celtrock
celtrock
4 volt coils for Trident
#789436 11/07/19 5:00 pm
Has anyone had any experience using 4 volt coils on their Trident? A friend installed them on his '74 T150 which he has upgraded with an electric starter and he says the bike has no power. He says that the electric start circuit is somehow interfering with the 4 volt coils. He installed a set of 6 volt coils and they worked fine. The bike has a Trispark electronic ignition. Any thoughts?
reliccycles.com
Re: 4 volt coils for Trident
Curmudgeon #789439 11/07/19 5:19 pm
Which Tri-Spark?
Black box or Classic Triple?
However, neither is intended to be used with 4V coils.
https://www.trispark.com.au/black-box-triple-ignition
"Required accessories if using 6-volt coils
Ballast resistor (required when using 6-volt coils);
Recommended accessories
12V Tri-Spark high performance coils - 3 required (no ballast resistor required – cleaner installation); IGC-1012"
https://tri-spark.neto.com.au/assets/files/TRI-0001%20manual%20V3.pdf
"Installation for 6 volt coils
The installation with 6 volt coils is slightly different than for 12 volt coils. You will need to install a ballast resistor as shown in the wiring diagrams. The ballast resistor can be the same type as used on a T160 or equivalent automotive type so long as it is 1.6Ohms. We can supply a ballast resistor ordered separately."
https://www.trispark.com.au/Classic-Triple-for-Trident-and-Rocket-3
"Compatible with cylindrical 12 volt coils (6 volt coils if a ballast resistor is fitted)."
https://tri-spark.neto.com.au/assets/files/Classic%20Triple%20V2.pdf
"Ignition coil compatibility:
Tri-Spark IGC-1012 (12 volt) coils are recommended 3.5 Ohm Primary resistance Note: 6 volt coils (typ. 1.8 ohm primary) may be used with a ballast resistor(1.6 Ohm). 4 volt coils are not recommended. Use of other than the recommended coils will damage the stator unit."
L.A.B. #789446 11/07/19 7:25 pm
its like lab said .
with
the underlying reason being the trispark is not a wasted spark type ignition .
the design asks for ;
3 -12v coils ,
or 3- 6volts coils... with a 1.6 ohm ballast resistor .
the 4 volt coils may have been fine for another type of ignition ... a wasted spark type
( Maybe the previous igniton before the trispark was added )
You could probably fit an appropriate ballast resistor to make 4 volt coils work
... but trisPark , in some of their literature
Specifically mentions not to do so .
... the 4v. coils were too hot ( not enough resistance ) for the ignition dwell time and voltage
... somewhere in the 8 millisecond range x 12 volts .
it wasnt the starter motor causing the problem ... the coils were overheating .
the Trispark ignition is not of the wasted Spark type
so each coil fires only one cylinder ... 3 individual pick up signals
fire three coils ... individually .
trispark recommends .
3 , 6volt coils with one ,,, 1.6 ohms ballast resistor [Linked Image from trispark.com.au]
Is there a ballast resistor fitted... its important .
or
3 , 12volt coils ... with not ballast .
( they also recommend that if a ballast resistor is fitted ...for 6 volt coil operation .
it not be bypassed during start mode ... (the original diagram with a starter used a solenoid bypass )
i would assume
the 6volt coils with ballast ... would be a bettter match ... to an engine with a starter .
the literature mentions being good down to 8 volts , but i wonder ?
Curmudgeon #789470 11/08/19 12:01 am
Thanks so much for this very useful information guys. I will pass it on to my friend.
Happy B-Day Morgan!
reliccycles.com
Curmudgeon #789485 11/08/19 9:19 am
This is a typical example of us reading or hearing something without engaging the brain and try to understand the essence of what we read or hear. It happens on occasion, though I try my best...
A typical example was an owner asking me this week to replace the Lucas 6v coils on his Boyer Bransden equipped Commando with a dual coil 12v item. When I asked why, these coils rarely fail, what are you aiming to accomplish, the answer was simply that somebody had told him it was a good idea, with no further reasoning.
Curmudgeon #789552 11/09/19 2:55 am
Back in the '80s I bought a Lucas Rita for my T150V. The kit came with three 4V coils. You don't suppose that Lucas actually knew something about their system, and their customers?
DavidP #790601 11/19/19 6:59 pm
The OP asked about 4V coils on a TriSpark ignition. That would clearly be wrong, as explained by others.
I agree that 4V with a RITA is the way to go. I have those on my Trident, and on my R3 back in in 90s.
SR
Moderated by  Tridentman
