Grandad
Grandad
Triumph timing gears lightening?
#792084 12/05/19 2:13 am
tritr6 Offline OP
What is the latest recommendation on drilling timing gears
Re: Triumph timing gears lightening?
tritr6 #792106 12/05/19 4:04 pm
Great way to kill a couple of cold winter evenings. It really impresses your buddies. As to possible gain, or loss it can be debated "until the cows come home."
The current theory you get better results using heavier cam wheels with the twins and singles. The mass helps dampen the oscillations as the valve spring
snaps the cam wheel rotation backward and forward. Triumph went to full width cam wheels on the 750. and if anything, we saw slight improvement in performance.
Any one have a Spintron?
You will get more out of spending your money on improving the flow around the valve seat.
tritr6 #792118 12/05/19 8:09 pm
Removing weight from reciprocating parts will have much more effect
Andy Higham #792120 12/05/19 8:35 pm
Are you sure it will have any effect that you will notice when you’re riding the bike?
tritr6 #792123 12/05/19 9:39 pm
That's an interesting subject that engineers using the spintron system have explored.
Changing the resonant frequency of a part, or group of parts that act in unison, often
delivers interesting results. They are not always intuitive.
tritr6 #792131 12/05/19 10:57 pm
Online Confused
bought these at the swap meet at the OVBSA meet in steubenville. can't remember whether i put pictures of them up before.
these have been milled thinner as well being drilled
I would rather be ashes than dust
tritr6 #792166 12/06/19 10:31 am
As usual, John hit the nail on the head.. Dick
tritr6 #792169 12/06/19 11:44 am
You want drilled gears ? How about a WW2 Bristol sleeve valve radial engine aircraft engine..
tritr6 #792213 12/06/19 9:32 pm
Online Confused
jeez
did those radials use a distributor cam or massive waste sparks?
kevin #792218 12/06/19 10:52 pm
jeez
[Linked Image from gracesguide.co.uk]
tritr6 #792219 12/06/19 11:27 pm
Online Confused
that's a magdyno, isn't it? the generator is part on the bottom?
i don't see a spark distribution system in there, although i think i see one set of ignition points on the left end of the lower shaft.
why would the spinning armature have spark towers on it?
strange instrument.
tritr6 #792228 12/07/19 12:56 am
It's just a mag Kevin, no dynamo.
The 500 cam pinions are thinner/lighter but the idler is too small to use.
I wouldn't bother, they rattle enough with the full width normally.
When racing i saw enough 'lightened' bits break and wear at extreme rates
to wonder about the advantages..................
But, as John said, it's a way to spend cold winter evenings.
The Centaurus was a lovely bit of kit for a radial thing. Sleeve valves, a complex way
to go about things eh?
NickL #792266 12/07/19 3:27 pm
Yes, The Brits seemed to love very complicated piston engines considering some materials were harder come by.The Napier engines were even more complicated...The Americans, with no limit to materials, built their engines using a lot less parts mostly because of mass production by unskilled workers and maintenance done 1000's of miles from the factories.
Napier Sabre sleeve valve
[Linked Image from aviationshoppe.com]
The somewhat less complex Pratt & Whitney R2800 Double Wasp....
[Linked Image from williammaloney.com]
tritr6 #792312 12/08/19 12:14 am
Both the Sabre and the Centaurus were developments of earlier engines (Dagger+Hercules)
When their early development was going on the best way of running detonation free on low octane
fuel was to use a flat cylinder head. Sleeve valve engines had flat heads and no valves to overheat.
It was much later on that higher octane fuel became available. They had embarked on a mission by then.
Also as an aero engine, the emphasis at that time was for low frontal area so the H section was
quite sensible. BRM made a formula 1 racing car with a 16 cyl H engine in the early 60's too.
On the face of it the sleeve valve arrangement is complicated but the PW does have it's own
internal complexity too, varying the timing around the radial engine etc.
Britain at that time having a huge empire also had the situation of engines being repaired and serviced many
thousands of miles from the factories and had been doing it for years before 1939. Unskilled workers
were also used in their thousands in british factories during and before the war. It's a bit of a myth that all
the workers at Rolls Royce Aero wore white coats and carried slide rules. Two or three new factories opened
to produce the merlin during the war at various locations, largely staffed by initially 'unskilled' workers.
Same thing with aircraft production or in fact any form of production, huge demand required lots of labour.
America was not unique in this approach, it was just bigger, had more resource and was not under attack.
If you talk to some mechanics who worked on any two row radial they will all tell you what a pain they were to work on.
tritr6 #792329 12/08/19 7:24 am
So is the cam on the P&W driven at half crankshaft speed and using one set off lobes to feed all cylinders it each row?
Mark Parker #792333 12/08/19 12:28 pm
I believe it's driven at 1/6 crank speed,,It's a large ring with external lobes (6?), one ring for each row, 9 cylinders in each row...It is aguably the best all around large radial of the War. over 125,000 were made and unlike most other WW2 engines, it was used in passanger and cargo planes until the jets took over in the 1950's..
tritr6 #792340 12/08/19 1:27 pm
Online Confused
what are the relative advantagez and disadvantagez of radials over inline enginez in aircraft?
when i lived in california the crop dusters used both.
tritr6 #792341 12/08/19 1:39 pm
My guess regarding fighter aircraft would be the reduced frontal profile of an inline, both for aerodynamics and presentation of a smaller target.
1967 T120R
1970 T120R
1970 Commando
tritr6 #792349 12/08/19 2:17 pm
Online Confused
well, the cropdusters certainly flew very slowly, no matter what the engine was.
torque is what tbey worked with.
they would drop stuff on you for fun, if they knew you.
tritr6 #792351 12/08/19 2:25 pm
Crop dusters generally use air cooled inline or radial engines...Inline aircooled engines can be Ranger inverted inlines or V's. Some use flat opposed 4 or 6 cylinder air cooled Lycomings..For duster use it's more likely a design choice by the airframe manufacturer ....
For warplanes, the radials used in the FW190 and US fighters such as the Corsair and P-47 gave up little to no top speed in exhange for the ability to absorb more combat damage ...One bullet can puncure the radiator or maze of coolant lines and the engine will seize soon afterward..
tritr6 #792395 12/08/19 9:15 pm
Online Confused
well, i didn't always get along with the dusters, being a beekeeper with some 800 hives scattered around their workspace, but i can appreciate what they do.
tritr6 #792421 12/09/19 1:11 am
Moderated by  Allan G
