Tappet the Kiwi
Tappet the Kiwi
On the River, On the Road
BarryS, Chris Robinson, wind1, Matt.B, Santacaferacer
10990 Registered Users
franko 92
DavidP 58
NickL 53
1,121,761 mail-order LSR
Topics68,683
Posts688,812
Members10,990
72 registered members (Adam M.), 2,064 guests, and 834 spiders.
Some hard found info.. for old guys #795446 01/12/20 4:06 pm
KC in S.B. Offline OP
This isn't new info, but some here might waste time figuring it out themselves,............. so here's a short version. When you get to the point where pulling the clutch / brake levers is difficult, one part of that issue is this: the pivot to cable distance, mechanical advantage. ( or in this case, DIS-advantage ??) The shorter pivot distance is easier to pull, but of course cable travel is less. Came across some photos I had to document the issue......
Re: Some hard found info.. for old guys [Re: KC in S.B.] #795454 01/12/20 5:10 pm
Hillbilly bike Online Content
It's my opinion that the design of the lever has more influence than the fulcrum distance...The Brembo type semi dog leg levers on my T140 have a smoother easier pull in than any stock Brit lever even though the distance is 1-1/8 ". Traditional sucks sometimes...LOL
Re: Some hard found info.. for old guys [Re: KC in S.B.] #795469 01/12/20 6:51 pm
HawaiianTiger Offline
The lever pivot distance is a critical part of the design, but with a crappy cable, it's all for nothing. Stout, non-flexing cables properly routed helps a lot. Other factors need attention, like the actual clutch. I've put a stuffer plate in my old 'Bird and it's a feather light clutch which doesn't stick overnight like it used to. It appears to me that if the spring adjusters are too tight, that is a major contributing factor to clutch sticking. And, yes, by now(I turn 70 this year) a lot of us have less strength than we used to and may have arthritis or carpal tunnel syndrome, perhaps other maladies.
Light controls means I can ride into the sunset.
I've modified two levers so far for a shorter pivot distance. Alloy levers are easiest. Plug the hole with a brass or aluminum plug and re-drill the hole.
Re: Some hard found info.. for old guys [Re: HawaiianTiger] #795503 01/13/20 6:57 am
Not so easy if one wishes to increase the pivot distance to get more clutch lift.
Re: Some hard found info.. for old guys [Re: KC in S.B.] #795512 01/13/20 11:26 am
Mike Baker Offline
Agree with Tony on this one. The race bike has kibblewhite springs cranked down and it is stiff with a capital S.
Dogleg levers make a huge difference for these worn out hands.
Re: Some hard found info.. for old guys [Re: Mike Baker] #795516 01/13/20 1:14 pm
Allan Gill Online Happy
Is this compared to new/good levers or old ones?
you find that the fulcrum hole wears oval, the other problem is that with the new position of the lever, the lever then rubs against the body of the "clamp". Also a lot of people use a set screw instead of a bolt/screw with shank which speeds up the wear and adds to the binding. On some I have made a small bush for the centre (for either clamp or lever depending on which is the inner most part) and this restores the smooth action.
I agree that dogleg levers often give the feel of better/smoother/lighter pull but I think this is often due to the optomised grip position.
Most aftermarket levers are over an inch fulcrum distance, the standard A65 ones for example are 7/8. even a new lever with the longer distance is heavier IME than a reasonable standard original.
Re: Some hard found info.. for old guys [Re: Allan Gill] #795519 01/13/20 1:24 pm
Better than old style levers even if they are new....Yes,it's all about optomised grip which trumps the small increase fulcrum distance....My opinion; bike riding is about control and comfort and not about original style if it's not as good...
Re: Some hard found info.. for old guys [Re: KC in S.B.] #795523 01/13/20 2:14 pm
Irish Swede Offline
I have often thought that a hardened steel bush in the fulcrum hole of the clamp may be the solution .
The pivot screw might wear out, but those are easier to find and cheaper to replace than the clamp itself.
Re: Some hard found info.. for old guys [Re: Irish Swede] #795527 01/13/20 3:51 pm
I've used bronze as its easy to machine and I have some, but steel with a decent carbon content (If such exists - I wouldn't know as im not a metalurgist) would be good. The couple I have done have been a vast improvement. Although Mike and Tony's racebike probably have their clutch screwed down much more than you would on a road bike, making this even more noticable.
