Bobster
Bobster
Seattle, Washington
11023 Registered Users
franko 138
koan58 68
DavidP 64
Rohan 51
1,150,777 mail-order LSR
Topics68,980
Posts691,293
Members11,023
43 registered members (Beach), 1,597 guests, and 977 spiders.
Page 2 of 3 1 2 3
Re: Another boring question. [Re: Tracey Spear] #771061 04/15/19 12:20 am
koan58 Online Content
If they are 3.5 thou you have a heck of a careful break in to do, lots of short runs.
Definitely get them measured, then you know.
The boring fellow should be happy to adjust with a little honing if needed, considering he didn't follow your instructions.
Alternatively, he should accept responsibility for a seizure during normal break in.
Re: Another boring question. [Re: Tracey Spear] #771126 04/15/19 2:30 pm
Tracey Spear Offline OP
Yes, not that it detracts from the conversation. I'm more concerned about 0.0035 piston clearance and whether to build as is or send back to the machinist than a missing 0 in a forum.
Re: Another boring question. [Re: Tracey Spear] #771163 04/15/19 8:39 pm
Shane in Oz Online Content
As per the others, .0035" seems too tight. I'd send it back for another run-through with the hone to take another half a thou out.
Re: Another boring question. [Re: Shane in Oz] #771177 04/15/19 11:01 pm
Ignoramus Offline
3.5 is too tight for certain
Re: Another boring question. [Re: triton thrasher] #771295 04/17/19 12:31 pm
Richrd Online Content
What concerns me is the machinist not listening to what the customer wants.
I know one shop that had a few tighten up at .004 when they started using emgos so had to go to .0045.
.035 would be fine in a 250, maybe.
Rich (last remaining member ThreeMustGetBeers)
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Another boring question. [Re: Tracey Spear] #791908 12/03/19 6:19 am
My apologies everyone, life kept me away from the project and forum for a few months.
Rather than speculate, I took the cylinders and pistons to a different machinist. He measured the Emgo + .020 pistons:
1 = 2.967, 2 = 2.966
The Bores measured:
DS = 2.9745, TS = 2.974
If Clearance = Bore - Piston. Match Piston 1 to DS and Piston 2 to TS
Then DS Clearance = 0.0075 and TS Clearance = 0.008
He thought that was way too loose, but he doesn't work on old brit bikes.
The A65 General Data for Piston, Clearance, top of Skirt is 0.0094 - .00109.
If I'm reading it right, and if machinist measured right, that leads me to think the holes are a little tight.
But General Data spec is based on '69 pistons.
The original machinist said he contacted Emgo and bored to their clearance specs because modern pistons don't expand as much.
I'm confused. I have an automotive machinist who thinks the pistons flop around, and spec's telling me the holes are too small.
Or I'm totally misunderstanding piston clearance.
Re: Another boring question. [Re: Tracey Spear] #791910 12/03/19 7:20 am
triton thrasher Offline
Measure clearance near the bottom of the skirt.
The commonly available modern pistons such as Emgo do expand as much as the originals.
Re: Another boring question. [Re: Tracey Spear] #791911 12/03/19 7:22 am
NickL Online Content
1.5 thou per inch of bore is typical, and always a safe bet. (measure at bottom of skirt this allows for taper on the piston if there is any)
Twice that for iron rings is about right too.
That is for cast pistons, it can be up to double that for forged ones. In either case the manufacturer will advise you.
Re: Another boring question. [Re: Tracey Spear] #791916 12/03/19 8:21 am
Not sure which manual you have that from. If you look at the early A65 WSM it states around 2-3 thou which is tight. Later manuals say more.
You want at least 4-4.5 thou.
Or as nick says 1.5 thou per inch of bore
Re: Another boring question. [Re: Tracey Spear] #791928 12/03/19 11:43 am
Mark Parker Offline
The manual I have handy says .0039"- .0054". However, I've seen oversize pistons that gave instructions on the box to bore to 'X' size, Hepolite I think, if you measured the pistons and compared that to 'X' they would have much more clearance, like .006-.007"+ probably why they didn't tell you the actual clearance on the box.
Early A65 pistons are different, not as heavy with less valve cutaway depth. If any pistons used had split skirts they would run much tighter. Also stock A65 pistons are thinner than oversize pistons. Over size are basically the same casting machined less so +.060" pistons can be pretty heavy. Which may effect the clearance needed.
An A65 +.040" piston and pin is 425g, a T140 340g, a cast JP 79mm B44 422g, 79.5mm Omega cast 396g, an 80mm JE forged 372g. Ed V's A65/A70 pistons are like the B44 versions, some of the very best, forged by JE and designed to run small clearances, .0035-.004" safely in an iron cyl or .002-.0025" in nicasil alloy cyl. Rings seal better when the piston is not rattling around.
.0075" or .008" is pretty big if the pistons were measured near the bottom of the skirt. JE pistons are measured up a bit from the bottom of the skirt.
