Crankshaft shimming
#791297 11/25/19 9:39 pm
Novice poster
Novice poster
Hi, I was wondering if when you are checking crankshaft endplay if you make allowance for the crankcase sealant ? Since you might need to add shims as required you wouldn't want to apply crankcase sealant until shims installed. Also is the bearing on the primary side loctited into the case if loose or is it installed on the crankshaft. The questions are in regard to 1965 BSA A65 lightning. Thanks Rebuild Rookie.
Re: Crankshaft shimming
CarpeDiem #791310 11/26/19 12:21 am
For the difference the sealant will make, no.
CarpeDiem #791319 11/26/19 1:47 am
In a 1965, the crank would originally have had a ball bearing, which would be pressed into the case on the primary side. It should not be loose in the case or require loctite.
CarpeDiem #791353 11/26/19 10:48 am
Parts Dealer
Parts Dealer
As MarcB stated, a 1965 model would have had a bearing on the drive side
You would not be "shimming" the crank should you be running a ball bearing
The only shimming you would do is to ensure your connecting rods are in the center of the liners
Get a spacer, washer and a rotor nut and tighten the drive side crank-end so the crank "shifts" to the drive side
From there, you can use some telescopic gauges and check the rods when you slip the barrel on
Also, your ball bearing inner race should be a tapping fit on the crank journal, if it is not, you can add some loctitie, but that will not cause end-float issues as your assembly will be fixed on the drive side
Good luck!
C.B.S #791354 11/26/19 11:10 am
Good luck!
Not true, the oil pump will pull the crank towards the timing side, this will in turn actually pull the ball bearing away from its housing so the shimming of the crank is just as crucial as on a roller bearing crank. The crank will shift to the drive side when tightened at build stage but will shift after a couple of thousand miles.
Also the use of bearing fit should be used in the worst possible situations. Even then I’ve found a sloppy housing then be too tight for the bearing once bearing fit is used. Standard procedure is to repair the housing.
Simply put follow MarcB’s advice.
CarpeDiem #791386 11/26/19 4:14 pm
Since I have taken a liking to the early unit twins.....
Marc & Allan are correct. You do have to shim the ball bearing cranks, you actually set running clearance between the crank and shoulder of the timing side bearing housing. .0015" - .003", sealant is not an issue.
Note, ball bearing engines, you check "end play" by checking the crank without the alternator rotor (or equivalent spacer) and nut not installed.
Roller bearing engine needs everything installed and tight.
You also need to shim the primary chain to keep from loading the crank. There are shims for that as well. A straight edge is as complex as you need to be on checking primary chain alignment.
The rods journals being centered are a myth. They are what they are due to the components used and BSA machining. The journals will be "reasonably"close to center with all correct components installed.
CarpeDiem #791413 11/26/19 10:31 pm
In your opinion only.
To get the best from the engine in terms of longevity and vibration etc. Centre them. Each to his own eh?
CarpeDiem #791414 11/26/19 10:44 pm
Parts Dealer
Parts Dealer
Some points here
- loctitie, referring to the crank journal NOT the housing
- Connecting rods being centered in the bore is a good thing to check, especially when cranks and cases have been changed - each his own
CarpeDiem #791421 11/26/19 11:44 pm
Makes no odds where you fit the locktite. It will still add a small amount of bearing crush and cause the ball race to run rough. It also should be a good fit on the crank and more often than not the case will wear before the crank. In many cases the bearing will actually spread on the crank journal rather than wear on the crank.
Back to the shimming, if you shim a crank to perfect centre then you have never tore the motor down afterwards least on the primary side and seen the bearing drift out of its housing. The only thing that will stop that happening is shimming the crank or an out rigger bearing outboard the primary drive/alternator.
As you say each to their own but the guys at BSA weren’t stupid, vehicles may have come on leaps and bounds in the last 50+ years but they didn’t add things to the WSM just because it seemed a good idea at the time. They made the best of what was available and understood very well what they were working with.
CarpeDiem #791431 11/27/19 12:15 am
Parts Dealer
Parts Dealer
Understood, but there are many ways to fix a common problem
You can weld the crank, hard chrome it or loctite it
Depends on the application and what that individual person feels should be done
You have your opinion on this, as do I
Allan G #791433 11/27/19 12:49 am
Don't quite understand what you are saying regarding centreing the crank.
This procedure normally involves making a bronze washer to suit the timing side as well as shimming or making a spacer for the drive side.
