celtrock
celtrock
BSA or Triumph Rob North
#787520 10/19/19 8:46 pm
Something about the lines of Rob North Triumphs has always bothered me, the angles of engine, frame and exhaust all clash badly. The BSA versions have the cylinders parallel to the front tubes and the exhausts
Re: BSA or Triumph Rob North
Andy Higham #787522 10/19/19 9:10 pm
I thought they were racers.
Andy Higham #787523 10/19/19 9:24 pm
They are, and the BSA looks better
Andy Higham #787634 10/20/19 10:07 pm
It is not the frame, it is the T150. It looks like a 1939 speed twin with another cylinder added on.
I think it was CZ that had the frame loop around the gearbox first. However, what North missed on the frame is the bracing of the headstock. Rickman had the bracing better with the lower end of the headstock braced by a single tube against the top tube cross brace forming a partial triangle.
Something more along these lines on the North would have been better:
The inverted J tubes on the North adds little strength to the headstock flexing backward.
Andy Higham #787699 10/21/19 1:23 pm
The bottom frame looks really nice DM.
I modified a stock '70 A65 frame years ago. Running the two loops up to the steering head and used a crossbar between them to fit the stock brace like the Rickman. The engine was still too far back and even a longer swing arm didn't fix the handling. It was alright but could shake it's head under power on bumps.
Andy Higham #787731 10/21/19 6:54 pm
Was this previous to your RGV bike? You must spend a lot of time modifying things.
This is the previous version of the aluminum Wenco frame:
It has a 1" wider swingarm pivot for more modern tyres and the V brace for the seat rails at the back of the tank. The steel frame seat rails flex quite a bit and they are welded to the mainframe.
I have to work more on the swingarm brace as it hits the shock diagonal tubes at full compression. I already moved the attachment point from directly behind the swingarm pivot to further up the loop. I need room for a K181 130-18 dirt track tyre.
Andy Higham #787740 10/21/19 8:29 pm
RPM Offline
The Rob North triples were race bikes and graceful lines were not as important as the overall function of the bike. Rickman triples are worse than Rickman twins when it comes to steering one of them. Rickman road race frame have too much rake and wheelbase. At the time the Rickman frames were designed tires were still not that good. The long rake combined with the tradtional sweeping race lines of the time they worked okay but soon after they came out tires started getting much better allowing for less rake and more load on the front tire. As tires got better the "point and shoot" style of riding became the fast way around the track.
I can see DMadigan has the rake pulled back on the frame in the photo. Also the swingarm angle looks better than a Rickman.
Andy Higham #787744 10/21/19 9:26 pm
I had a T150v for many years from about '77. It ended up 880cc with bug bore 3 into 1, big valves and 32mm dellorto carbs. It ended up in an early VFR frame. It went really well. The A65 has better power and is lighter and better handling, with better brakes. I would have loved a Rob North frame for it.
Mark Parker #787782 10/22/19 2:35 am
I remember the Trident at the Empire Strikes Back. Was in a Japanese alloy frame....I guess it was the VFR?
Mark Parker #788011 10/24/19 10:52 am
The A65 had better power than the 880 Trident? Am I alone in wondering what was wrong with the triple?
Andy Higham #788019 10/24/19 11:37 am
The main thing wrong with the triples is the same thing that is wrong with just about every bike from BSA/Triumph/Norton/RE etc from mid sixties onwards, outdated designs and under developed.
Yes there were some good bikes but there could have been some really great bikes
Andy Higham #788020 10/24/19 11:39 am
The road bikes should have used a derivative of the Rob North frame
Tigernuts #788083 10/25/19 1:38 am
Marks A65 is a very powerful machine...……….
http://www.britbike.com/forums/ubbthreads.php/topics/773092/1/exhaust-pipes
http://www.britbike.com/forums/ubbthreads.php/topics/782021/1/the-what-if-a65-67hp-challenge
If ever I bought an A65 I would want his engine setup or similar.
Andy Higham #788088 10/25/19 3:32 am
The oil in frame bikes was a change to address induction noise for meeting noise standards. It made room for bigger and quieter air intakes. The Rob North frames could have given the same thing, but they were unorthodox, meaning odd looking to some, or exotic to others. Personally I think it was a big mistake building the T160 when it would have been possible to build an 860 Rob North triple instead. A bike able to directly compete with the Z900 and Ducati SS750/900. Even a limited number could have been effective. Café racers were becoming more widely popular and these things would have been the business.
Mark Parker #788089 10/25/19 4:03 am
Many of us wondered the same thing. Norton built the JPS bikes, why didn't Triumph build a Slippery Sam replica for the US market? The North frame actually cost less to build than the stock frame.
Judging from the last issue of Triple Echo, most of the T160s ended up back in England after they didn't sell here.
Andy Higham #788121 10/25/19 9:05 am
A lot of JPN's got left in the showrooms and only 200 were built so that would have played a part in no factory Slippery Sam replicas being made.
Andy Higham #788122 10/25/19 9:35 am
I think it was a mistake to build the T160 as a 750cc...…...I think that building it as a classic bike was no big problem, most other bikes on the market were similarly presented [Honda, Kawasaki, Suzuki, Yamaha and they sold heaps] except for some Italian bikes like Ducati, Laverda SFC and Guzzi Le Mans etc but at that stage they were not big sellers.
And in the day, you added ace bars and rear sets and you were a café racer, or high Z bars and you were a cruiser, or wide flat bars and you were a tourer etc etc, it really was that simple in that era.
Triumph could have offered variations [similar to what we have today with the Speedmaster, Thruxton and Bonneville etc], but I think this type of thinking was in the early conceptual stage and still some way off.
But they did miss the mark by not making it an 850 or 1000cc. But its all 'water under the bridge', most of it tears from all us tragics smile
tridentt150v #788440 10/28/19 12:14 pm
Thanks for those links - an amazing machine and an incredible feat of tuning. I've posted a couple of questions on one of the threads for Mark, as this has got me curious. I forgot to ask whether the 97 BHP achieved was on straight petrol or other fuel.
Andy Higham #788445 10/28/19 2:48 pm
"why didn't Triumph build a Slippery Sam replica for the US market?" - americans like choppers which is why we got the Hurricane with peanut tank and extended forks. Same reason we never got the "Home Market" tank on the twins.
Andy Higham #788492 10/28/19 11:58 pm
I read Slippery Sam used modified stock frame, not a Rob North frame like racers.
Hurricanes didn't sell and I'm sure S.S, replicas wouldn't sell either, OHC / DOHC engines with electric starters on paper sold better than performance in real life.
Remember my own reaction on first reading about Trident "what OHV engine with a kick starter?
Forget it."
And on the street they always look shoddy with oily, dirty looking engines and those strange looking mufflers rusting away.
So all the available money was spent on these nice, glittering and never braking Japanese bikes.
Andy Higham #788521 10/29/19 8:50 am
Slippery Sam was entered in Production classes, so had to have a standard frame.
Moderated by  Tridentman
