Dave - NV
Dave - NV
Elko, Nevada USA
Page 2 of 2 1 2
Re: Front brake suggestions requested
David Dunfey #786141 10/03/19 11:02 am
Chip205 Offline OP
Originally Posted by David Dunfey
John,
I think that Chip was saying that he chose the wrong lining application,
Just so. Or perhaps I didn't know enough at the time to request what I wanted. I've little experience with drum brakes on street bikes. All I ever did, on cars and bikes, was mount new shoes -- and I've never had a street bike with a front drum after my first bike, a Yamaha DT1 250 (48 yrs riding and counting). Back then, when I had those vehicles, new shoes were readily available. The only time I ever had shoes relined was on my Bultaco and Montesa trials bikes ('70's). And then a friend swore Model T linings worked better than stock. He was right.
Chip205. '61 Clubman's Gold Star, '13 Daytona 675 R, '13 Duke 690, '18 Street Triple 765 RS, '20 R1250R
Chip205 #786144 10/03/19 11:50 am
Chip205 Offline OP
Ummm...(sheepish look)...except for the Gold Star which I rode a fair bit in the '70's. I remember the front brake being fine.
Chip205 #789066 11/03/19 8:44 pm
Hi, I have an RGS with the 190mm brake. When I went through this bike in 2012 I ground the shoes on a jig I made which held the shoes set at a controlled diameter. Following some advice I found on the internet I ground them to be .005" smaller then the drum. Ever since this brake has been about the best bike drum brake I have ever experienced (more than matching a an 8 inch BSA 1/2 width brake with old Ferodo green linings). Two fingers can lock the wheel if you wish. Being 1LS it is not grabby and holds the bike well on uphill T junctions. The shoes on this brake are very wide and I feel that grinding or careful turning of the shoes really does matter. I have ground or turned quite a few sets of lining on British brakes and providing its done so that there are not untoward stresses on the brakeplate when doing it, it reliably makes a good brake. The jig has a threaded rod that you can adjust to pull the brake on. The jig also matches the ID of the brake plate hole closely and mounts between centres so you can take the assembly out partway through if you feel the need. You do need to be able to set the diameter fairly accurately - I use a 12 inch digital caliper. Grinding is the best way to remove lining material but a SHARP EDGED carbide tool can also work well (HSS does not last well). Before starting I cover the lathe chuck with a close fitting polythene bag and use dampened newspaper to cover the bedways and use fairly light passes. I generally believe that BSA knew how to make good things and if you fettle what they provided, you can usually get better results than you might expect. HTH,
Jon
Chip205 #789068 11/03/19 9:16 pm
I fitted a Robinson replica 4LS It is very powerful but controllable too, I bought it from JL in Czech Republic https://www.jl-exhausts.com/robinson-230mm-4ls-front-brake-1999-p.asp
[Linked Image from live.staticflickr.com]20170908_145323 by Sigma Projects, on Flickr
Chip205 #789069 11/03/19 9:18 pm
Chip205 #789533 11/08/19 8:47 pm
This was my solution to improving the stopping department, It works very well, but the down side being it is quite heavy. I did weigh it at the time, but didn't record the figure.
It probably weigh more than Andy's Robinson. That's a nice looking bike.
Brian
Made In England
Chip205 #789564 11/09/19 6:23 am
I've admired DBDBrian's doubled-up brake before, in the flesh - at East Kirkby, I think, for the Wolds Run. Some attention to detail there - notably the mirroring of the back plate, with the drain hole repositioned, etc.
He must think it works ok - given the fitting of the security bolt!
Oliver Wendell Holmes
Chip205 #789619 11/09/19 8:18 pm
Wheelies shouldn't be an issue with that set up :-)
Chip205 #789636 11/09/19 10:57 pm
Yes Kerry, our paths did cross at the Wolds run, but unfortunately we did not meet, lets hope some time in the future.
I fitted two security bolts, as the holes were in the rim. I was glad I also have two in the rear wheel , as it deflated a bit sharpish last summer when I picked up this through the tyre.
Andy, I don't think Clubmans Goldie's were renowned wheelies, unfortunately I think I maybe well past trying. 😊
Brian
Made In England
Chip205 #789727 11/10/19 8:20 pm
That's a great mod Brian, and I'm left wondering how you managed to join the two hubs together? I guess the original left hand small spoke spool would have been turned off with a lathe and then the two brake drums were carefully welded together ensuring they were Concentric. I was also wondering if there is any issue with the left hand drum being more efficient than the original right hand drum given that the left lever orientation is now different?
Based on the original question on front drum brakes and how to improve them here are my thoughts:-
- what's has not been mentioned so far is the type of cable used and its routing. I've recently started using Venhill brake cables which have a Teflon inner lining and have noticed a marked improvement in brake performance. I believe the Teflon lining reduces frictional loss when the handlebar lever is pulled and therefore increases the pull on the brake drum lever. Additionally its important to check that the cable has no sharp curves or bends as these also cause frictional losses.
- another thing to check is the handlebar brake lever pivot length, this is then length measured between the lever pivot and brake cable nipple. Many levers have a pivot length of 1-1/16 inch and a improvement can be found by using a lever which uses 7/8 inch pivot as the mechanical advantage is greater.
I've recently made the above changes to my B44 front brake which uses an 8 inch SLS brake with floating shoes. The front brake is now much better than previous and it almost feels like the front wheel could lock up in an emergency braking situation, certainly much better than before.
Chip205 #789737 11/10/19 9:38 pm
A trick I have seen for vintage racing where the rules prevent external linkages on the brake.
An abutment for the trailing shoe is fitted next to the cam and the existing abutment is removed and a floating one installed. This effectively makes both shoes into a long leading shoe with a hinge in the middle
Chip205 #789833 11/11/19 6:25 pm
Thanks Gunner, In answer to your question, the original spoke flange is pressed into the drum, I made a centre shouldered sleeve, which carries both drums.
I have attached a couple of mock up drawings of the hub / spindle arrangement.
Re the L/H lever / cam operation, the effect is the same, as the drum is rotating anti-clock viewed from the plate.
I have considered TLS plates, which a mate will CNC machine from billets. The drawing / programme for the plates still needs a little tweaking before making a start, but other commitments keep getting in the way, and then of course there is the extra weight to consider.
Front face
[Linked Image from i.postimg.cc]up images
Rear face
This is the R/H plate, the programme only need reversing for the L/H version
[Linked Image from i.postimg.cc]upload a photo and get url
I have two billets ready
Yes, good cables and there alignment play a big part in brake performance, the gold star clip-ons use the short 7/8" pivot levers.
Brian
Made In England
Chip205 #789894 11/12/19 3:54 am
Yes I've heard about this mod which I believe is called the Bendix Duo-Servo self-energizing concept, a description of this mod can be found in the Victory Library at This Link near the end of the page. Looks like the cam has to be ground so that only the lower lobe is present and the pivot bolt removed so the shoes can float freely. Seems like a good idea and worth a try.
Thanks Brian I didn't know the smaller spool was pressed on using a sleeve, so joining the two drums together using a new sleeve would be relatively easy. Presumably the position of the new drum relative to the rim had to be considered so that the spokes would fit.
Page 2 of 2 1 2