As you said before the natural thrust of these motors is toward the timing side due to the oil pump, this tends to pull the bearing out of it's
housing with a ball type if the movement is not restricted. With the roller this is not a problem unless using a double flanged one.
If you have to use loctite 638/641 etc on the drive side housing, you can normally get away with it if you use a c3 fit bearing. Stopping the
bearing moving by applying the previous method will help prevent the housing growing anyway.
Everyone has their own methodology with these things, normally if you haven't encountered any problems with a method, you don't change it.
It's a 'if it ain't broke........thing. Most of my experience on these was racing them, so i got plenty of problems........................................
CarpeDiem #791435 11/27/19 1:28 am
I was probably straying from my original point Nick, it’s quite late here and I aught to try and get some sleep. What I should say is there is nothing wrong in centring the crank providing you correctly shim (with shims and or a form of bronze thrust face on the timing side) to give the correct amount of end float.
centring alone without taking into account the end float is foolish. As unless you create a bearing retainer plate (which there would probably be no room for) the bearing will walk (or use an outrigger).
Adding anything to the crank is irrelevant as far as bearing walk is concerned Between the crank and the inner bearing race, doing anything to this surface is just kidding yourself. Once the end nut is bolted up there should be no lateral movement. If there is some clearance between the crank and the bearing then I have seen the ID of the bearing grow and become a slop fit. The first note I had of this was with Increased vibration. never found that on a ball bearing but have with the same crank when a roller was fitted. There was never any slack in the end nut. The bearing became a throw on fit and the replacement bearing was tight to the crank.
Put another way if you have to add locktite or hard chrome or what ever to that crank journal then you really aught to be looking at changing the DS bearing or at least checking it against a new one.
( I think we’re also moving off topic for the sake of a pissing contest. )
CarpeDiem #791447 11/27/19 5:50 am
Ahh, now i understand what you mean Alan. No pissing contest intended here.
Nick
NickL #791453 11/27/19 7:57 am
Nick
I didn’t mean you Nick lol. I hold your knowledge on the subject in high regard.
CarpeDiem #791483 11/27/19 9:49 pm
Novice poster
Novice poster
Hi, I am processing all the inputs, Thanks to everyone, I am sure your expertise will be tapped again. Rookie Rebuilder.
CarpeDiem #791500 11/27/19 11:40 pm
Novice poster
Novice poster
Hi, does the retaining cup on the primary side(between bearing and crank) get place curved edge facing crank or the other way around so has flat edge for shimming? not clear in manual. Thanks Rookie Rebuilder.
CarpeDiem #791501 11/27/19 11:53 pm
The shims sit in the cupped side, this then sits on the bearing inner flange.
If the cup does not sit on the flange it may be an early type cup on a later bearing type.
They changed the bearing in the late 60's and the inner diameter was different.
It's a nuisance i know, but around that time a few bearing manufacturers were amalgamating.
CarpeDiem #791504 11/28/19 12:12 am
Doesn’t centering the crank have to take into account end float, within a certain number of thou, by definition?
Restricting end float will surely limit how much a ball main on the drive side can “walk” toward the timing side.
Is this “walking” a proven fact? Only ask because it is a debated phenomenon in Triumph engines as well, and I’m far from convinced.
koan58 #791507 11/28/19 12:43 am
The beezer has an oil pump driven from the crank, this creates a thrust toward the timing side.
The early crank used a ball race on the drive side to retain the crank, when the cases heat up the
thrust tends to pull the bearing from it's housing as there is no thrust washer on the timing side.
I have seen this on several occasions. The matter is enhanced if the later crank is fitted with a ball race.
I am not saying centreing and shimming/spacing is the only way to go, but from experience it is a definite
improvement. As i said before, if you haven't had the problem you wouldn't see the need.
Getting the crank central is always a good idea anyway, if only for longevity.
When i raced a pre-unit morgo trumpet we used 2 rollers so shimming was required anyway.
I just feel that relying on interference fit bearings to retain the position of the crank when it can move
2 or 3mm without spacers/shims is not such a good idea.
It's only my take on it, it's not the law.
CarpeDiem #791511 11/28/19 2:01 am
Thanks Nick, makes perfect sense. You might have noticed I’m not a BSA man.
I am surprised there isn’t a thrust washer on the timing side, considering the bias of the oil pump, and I’d have thought that centering the crank would quite possibly involve shims to both sides (limiting end float at the same time surely?).
