marinatlas
marinatlas
FRANCE- DINARD -BRITTANY
Installing Handgrips
#793319 12/18/19 8:02 pm
mrcarb Offline OP
Would anyone here have any suggestions on how to install handlebar handgrips? Soap and water? Heat them or warm them? A lot of pushing?
Thank you in advance
Re: Installing Handgrips
mrcarb #793320 12/18/19 8:10 pm
I use a squirt of hairspray
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando
mrcarb #793323 12/18/19 8:37 pm
Wd40 works great.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
mrcarb #793326 12/18/19 8:54 pm
+1 for the hairspray.
Cheers!
Ph.
Best regards
Phil
Duesseldorf/Germany
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'84 Yamaha SR 500
mrcarb #793330 12/18/19 9:48 pm
Definitely hairspray, it lubricates them so they slip on easily then sets gluing them in place.
You get odd looks as a bald man buying hair spray
Beach #793335 12/19/19 12:39 am
Originally Posted by Beach
Wd40 works great.
Most definitely !
Do not use soap and water...especially soap, unless you want to find rusting handlebar ends next time you change out your grips. I'm not even sure the grips would seal on the bars. WD40 is IME the best lubricant for fitting and removing grips.
1971 BSA A65 650 - Project
Jon W. Whitley #793341 12/19/19 2:44 am
I think most people are under impression that Wd40 is a lubricant, when in fact it's a water displacer.
When my grips are on it takes spraying Wd40 inside to get them off.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
mrcarb #793342 12/19/19 2:56 am
Hair spray again.
Spray it on thick.
leaving the grips out in the sun to warm up a bit helps a lot
then be brutal & quick
Put the clutch side on while the throttle side is off the bike
Do the throttle grip by itself
You can get air locks which makes the last little bit hard to get on with grips that are airtight.
mrcarb #793347 12/19/19 3:59 am
To get old grips off, I wedge a thin screwdriver to slightly open the grip. Then spray some Berryman carb cleaner inside and work the grip and it comes right off. To attach, spray a little inside and slide it on. It dries quickly and stays put.
Coming to terms with your delusions, is the first step to sanity
mrcarb #793366 12/19/19 8:59 am
I’ve never had problem On sunnier days but a few times riding long distances in the wet, the grips start to slide off the bar. It fine when they dry out but a bit of water in there and they are off.
I’ve taken to roughing up the chrome on the bar and then carpet adhesive. Contact adhesive might work. Tried the carpet adhesive without roughing the chrome up and it still slides off eventually.
mrcarb #793371 12/19/19 10:28 am
Compressed air is the simple way? Just use an air nozzle and expand the grip with air, You can start it on, put the nozzle under the edge and make it expand with a squirt of air and it slides on. However some more fancy grips have alloy crimping sections on the ends that don't expand much, but air still works, just more difficult.
mrcarb #793373 12/19/19 10:46 am
Used both hairspray and WD40, both work, surprising how well the WD40 once dry grips.
Beach #793434 12/20/19 12:45 am
I knew as soon as I typed it, using the word lubricant, coupled with WD40, would draw a response to point out that WD stands for water displacer.
However, while that is true, WD40 also has lubricating qualities as noted by the manufacturer.
https://www.wd40.com/products/one-gallon/
"WD-40® Multi-Use Product protects metal from rust and corrosion, penetrates stuck parts, displaces moisture and lubricates almost anything. WD-40® One Gallon is ideal for heavy jobs that require soaking and dipping."
mrcarb #793436 12/20/19 1:09 am
Spay clear lacquer into the grip and quickly slide onto bar. Probably same as hair spray but you might have a can of clear lacquer on hand.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
2018 Kawasaki Z900RS
Jon W. Whitley #793438 12/20/19 1:16 am
Sorry Jon. Didnt even notice you had called it a lubricant. Was actually meant for people who never considered it for this use. I guess it is a lubricant, but it disappears quickly.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
mrcarb #793439 12/20/19 1:19 am
P-80 rubber lubricant, hands down.
mrcarb #793440 12/20/19 1:20 am
mrcarb #793441 12/20/19 1:21 am
You could also call lacquer a lubricant until it dries. WD-40 is what I use to put on grips. To take off, spray some under the grip with the tube, wiggle around and the grip comes off without damage.
If used on machinery to displace water it should be wiped off after. It becomes a dust magnet.
mrcarb #793548 12/21/19 8:42 am
Brake cleaner works. You just need to be quick, some 20 seconds.
mrcarb #793567 12/21/19 4:54 pm
I have always used petrol. Small amount acts as lube, slightly melts the inside, then evaporates and dries.
AngloBike #793632 12/22/19 10:30 am
+1
