Don Leaming
Don Leaming
Ontario Canada
Atlas Kicker Bushing Replacement
#790291 11/16/19 11:25 pm
BobM Offline OP
My 1967 Atlas has started leaking from where the kicker shaft comes through the gearbox outer cover. Do I press out the old bushing and press in a new one, or is there a different way I should do this? Thanks.
1966 Triumph Thunderbird 6TA
1967 Norton Atlas
1967 BSA Spitfire
Several Harleys
Re: Atlas Kicker Bushing Replacement
BobM #790296 11/17/19 12:17 am
Often the O-ring for the kick starter is perished and/or loose in the outer cover. Sometimes the corresponding steel bush is worn, and sometimes also the kick-starter shaft. I've seen that steel bush loose in the housing. Worth checking it all carefully before pressing out the steel bush.
When replacing the O-ring, note that Norton finally supplies a Quad Ring for that function, but you are best served by machining the outer cover to take a radial lip seal as fitted to the MKIII.
... gREgg
[email protected]
BobM #790297 11/17/19 12:20 am
You could also just fit the seal which goes in without any machining.
The bush has to come out to fit it.
trevinoz #790349 11/17/19 4:41 pm
Yes there is a modern type seal that will fit between the bushings without the need to mod. Works great. Did it on 74 Commando, 66 Atlas and 67 atlas. Will look for that seal number.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Moderated by  Dave Comeau
