Bobster
Bobster
Seattle, Washington
11023 Registered Users
franko 138
koan58 68
DavidP 64
Rohan 51
1,150,777 mail-order LSR
Topics68,980
Posts691,293
Members11,023
49 registered members (Beach), 1,597 guests, and 983 spiders.
Remove an A65 con rod via sump?? #793576 12/21/19 7:26 pm
Danam Online Content OP
OP Online Content
I saw this video where he said he removed an a65 con rod via the sump opening... this is possible?? I want have new small end bushings installed but don’t want to tear down the case. Thus would be great!
video link here
Re: Remove an A65 con rod via sump?? [Re: Danam] #793586 12/21/19 9:43 pm
Servodyne Offline
It's an interesting question. Randy seems pretty confident that he did it, but he must have used open ended spanners to get on the big end nuts with the very tight access.
It would be a bit easier with the very late A65 flywheels that are scalloped around the big ends rather than the full width ones, and easier still if BSA had the foresight to have used a wider sump plate.
Let use know how you get on.
1957 BSA A10 Spitfire
1971 BSA A65 Firebird
1971 BSA A70 Lightning
1975 Norton Commando
1961 Norton 99
Re: Remove an A65 con rod via sump?? [Re: Danam] #793588 12/21/19 9:52 pm
bodine031 Offline
You had the pin bushing turn you have a bigger issue than renewing the bushings
Re: Remove an A65 con rod via sump?? [Re: Danam] #793595 12/21/19 11:25 pm
A rod cap would be one thing but to get that rod and piston out to remove the small end one would need to be Houdini.
Re: Remove an A65 con rod via sump?? [Re: Danam] #793618 12/22/19 5:09 am
Mark Parker Offline
You cannot do it. I believe you can remove the centre rod on a Rocket three.
Re: Remove an A65 con rod via sump?? [Re: Mark Parker] #793621 12/22/19 6:13 am
DavidP Online Content
Yeah, some people actually use this method when installing cylinders on triples.
Re: Remove an A65 con rod via sump?? [Re: Danam] #793625 12/22/19 7:33 am
NickL Online Content
He either had a bloody great hole knocked in the case by the rod snapping OR
a special cut away flywheel and custom sump plate.
Anyway to get the rod and piston out means all the top end off. That's the only way
to do a small end bush.
Some aftermarket rods have the nuts at the top of the big end so you could get the rod out that way.