Re: Another boring question. [Re: Tracey Spear] #791956 12/03/19 5:36 pm
Allan: My reference is the BSA Workshop for 69-70 A65, A50.
Everyone else attempting to help a baby engine builder.
I don't have a 3" mic, but with Vernier Calipers I can get within one digit of the machinist measurement.
he measured the pistons at 2.966 and 2.967. I got 2.967 and 2.968, bottom of skirt, perpendicular to pin. Close enough I think to confirm his values.
If I then accept his bore measurement that still leaves me with Clearance DS = 0.0075 and TS = 0.0080
The manual states Clearance, Bottom of Skirt, on Major Axis is 0.0039 - 0.0054.
Which confirms the machinist_2's opinion that the bore is excessive and the piston too loose.
Which means the original machinist_1 totally f'd up the job.
Which means I have to now order + 0.040 pistons, and re-bore.
Correct?
Re: Another boring question. [Re: Tracey Spear] #791957 12/03/19 5:58 pm
8 thou clearance might work.
Re: Another boring question. [Re: Tracey Spear] #791958 12/03/19 6:05 pm
kommando Offline
The 4 to 5 thou is the starting point, you are allowed another 5 thou of wear, so 8 thou still leaves you 2 thou to use. That assumes the pistons expand like the originals, f they expand more then 8 may be a good starting point and you have 5 thou to go on wear.
Re: Another boring question. [Re: Tracey Spear] #791965 12/03/19 7:10 pm
Impress your friends with your “racing clearances.”
Re: Another boring question. [Re: Tracey Spear] #791973 12/03/19 8:05 pm
Sorry if I touched a nerve, this wasn’t intentional.
However you don’t need a 3” calliper. (Most vernier callipers aren’t accurate enough and the same measurement twice with cheap digital ones can give different readings each time. The biggest micrometers I have are 2” so not big enough for a piston, but if you have feeler gauges or pin gauges in small enough sizes then you will get more use and accurate enough readings from this. I use feeler gauges about an inch or so up the skirt and at the side of the piston/skirt. This will be more than enough and give you a better result than measuring both barrel and
Piston and calculating the gap.
Re: Another boring question. [Re: Allan Gill] #791988 12/03/19 10:44 pm
My apologies Allan. Read back like that, it comes off as quite rude. That wasn't my intention, your reputation is one of always trying to help. All I intended to do was let you know what my source was since you had mentioned an earlier reference. That came off really bad.
Back to my confusion. I think there is something fundamental I'm missing here. Keep in mind, I've never done this before.
The manual states Bottom of Skirt clearance range is 0.0039 - 0.0054.
The manual also states Top of Skirt clearance range is 0.0094 - 0.0109.
Given that, by the math, I have Bottom of Skirt clearance of 0.0075 and 0.0080.
How do I translate Kommando's statement from above " The 4 to 5 thou is the starting point, you are allowed another 5 thou of wear, so 8 thou still leaves you 2 thou to use."
Is "The 4 to 5 thou is the starting point" the Bottom of Skirt clearance?
"you are allowed another 5 thou of wear" is that wear the difference between top of skirt and bottom of skirt 0.0054 to 0.0109?
"so 8 thou still leaves you 2 thou to use." Would you build an engine like that? Seems to me that would be like installing a brand new, worn out piston.
Re: Another boring question. [Re: Tracey Spear] #791993 12/03/19 11:00 pm
Mark Parker Offline
Don't worry about the top of skirt clearance that is machined when the piston is made. The top of the piston gets hotter and expands more in use. The bottom of skirt clearance is what you have the bore finished in relation to, and that's front to back measurement, pistons are oval on the skirts narrower on the sides. You can use 7-8thou clearance. Check the ring end gap width and see what they are at the top middle and bottom of the bore, they will show if it's the same all the way through.
Re: Another boring question. [Re: Tracey Spear] #791997 12/03/19 11:32 pm
Back to my problem. I want to verify whether Machinist_1 who delivered a good +020 bore. I took the completed cylinder and pistons to Machinist_2 who balanced the crank for me. His measurements seem to indicate that this brand new bore is at the far range of worn out. What's a neophyte engine builder to do. Slap it together, knowing that seizure during break in will be very unlikely, pistons may rattle around a bit, and another top end job will be in the future.
Or
Suck it up, order + .040 pistons and effectively start over.
What do you more experienced builders recommend?
Re: Another boring question. [Re: Tracey Spear] #791998 12/03/19 11:34 pm
kommando Offline
If the figures you quote are correct then your 20 thou over rebore is 1/2 worn out already, but go to 40 thou over and you get no running at 20 thou at all and waste a good set of 20 thou over pistons instead of running them for 1/2 their life and pay for 2 rebores. What is your annual mileage going to be, not a lot going by most.