The maximum the drive side bearing could “walk” out from its housing would surely be the few thou end float that has been set (hopefully not 2-3mm).
If that truly happened, the next time you measure the end float it would be zero, or much less than originally set, unless you imagine the bearing moves back into its housing as it cools.
I recall similar interesting conundrums regarding pre-unit Triumphs with 2 ball-bearing mains – what gives during temperature expansion changes?
CarpeDiem #791512 11/28/19 2:42 am
The post '66 ones went to roller drive side and had a thrust washer on the timing side.
The ball race (earlier ones) did not. The crank was also wider across the webs.
It relied on the fit of the drive side race.
The available movement varies (without shims/spacers) enormously. If it's only a few thou then, no problem.
As with all production stuff back then, tolerances were variable, and the assembly relied on a bloke/blokes
on piece work doing the job. The cases were marked for shimming sizes. If he found that a few were tight,
the next 20 he did would probably be loose as he didn't want to do the job more than once.
Same score with gearboxes, i don't think i've ever seen a standard a65 gearbox layshaft set up properly
on an original bike. If they were tight, the box had to come out again............so......
50's and 60's production lines for workhorse motorbikes and cars were like that, like it or not. These were not Bentleys.
You are also relying on the fact that the engine is all as it came from the factory.
If a late crank is fitted to an early motor it will have a lot of movement available.
The cases grow so much as they heat up, end float is increased anyway. I hear a few people say the
crank expands at a higher rate from cold initially but a couple of thou maximum is all i ever allow.
Normally setup the crank to just binding, then some sealant on the cases gives the required end float.
With a warm motor it'll be 5+ at least.
CarpeDiem #791515 11/28/19 2:54 am
Cheers Nick, makes sense.
" I hear a few people say the
crank expands at a higher rate from cold initially"
I don't see how that could possibly be true, considering the heat pathways from the top end and expansion coeffs of steel vs alloy.
CarpeDiem #791517 11/28/19 3:03 am
Well,,,,,,,,, that's my take on it but a few blokes here say they have pushed bearings through the primary case
due to insufficient end float setup. They say the immediate heat generated by the engine makes the crank
grow faster than the cases from cold. I've never experienced it but that's what they say. Maybe they assembled
the engine in very cold weather?
koan58 #791530 11/28/19 9:48 am
The crank big end journals have a certain amount of play which the rods can run, there is also a mahoosive gap between the rod and the piston gudgeon pin boss, hence why you shouldn't have to worry too much about crank centering.
The crank walk is prooven enough. My own setup has a needle roller on the timing side, I use an outrigger bearing on the drive side to locate the endfloat. Following some not so good advice about the ball bearing not needing the outrigger (in my situation) as it would keep the crank located on one side, this I did. It meant I didnt have to space my primary case out, it also meant it would be easy to strobe time my bike.
After about a thousand miles I removed the primary cover to change a sprocket or something (can't remember what reason now) and found the front pully flush against the crank case, for the short time it had been doing this it has started to mill away against the crank case. Had I still been using a drive chain setup then the damage would have been much worse. The outrigger went back on!
Its worth noting that the bearing was a good and propper fit in the case, not a push in fit by any means.
My instance was more noticed becasue of the modifications to the TS giving much more end float than If I had a thrust washer fitted for example, If you imagine the thicness of a thrust washer then this is how much it would have walked by. If you have only 1 thou or 2 endfloat when cold then it is probably just enough to allow the crank to be pulled over to the thrust face on the TS bearing without having enough space to allow tollerence within the bearing but not enough to pull it off its seat... Im speculating, Its a good question which to that bit I don't know the answer.
koan58 #791531 11/28/19 10:12 am
From a previous experience with the same motor, I was having bearing cages crush, despite there being enough clearance to clear the crank, there was insufficient clearance when hot, power was being sapped and the needle roller was being crushed down onto the bearing cage. (creating more clearance was the mechanical change was made, this was before fitting the ball bearing DS bearing)
An example of heat coeff for steel vs alloy can be seeing if you drop a crank case in a warm heat soaked over vs putting in an oven then turning it on. If the oven is heat soaked the aluminium should expand more rapidly than the steel (bearing) and the bearing will drop out. Put them both in a cold oven and turn the heat on and they will both expand at the same rate, you stand as much chance the bearing dropping out then as you do with the cases at room temperature. The crank and cases will both heat at a similar rate.
Are you sure Nick? the early cases were not machined as deeply if at all on the drive side Link thanks to CBS
