kevin
kevin
Rating: 4
A65 Fork Tubes
#789716 11/10/19 6:21 pm
mrcarb Offline OP
Hello All,
should the top of the fork tubes on a 69 A65 be even with the top of the triple tree?
Thank you in advance
Re: A65 Fork Tubes
mrcarb #789724 11/10/19 8:04 pm
Depends if the taper of the tube was machined the correct length.
Generally, they do not come up "even" with the top of the top fork yoke.
Re: A65 Fork Tubes
mrcarb #789728 11/10/19 8:20 pm
mrcarb Offline OP
Than you Irish Swede. Mine are about .1" (2.5mm) below and cannot get them to come up any further. The reason for removing them was to replace the gaiters. I wonder if they are in far enough and if they will leak.
Re: A65 Fork Tubes
mrcarb #789729 11/10/19 8:43 pm
That must stop before reaching the top, this is to ensure they engage with the taper fully and the assembly is rigid.
Re: A65 Fork Tubes
mrcarb #789760 11/11/19 12:45 am
what Komando said ..........the top nut has to bear/lock on the fork yoke NOT the stanchion
having said that 1" below flush on the top yoke does sound excessive .........not a whole lot of taper will actually be engaged with that gap .........are u sure they are the right stanchions?
Re: A65 Fork Tubes
mrcarb #789772 11/11/19 3:16 am
mrcarb Offline OP
I am reasonably certain that they are the right stanchions. They are .1" below and not 1" below. What Kommando says makes good sense. I am hoping that they will not leak near the top.
Thank you all for your replies.
Re: A65 Fork Tubes
mrcarb #789776 11/11/19 3:36 am
Use thread sealant between the top nuts and the stanchions.
0.1" is fine--as Kommando says you don't want the stanchions to come right up to the top of the yokes (triple trees).
Re: A65 Fork Tubes
mrcarb #789806 11/11/19 3:09 pm
If you have used a fork pulling tool and the taper on the yoke isn't full of paint then there shouldn't be any issues.
Re: A65 Fork Tubes
mrcarb #789834 11/11/19 6:28 pm
i misread it as 1' not POINT 1 " (usually written 0.1 ) the decimal point is practically invisible on new *hit monitors.
but yep 0.1" is fine, sorry for confusion.
