Servodyne
Servodyne
England
New BritBike book out!
clutch shaft end play 1974 T100R
#796745 01/27/20 5:00 pm
Lucas57 Offline OP
1974 T100R Daytona. i have removed the clutch, the clutch hub and cover plate exposing the gearbox sprocket. The end play as measured from the threaded end of the clutch end of the main shaft is .07 inches or 1.8mm. Is this within the acceptable range?
Re: clutch shaft end play 1974 T100R
Lucas57 #796749 01/27/20 5:25 pm
The mainshaft is fixed to a bearing on the timing side of the gearbox and should have no end play.
Chris
Lucas57 #796755 01/27/20 5:58 pm
A common cause is the nut at the other end of the shaft being loose.
Lucas57 #796780 01/27/20 10:11 pm
Lucas57 Offline OP
Yes, the nut on opposite end of the main shaft did not have a nutlock on it and came loose. The clutch pushrod had worn causing the main shaft nut to rub on the pushrod mechanisms apparently unscrewing it a couple of turns.
Lucas57 #796801 01/28/20 1:43 am
I very much doubt that the pushrod had anything to do with it. If the nut was loose, there's your culprit, as TT first indicated.
If the pushrod is worn, that is another, and separate matter.
A worn pushrod won't cause a loose mainshaft nut, the excess length of the mainshaft as a result of the mainshaft nut coming loose will make it seem like the pushrod is shorter.
Lucas57 #796827 01/28/20 9:33 am
Born To Run
Born To Run
Pay close attention to torque on the timing-side mainshaft nut. There's not a lot of threads and they can strip if over-tightened.
Lucas57 #796840 01/28/20 5:23 pm
Parts Dealer
Parts Dealer
As others have stated, if you're worried you can remove the lock tab washer and apply some loctite to allow more thread engagement
Also check and see if the ball bearing is causing lateral movement - if so, may be time for replacement
