Don Leaming
Don Leaming
Ontario Canada
Help with b31 big screw up!
#797219 02/01/20 5:16 pm
I think I really screwed up, long story short I have a beautiful rebuilt head part number 65-1705, was under the impression it was for a b31 but I think its a b33 head, CRAP!
I am tired of kicking myself, I really don't want to throw in the towel.
Any constructive advice besides giving up?
Re: Help with b31 big screw up!
dean toensing #797224 02/01/20 6:15 pm
The B31 and B33 heads are quite different size wise. The bores are 71mm and 85mm respectively so if you add a bit for going over any protruding cylinder spigot you should be able to tell exactly what you have for a head.
Is this the same head that you had issues with valve clearance?
If you do have a B33 head and rest of the engine is B31 then the easiest solution would be to sell that head and source a B31 head. Could your original head be repaired?
Can you post photos?
Good luck
dean toensing #797227 02/01/20 6:44 pm
Yep, head with pushrod adjustment issue. Old head is cracked badly. Really discouraged.
dean toensing #797229 02/01/20 7:00 pm
You could also try to find a B33 barrel and enjoy the extra power
dean toensing #797236 02/01/20 7:58 pm
So just a barrel and piston? Would the b31 rod work?
dean toensing #797242 02/01/20 8:43 pm
The 1949 parts book shows the B31 and B33 with the same conrod but they do show different flywheels. 65-1125 and 65-1123 for the B31 and 65-1235 and 65-1233 for the B33.
Are you aware of what flywheels you have?
Gordo in Comox #797243 02/01/20 8:54 pm
The stroke is the same for both engines, Differences in crankshaft will be related to balance and weight so of little consequence.
dean toensing #797245 02/01/20 9:24 pm
I can't confirm whats in the bottom end.
Andy Higham #797262 02/01/20 11:59 pm
Could he bore & sleeve his cylinder??
dean toensing #797311 02/02/20 5:12 pm
Would the larger cylinder option require any machining to the crankcases? I sure appreciate your collective knowledge.
dean toensing #797313 02/02/20 5:51 pm
Dean: The mouth on the cases should be all the same size so no machining. The B33 piston would be heavier from a balance point of view so high revs might be interesting. For example a BB32 mid compression piston no pin weighs 311 grams, low compression BB34 piston no pin weighs 430 grams and a higher compression BB34 GS piston no pin weighs 493 grams. The experts can tell you what issues the weight increase might be. Of course you may well have a B33 bottom end.
dean toensing #797327 02/02/20 7:22 pm
The additional power sounds appealing and I'm not concerned with originality but I sure don't want to jeopardize the engine or have a bad vibration problem. Since I've never ridden a b series, you that have, does this seem to be a worthwhile way to go or risky?
dean toensing #797335 02/02/20 8:23 pm
It does not really matter what is in the bottom end. The rods are the same, the crank stroke is the same. The B33 is essentially a "big bore" B33
dean toensing #797336 02/02/20 8:26 pm
This has absolutely standard B31 cases
[Linked Image from live.staticflickr.com]20180609_152238 by Sigma Projects, on Flickr
dean toensing #797359 02/02/20 10:18 pm
Hi Dean
PM sent
dean toensing #797374 02/03/20 12:01 am
Side note, the carb that came with this basket case is a AMAL monoblock 376/17.
dean toensing #797458 02/03/20 7:10 pm
As bodine031 asked, could the b31 cylinder be bored to b33 size?
dean toensing #797460 02/03/20 8:00 pm
No. The bore of a B33 is over 1/2" larger, which means over 1/4" would have to be removed from the walls and there isn't nearly enough material to allow that.
dean toensing #797462 02/03/20 8:20 pm
Thank you Magnetoman.
dean toensing #798598 02/18/20 1:01 am
There is a small fin B31 head on fleaBay in the US right now
dean toensing #798806 02/20/20 1:39 pm
They all seem to have a broken fin or two. Been told thats not a easy or cheap fix.
dean toensing #798811 02/20/20 2:20 pm
Cast iron welding or brazing needs skill and knowledge, the finding of the person who can do it is the hard bit, the actual fixing is not costly.