Re: Another boring question. [Re: Tracey Spear] #792000 12/03/19 11:40 pm
No worries at all Tracey, I think I may have miss read your previous post when I put my reply in and not correctly noted that you referred to the top of the bore clearance.
I could be wrong here with this next statement so someone please pull me up if I am.
There is more piston rock at the bottom of the stroke than at the top, it’s greater again with a long stroke motor with a short rod and lessens with a long rod motor with a short stroke. By measuring the wear at the bottom of the bore you have a better idea of actual wear at the most worn point. On a used motor I would compare the gap at side Of the piston to that front or rear of the piston skirt.
Kommandos Point of having a further .005” on top so a total of 0.010” gap is how far you can go if you measure the bore of a Used motor and determined if it needed the next oversize or not.
For the amount of use most of our bikes get now, you would most likely be fine at a larger gap. And it last 10 years....
Personally I’d get the feeler gauges out and check the bore that way before doing any more.
I was looking on U tube to find a decent example, instead in typical u tube fashion I got distracted but found these videos interesting none the less, the first one with his plastic engine cut away gives you a good idea of what is happening inside the motor, the second one is interesting in other ways but but seemed to have me chuckling anyway.
Video 1
Video 2
Re: Another boring question. [Re: Tracey Spear] #792006 12/04/19 1:08 am
Mark Parker Offline
If you have rings put a compression ring in the cyl and see what the bore size is at different points. Measuring its end gap with feeler gauges. It's not uncommon for someone honing, to finish the bore, honing more from the top, this will show up pushing the ring down to different spots and measuring the gap with feeler gauges. Without a bore mic do not expect to measure the bore accurately nor the piston without a micrometer.
So try what Allen suggests and measure using a feeler gauge between piston skirt, front or back by seeing what size feeler gauge fits. Put the gauge mostly in the bottom of the cyl and slide the piston in over it, you will see when the bottom of the skirt no longer has play and there is a little resistance, then see what size feeler gauge does that. Start with .004". Its only the bottom of the skirt you are measuring and you are not trying to lock it up just till it eliminates the play and has a little resistance.
Re: Another boring question. [Re: Tracey Spear] #792024 12/04/19 9:30 am
Bores don’t wear fast with the oil they sell nowadays. Having less wear left on your bores because of the bigger clearance really doesn’t matter.
You may get more piston slap noise than others, you may not, but that doesn’t matter much either.
You may as well stop quoting us the stuff about the clearance at the top of the pistons. It’s the clearance low down the skirt that matters here.
Re: Another boring question. [Re: Tracey Spear] #792029 12/04/19 12:26 pm
Hillbilly bike Offline
I wouldn't spend the money to have cylinders bored if the pistons won't be the correct clearance afterwards....Do it right unless it's just a beater.....
Re: Another boring question. [Re: Tracey Spear] #792043 12/04/19 3:44 pm
Tracy, don't worry so much. there are things we've learned from experience and things that have changed from when these machines were new and the books were written. All the above guys are saying basically the same thing but to you it sounds confusing.
IF mach 2 measured the bores correctly, and I might question that, the clearance will be a bit big, but you may never wear out the life you do have. put it together and run it.
Next time, talk to local motorcycle shops for recommendations on who to use.
YOU TELL THEM WHAT CLEARANCE YOU WANT AT ONE HALF INCH UP FROM BOTTOM OF SKIRT. not the other way around. 3.5 is too tight. the proper way to measure clearance is with a bore guage which measures the difference between the piston and the bore. there is a chance mach 2 introduced error to his measurements by measuring the bores as a separate step.
and the Snake Bike
and a Honda?
Re: Another boring question. [Re: Tracey Spear] #792068 12/04/19 11:09 pm
F
Fullminator Offline
F
I would say the minimum clearance bore to piston would be .0045 Anything less will risk a seizure. The seizure will happen after the bike has been sitting unridden for a while and the weather is on the cold side, and within the first 5-10 miles or so. At the same time .008 is too loose. It will work, but when cold the piston will slap about and you will think you have a threshing machine instead of a motorcycle. This can be minimized by using straight 40 or 50 oil, but that is another subject.
The bore clearance at the top of the piston is immaterial. Measurements should be taken around the bottom of the skirt and at the thrust face, not on the wrist pin side. The only reason to measure the bore all around and up and down is to ensure the bore is straight. This is something many machine shops are incapable of achieving, since the majority of them are most adept at boring 4 cylinder Toyotas and Fords.
If your plans for the bike are like most of us-limited use- then the .008 will work and you may not be bothered with it. The other point is why do you have two completely different measurements of the same cylinder and pistons? Someone is having trouble.
From your posts, I suspect your machinist #1 did a crappy job. Believe me, I have been down this road, just as you are now. I am forever amazed at the sub quality work and excuse filled apologies from those that are in the business and professed to be professionals.
Fullminator
Page 2 of 3 1 2 3
