Allan G
Allan G
West Yorkshire
Iron b31/b33 race engine questions
#796824 01/28/20 8:27 am
jimq Offline OP
Hi all. I am collecting bits to build a pre unit single race bike. I have bought an incomplete thick flange zb31 cased motor which is said to have a b33 crank and has a small fin b33 top end. It is a bit of a bitza and hopefully doesn't turn out to be scrap. Anyway I have been told by a guy who seemed to know what he was on about that for my purposes a 350 would be a better proposition than a 500 for an iron race motor and a 350 is best built with a 500 crankshaft as it is heavier. My plan at this stage is to build it up as a 350 with the 500 crank, a carrillo or similar short late gold star rod and a cut down big fin b31 cylinder. I intend to run the engine on methonol. Does this sound like I have been given good d advice to anyone in the know? Also I am unsure at this stage how to tell the difference between a b31 and b33 crankshaft other than if it is a later short rod b33. Can anyone give advice or pictures there please. Cheers, Jim.
Re: Iron b31/b33 race engine questions
jimq #796828 01/28/20 10:02 am
Novice poster
Novice poster
G'day Jim,
Not sure that you would want to use the 500 crank for a 350, Being heavier is not an advantage for a race engine I wouldn't think.
You also may have trouble with the balancing of the crank with the smaller 350 piston.
I have heard of racers back in the day doing the opposite in fact, and using the lighter 350 crank flywheels in a 500 engine
to make it spin up/ accelerate faster.
Not sure about how to identify a 350 as opposed to the 500, I would assume the 500 flywheels are thicker, I do have a 500 crank in a set of cases that was a race bike, but I think they have been lightened, will try and find out thru my contacts if no one else knows.
Not sure if you saw my post about my bike, on your other thread re wheel choice etc .
Glenn
1974 Mk2a Commando
1968 Bonneville
BSA B31 Racer
Norton/BSA 500 Racer
DBD 500 Goldstar Project
glenno69 #797055 01/30/20 11:53 pm
jimq Offline OP
Hi Glenn.
Thanks for the reply.
Yes i did see the reply to my other thread but not for a while after you posted it.
I am thinking i will go with the 19 inch wheels as they will add a bit of authenticity to the bike and you can get good Avon's for them. the same tyres guys are running on their Manx's.
What you say about the lighter crank makes sense but i note that the gold stat cranks look heavier again than the B33. I think i can see the difference now. it is in the rim that runs around the outside of the flywheel being thicker on the 500 crank.
I guess i will wait until the next time i am at the track to quiz some of the guys i have talked to previously about what they had said.
My bike will be fairly similar to yours but the class that will allow me to run a methanol burning pre 63 350 over here is the modified class which allows any drum brakes so i plan on running a 69-70 type BSA / Triumph 8 inch tls.
I am in a planning and collecting parts as i find them stage of this project at the moment so not pressing into anything too seriously. I am pretty keen to find a frame though, then i would have most of a motor and a frame which make me feel a bit more like i am actually getting somewhere with it.
At this stage i am hoping to have my B50 finished for a meeting in october.
jimq #797065 01/31/20 12:51 am
These two cranks are 1956.
Click to enlarge
The B31 crank has casting part # 66-610
The B33 crank has casting # 66-635
Gordo in Comox #797070 01/31/20 1:17 am
jimq Offline OP
Hi Gordo.
Thanks for that reply.
I have been trying to figure out what the visual difference between B31 and B33 cranks is for a couple of weeks now.
What you show is what i was thinking about a week ago until i managed to convince myself that the 350 and 500 cranks look similar ( to what you show as the B31 crank ) but when viewed from the side that rim that goes around the outside of the fly wheel is wider.
My information all comes from scrolling through pictures i have found on the internet.
What you are saying is the b33 crank looks like what i was calling a gold star crank.
I am sure you will be right and i will be wrong. That will make it alot easier to tell what i have when i pull the thing apart.
Cheers.
Jim.
jimq #797082 01/31/20 2:49 am
Jim: then to complete the story this is a 1952 Gold Star crank. The rod and wheels are polished and the drive side shaft is stepped to take a larger bearing.
I would be surprised if a B31/33 case had been modified to take the larger bearing.
click to enlarge
This is a DBD crank for comparison
