SmoothPierre
SmoothPierre
South Lincolnshire, UK
#@*& I think I’m screwed!!!
#790238 11/16/19 5:55 pm
Finalizing my engine rebuild and while tightening the clutch spring bolt on the inner cover, the bolt snapped off.
Damn it!!!!!!
I tried drilling it out and using an easy out but all I did was make the hole too big.
I’m screwed right?
Are the entire engine cases shot now?
Do I need to start from scratch and build an entirely new engine?
I am SO FRUSTRATED!!!
Is this bolt necessary? Meaning if I just set it in the hole and attached the clutch spring to it and then attached the outer case, will that hold the bolt in place enough to anchor the clutch spring???
I am at a loss I am so frustrated.
Any words of wisdom or hope will be greatly appreciated.
1973 Norton Commando Project
2016 Ducati Xdiavel
1968 Ford GT40 Replica
Re: #@*& I think I’m screwed!!!
Norcoastal #790239 11/16/19 6:01 pm
What sort of bike is it?
Norcoastal #790241 11/16/19 6:07 pm
I’m sorry, it’s a 1968 B44 441
2016 Ducati Xdiavel
Norcoastal #790242 11/16/19 6:09 pm
I have such a knot in my stomach. I’ve been working on this engine for weeks and I’m just about done. New seals, new bearings, new rings, new clutch. Just ordered a whole new set of Allen bolts to put the cases together and I’m done.
2016 Ducati Xdiavel
Norcoastal #790243 11/16/19 6:11 pm
No idea which part you having issue with, is it a clutch spring adjuster nut on the primary side or something to do with the clutch cable lever on the timing side. Posting pics removed misinterpretation.
Norcoastal #790244 11/16/19 6:18 pm
Guessing the kick start return spring? And the 1/4" bolt that anchors it.
Norcoastal #790246 11/16/19 6:21 pm
For some reason I can’t upload pictures. But it’s the little bolt on the kickstart side of the engine. It’s on the inner cover and all it does is allow the kick start spring a place to anchor.
Sorry I said clutch spring. I’m a little upset.
It’s just the bolt with the little knub on it to hole the kick start spring. I don’t believe it has any other structural use and on the outer cover on the kick start side, there is a recessed hole to accept this knub which is why if I just put the cover on it “ may “ be ok???
2016 Ducati Xdiavel
Norcoastal #790249 11/16/19 6:28 pm
I think I’m [email protected]#ked!
2016 Ducati Xdiavel
Norcoastal #790250 11/16/19 6:28 pm
Step back, calm down and decide what to do, it may be best to take it to someone to weld a rod onto what it left so enough torque can be applied or use impact driver but no easyouts as they get you in the mud even further.
Norcoastal #790251 11/16/19 6:37 pm
If you remove the inner timing cover, can you grip the rest of the bolt and undo it?
And everything Kommando said.
Norcoastal #790252 11/16/19 6:37 pm
Thanks but I’m beyond that I think. I drilled the hole too big. My only option that I can think of is to maybe have someone melt aluminum into the hole and tap it from scratch.
This just set me way back. Damn it!!!
2016 Ducati Xdiavel
Norcoastal #790253 11/16/19 6:39 pm
This is a nice B44B early ‘68 engine. I’ve put a lot of time and money into it.
It doesn’t matter at this point to try and get the old bolt out, I think I over drilled and now the engine case is shot.
2016 Ducati Xdiavel
Pelle #790255 11/16/19 6:41 pm
I’ve already removed the inner cover. The bolt had broken deep into the hole which is why I tried drilling it out which just made it worse.
2016 Ducati Xdiavel
Norcoastal #790256 11/16/19 6:43 pm
I can feel your frustration, so close to completing the rebuild, yet so far.
Luckily the bolt you mention is attached to the inner timing cover which is easy enough to take off on a B44.
So remove the inner timing cover, take it to a local machine shop, explain what happened and get them to machine out the old bolt, fit a re-thread insert and off you go. Alternately, source a new inner timing cover, there are plenty available.
gunner #790258 11/16/19 6:48 pm
Thanks gunner, but the inner cover is fine. It broke off in the engine case. It the engine case that I drilled too big.
I doubt anyone has a thread for a ‘68 British bike in a modern shop, or do they?
2016 Ducati Xdiavel
Norcoastal #790259 11/16/19 7:07 pm
The stud that holds the kickstart spring, threads into the inner cover as previously stated. Maybe it's something different you broke.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Norcoastal #790260 11/16/19 7:08 pm
Depending on the size of the hole now, possibly a thread repair insert can fix this. Anyway the engine case is not scrap.
Norcoastal #790261 11/16/19 7:18 pm
OK, after studying the parts books I think I see what you mean now. It sounds like the kick-start return anchor bolt (part 57-3764) has broken off where is screws in to the TS crankcase. This part fits through the inner timing cover and screws in to the timing side crankcase.
Maybe what you could try is find someone good at welding and get them to weld a small bolt to the broken off part. The heat will help free the seized part and it should then be possible to unscrew the old bolt.
Alternatively remove the engine and take it to a local machine shop to get drilled out or find a new set of cases.
Norcoastal #790262 11/16/19 7:18 pm
I’m going to search vintage motorcycle repair shops and see if someone can fix this. I’m a weekend mechanic. This is beyond my ability.
I’m so mad at myself. I could have just left it well enough alone. I didn’t have to try and tighten it.
It’s my own fault, I’m just beyond frustrated.
Thanks for all of your advice. I’m either going to try and get it fixed or buy new engine cases.
2016 Ducati Xdiavel
gunner #790263 11/16/19 7:20 pm
Yep...
Anyone have an extra set of cases they’d like to sell 😞
2016 Ducati Xdiavel
Norcoastal #790264 11/16/19 7:26 pm
You are not there yet, 2 site sponsors can help you do a repair, edv engineering and Peter Quick at unitsingles.
https://www.shopevengineering.com/
www.bsaunitsingles.com
kommando #790266 11/16/19 7:36 pm
I’ve purchased a lot of parts from Peter. He knows my engine. Maybe I’ll reach out to him.
Thanks K
2016 Ducati Xdiavel
Norcoastal #790267 11/16/19 7:43 pm
It's not a big deal to assemble and disassemble one cylinder BSA engine.
Everything will go so much better and quicker second time around.
Remember installing and uninstalling gearbox of BMW R75 ( military bike from second World War ) many years ago - first time it took me 3 hours, fourth time just an hour.:)
Adam M. #790269 11/16/19 7:56 pm
Haha, second time around is funny. I must have taken this apart 10 times getting everything right. But you’re correct Adam. These motors are super simple and super easy to tear apart and put back together.
I’m ok with what I did. It’s just frustrating.
I’m going to the movies with my wife to see Ford vs Ferrari. I am also building a 1968 Ford GT40 and it’s in my garage next to my motorcycle. That will take my mind off of me being so stupid.
Thanks Adam, you are 100% correct. This isn’t a big deal, just a set back.
2016 Ducati Xdiavel
Norcoastal #790289 11/16/19 11:12 pm
I think a repair would be more straight forward than getting new cases. From what I can see the area would be easy to weld although you might need to grind down the inside so as to allow the welder full access to the area that needs to be built up. I am assuming that the broken bolt has been drilled out.
I think that this is the bolt and hole you are talking about.
The hole is enlarged for the first bit to allow for the dowel which helps to position the inner cover the is threaded for the bolt.
This is the dowel that positions the inner cover
Once welded up the face of the case would need to be dressed flat with surface. For drilling and threading you can use the inner cover hole to establish the center of the new hole.
Good luck
