bit, then you'll still pay £17 on a £7 item plus postage cost of £12 for example... at £7 it would fall under the value threshold anyway.
You win some... You loose some....
Danam #797375 02/03/20 12:25 am
A couple of drawbacks to eBay global, you have to sell through eBay and use Paypal. So extra cost of buying through eBay rather than direct and the import duty is based upon the eBay selling price. Not that anyone would declare the value as less for the customer.
Danam #797390 02/03/20 5:57 am
Actually they are not all that expensive to make in volume.
The basic shape is an upset forging, much the same as bolt.
Dirt cheap
then it is capstain lathe to polish the head, reverse the fastener then machine the shank ( actually better to machine the crank first ) followed by an electro polish & chrome plate.
However to get the price down you need to make them in the millions and the world comsumption would be in the hundreds.
So for a start there is a lot of dead capital.
Add to that the storeage costs and in particular the cost of corrosion prevention over the next 100 years till the last one was sold,
Danam #797414 02/03/20 1:25 pm
I've never had one that was chromed.
Danam #797416 02/03/20 1:35 pm
I bought some stainless steel ones some years ago, never seen them again. I also bought some zinc plated ones from RS Components even more years ago and they can be polished to look like chrome.
