Mike-71-650
Mike-71-650
Al, Birmingham
Bill Walker, Phil McClusky, 1957 Road Rocket, Payne, Mysticbus
11018 Registered Users
franko 135
koan58 67
DavidP 61
1,149,071 mail-order LSR
Topics68,948
Posts690,993
Members11,017
48 registered members (AML), 1,881 guests, and 805 spiders.
Dynamic Balancing shops? #786255 10/05/19 1:54 am
Andrew Dunham Offline OP
I'm coming up on the reassembly of my 61' BSA Super Rocket rebuilt, but I have opted for some more modern bits and would like to have the crank assembly dynamically balanced. MAP cycle connecting rods and GPM pistons.
Does anyone know if a good shop to have this done in the US? In particular, near Ohio would be great.
1961 BSA Super Rocket
1968 BSA A50
1969 BSA 441 VS
1970 BSA Thunderbolt
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786279 10/05/19 12:14 pm
Al Eckstadt Offline
Could possibly find someone here in Central New York State. There are a few excellent shops that specialize in Brit bikes. I would have to ask about dynamic balancing.
Al Eckstadt
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786288 10/05/19 1:41 pm
Dick Harris Offline
Mcquillen machine shop in Leroy New York has done several Triumph cranks for me, including my 76 degree crank done many years ago. Dick
Re: Dynamic Balancing shops? [Re: Dick Harris] #786353 10/06/19 12:33 pm
Hillbilly bike Offline
McQuillen was recomended to me by Dick Harris....The shop balanced two of my race engines and one 750 kitted 650 and a bunch of machine work..McQuillen has state of the art machining equipment and people who know how to use it...They will not tell you what balance factor to use..That's your decision...
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786354 10/06/19 12:40 pm
MikeG Offline
I used these guys to do my A10 a few years ago:
http://www.lindskog.com/
One thing I noticed after it was done is that the vibrations are still there, just at a different frequency and RPM range. Where I used to get a lot of handlebar buzz from about 1/4 throttle on, getting worse as RPM climbed, it's now more pronounced in the seat and footpegs and not as harsh. The worst of it does not start till the RPMs are much higher-no tachometer so its just a seat of the pants guess.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
(Used to be a Triumph here)
71 Norton Commando
17 Triumph Bonneville
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786369 10/06/19 4:30 pm
bodine031 Offline
Ed G Cranks offsetcranks.com 416-347-6936 TIOC vendor
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786402 10/06/19 11:40 pm
Thanks for all the responses everyone. This gets me plenty of options for when I get close to having it done. I am waiting on my new pistons, then they have to go to the machinist to bore the cylinders out. Then I can send it all out for balancing.
MikeG, that makes perfect sense. I know next to nothing about crankshaft balancing at the moment, but learning all the time. It seems like the whole purpose of the dynamic balance is to get the engine to run smoothly at whatever your desired RPM range is. That will be a bit tricky because I only managed 3 miles on this bike before deciding to check the sludge trap and tear the engine down, so I have no idea what RPM is 60-65 mph!
I may have to take a trip up to NY state and talk to McQuillen. That looks like quite the operation.
1968 BSA A50
1969 BSA 441 VS
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786416 10/07/19 12:58 am
Shane in Oz Online Content
You can work that out from the sprocket tooth counts and rear wheel circumference, but it's typically around 3,500 - 4,000 rpm.
How many teeth on:
a/ crankshaft sprocket
b/ clutch chain wheel
c/ gearbox sprocket
d/ rear wheel sprocket
I assume it has a 19" rear wheel, and probably a 3.50 or 4.00 rear tyre.
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786418 10/07/19 1:11 am
9
99cyclone Offline
One of the best, and specialized in vintage British bikes...
http://richtermachining.com/
Buells and Brit Bikes
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786419 10/07/19 1:13 am
Jerry Roy Offline
Since you are in a learning mode, you might find this helpful;
https://www.bing.com/videos/search?...50AB2E38620FF21AA6FB50AB2E&FORM=VIRE
Or, BING "how to figure speed from gear ratio", and spend an hour or two going through the sites until you find something that you can use to figure your speed at whatever RPM you want to cruise at, or vice versa.
You will need to know what ratio your transmission uses for top gear, so if you don't want to take the tranny apart and count teeth, look in a good manual, and see if you can find a chart with the ratios.
Most will have a 1 to 1 top gear ratio.
You can work the math starting from the rear wheel, after figuring out how fast it is turning at your cruising speed. (60 MPH = 1 M/ min. 5280 Ft divided by your rear wheel circumference in feet will tell you the RPM of the wheel at 60 MPH.)
Have fun. crazy
JR
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786443 10/07/19 9:17 am
Douglass Harroun Offline
http://www.countrysidecycle.net/engines.htm
did very good job on my Triumph 650/ almost no vibes anywhere
Doug
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786498 10/07/19 8:08 pm
JubeePrince Offline
Born To Run
Born To Run
John Healy has always spoken highly about this shop:
https://www.memphismotorwerks.com/
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786501 10/07/19 8:28 pm
John Healy Offline
Steve this is not the type of work they do
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786517 10/08/19 12:34 am
JubeePrince Offline
Born To Run
Born To Run
They stick to strictly valve and head work then?
Re: Dynamic Balancing shops? [Re: Andrew Dunham] #786684 10/10/19 2:44 am
Thanks everyone. I contacted Richter and they seem confident like they could do the job well. I'll pursue that route a little further and see how it goes.
1968 BSA A50
1969 BSA 441 VS
Re: Dynamic Balancing shops? [Re: JubeePrince] #786698 10/10/19 11:43 am
Ask Kevin Roberts on this site...he sent in a head and it's been over a year, maybe two years and they didn't get to it..There are a few others with similar stories..
Re: Dynamic Balancing shops? [Re: Hillbilly bike] #786792 10/11/19 1:37 pm
JubeePrince Offline
Born To Run
Born To Run
Wow.....he (MMW) must be spending too much time playing bass guitar!
