Servodyne
Servodyne
England
Page 2 of 2 1 2
Re: A-65 excessive end float
Nick H #794655 01/02/20 11:03 pm
Originally Posted by Nick H
NickL: Just how do I best "get the crank central"? Measuring from where? Any tips or tricks?
Fortunately there is a lot of play on the small end and some on the big end so how critical is it?
And what type of spacer do you suggest for next to the thrust washer where it is needed?
Your previous post you suggest a bronze spacer made in a lathe.
I may attempt to fabricate a new thrust washer by hand from a bronze washer - no lathe.
Sorry if i am overcomplicating this.
I have already told you how, read my earlier posts.
MarcB #794660 01/03/20 12:38 am
Nick H Online Content OP
OP Online Content
Sorry NickL, I see that you did.
It is difficult to do with the accuracy we need as points to be measured are not on the same plane or otherwise obstructed. I was hoping someone might have a trick.
I did my best to find the center on the flywheel and scribe a line as per your suggestion. The flywheel bolts seem to be in the center as expected.
I then slid a piece of paper in the center joint to see where it meets my scribe line.
It appears to be right on center with my .086 shim stack on the drive side.
On further thought, this makes sense as MarkB pointed out above that the drive side bearing on the late case has been shifted outward.
The late crank has a thicker counterweight on this side that makes up the distance that my early crank lacks.
For some reason I was making an assumption that my shim stack was excessive and the slack was on the timing side at the thrust washer.
Unless someone points out that I'm off base here, I'm going to run with it. Whew!
Thank you to those that helped me hash this out and I hope it was not too tiresome.
1966 BSA Lightning
(2) 1967 Triumph "Choppa"s
1974 Indian ME125
1960 Harley Servi-Car
Nick H #794682 01/03/20 5:55 am
I didn't know you had the flywheel on, that makes it a bit more awkward.
Your method is as good a way as any though.
Page 2 of 2 1 2
