swooshdave
swooshdave
Portland, Oregon
3 into 1 flat spot
#784830 09/20/19 7:09 am
DavidP Offline OP
I'm no racer, but I figured you guys might have some experience with this.
'72 Trident with some sort of 3 into 1 header, not sure who made it. 180 main jets on stock Amals.
In any case, I got a rough spot between 4 and 5000 rpm. I can accelerate through it, but at steady rpm it kinda sounds like a racing two stroke, coughs and spits.
Is this just the nature of the beast? Reversion?
Re: 3 into 1 flat spot
DavidP #784842 09/20/19 1:47 pm
David, if it has a fairly big bore system you can get reversion, but you also get top end power. Typically you open the throttle and it goes pa pa pa pa, no power, then WAAAAAAAAAAAAAA, lots of power. If that's what it does a lighter throttle through the reversion may prevent it. If that's what it is there are a couple of anti reversion things you can try at the headers as well. Big headers have lower gas speed and it needs the speed to draw the inlet charge in and reversion happens when the intake air does not have enough speed and energy to carry the air into the cyl against the rising piston pushing it back out before the inlet valve closes.
Mark Parker #784844 09/20/19 1:57 pm
I got the same symptoms on the A65 by retarding the cam (probably too much) never fully cured it. well not least till I advance the cam again
DavidP #784855 09/20/19 4:43 pm
Easiest solution I believe is adapting a Supertrap muffler... Change the number of discs until the problem is minimised or gone....I had a 3-1 on a 73 Trident many years ago with bad reversion like you mention...I added one inch balance pipes beteween the three primary pipes about one foot from the head, no more reversion traded for a barely noticable loss of top end power.
DavidP #784881 09/20/19 8:20 pm
David,
I know you are on the Triples Online site as well. On that site someone was having problems with a similar flat spot. Turned out the alternator output was interfering with the electronic ignition impulses. Was discovered by taking a test run with the alternator disconnected. You might want to try that to make sure you don't have the same problem.
Ed from NJ
edunham #785162 09/23/19 2:50 am
DavidP Offline OP
Originally Posted by edunham
David,
Ed from NJ
I guess that's worth a try. The alternator wires are routed as stock. When I installed the Trispark I ran the pickup wires out the front of the case, along the bottom frame member under the engine, and up the down tube to the black box, mounted where the tool tray should be. The alternator wires run up the opposite side of the down tube, but are not tied to it. In any case, that puts them in parallel at a distance of about 3". I suppose I could separate the alternator wires from the loom and reroute them behind the oil tank.
For the rest of you, the pipes are 1.5" OD and join the collector under the center of the timing cover, about 29" from the valves.
DavidP #785184 09/23/19 11:44 am
That sounds like a drag race pipe. The Supertrapp would be a good answer. But, you did not provide much info about your problem. 4-5k no load, light load, going up an easy hill, full throttle? Maybe just a carb tuning issue.
DavidP #785279 09/24/19 2:20 am
DavidP Offline OP
The length of the collector/megaphone is 30.5", so total length from valves to exit is 59". Mega flairs to 3" with gases exiting through a 1" hole. Pictures in this thread: http://www.britbike.com/forums/ubbthreads.php/topics/782387/anyone-recognise-this-header#Post782387
The problem occurs at light load, constant speed, maybe 1/4 throttle. I did a plug chop and got no deposits. Went to 107 needle jets and got some color on the plugs, but the problem persists. I'll be installing the chokes next time the carbs are off, maybe they'll help diagnosing the problem.
Ed: I just happened to have a pair of alternator wires in my stash of old wiring. I ran these straight back and up the frame tube behind the oil tank, well away from the trigger wires. Gotta finish rebuilding the clutch before I can ride again though.
DavidP #785327 09/24/19 3:44 pm
From the photo,the pipe is likely too long and causing reversion.
DavidP #785691 09/28/19 5:31 am
I've run similar to that. I removed the centre stand and took the centre pipe to the left of the frame tube with all pipes angled to the left with the collector angling back to the right well up under the engine because it gets close to the ground. I had various tail sections with glass packed muffler because they frown on open Megaphones on the road here. No other pipes gave the same power. The factory were open 4" from memory. The things are much better at 850cc with 30 or 32mm carbs. Depending what you are looking for.
DavidP #785700 09/28/19 11:19 am
This photo circa 1980 shows the 3-1 on my 74 Trident..short primaries with the balance tubes and a glasspack muffler...On the street the engine was stronger to about 7000 rpm..The longer pipe felt better at top end...Depends how you ride I suppose..But after my recent experience with Supertrapp mufflers I believe it's best option for street exhaust tuning.
DavidP #785704 09/28/19 1:09 pm
RPM Offline
I have never seen a triple use 107 needle jets. All the 1000cc bikes and factory triples I have worked on have used 106 jets.
Did you check the jets with a gauge? I would check some 106 jets to make sure they are the correct size and try them.
DavidP #785860 09/30/19 6:00 am
DavidP Offline OP
I'm NOT a bloody machinist! I don't own a complete set of pin gauges just to check that parts bought from reputable suppliers are made to spec. Perhaps even current production jets are made with the same WW1 era production equipment used to make these bikes in the first place?!?
I have used 107 needle jets in past on a Trident with different exhaust. All I know in this case is that I did a plug chop at 1/3 throttle and got NO deposits on the plug, much less a "mixture ring" at the base of the porcelain, with new genuine Amal106 needle jets.
DavidP #785883 09/30/19 1:59 pm
RPM Offline
I checked 4 needle jets on two T140 last week. Of the 4 jets 1 checked good, 2 were worn to 107 and 1 of the jets marked 106 the 105 gauge would barely slide in. I check every needle jet I pull from a carb and every new jet I install or sell. Yes I have seen new jets that checked bad.
Gauges can be had for around 25 dollars for the 105/106 combination gauge.
RPM #786271 10/05/19 9:17 am
I am the same with the ones I fit and sell. Often if the needle jet is over tightened it will be enough to reduce the size of the needle jet from say a 106 to a 105. It’s good practice to check the jet post fitted into the jet holder.
DavidP #786961 10/13/19 3:51 am
A bigger motor will help remove reversion as it increases gas speed through the head. But also, I was reading last night, that a cure for reversion was increased compression ratio. Reversion is related to gas speed and apparently higher compression, that has that crisper exhaust sound, also delivers more velocity into the exhaust gas helping the gas go forward through the engine rather than back the wrong way.
DavidP #786973 10/13/19 11:54 am
True Mark. Everything matters. PRT
DavidP #787198 10/16/19 4:51 am
DavidP Offline OP
No plans to increase displacement nor to fit 11:1 pistons.
Perhaps if the problem persists I will cut the pipe and install a Supertrapp silencer.
DavidP #787209 10/16/19 9:49 am
The shorter 4 inch style like this one are often on eBay. 1-3/4 is a popular size.....Not a Trident but 12 discs for initial tuning works well for most ...Nice sound also...I didn't like the look but it grows on you
DavidP #787252 10/16/19 8:33 pm
Rather than speculate, why not book a dyno session
Andy Higham #787256 10/16/19 9:49 pm
From my expereince with my race bike reversion and hours spent on the dyno.. I believe reversion on a street bike is better deal with by road testing especially if you only have access to an interia dyno..My opinion ..
Hillbilly bike #787358 10/18/19 3:01 am
DavidP Offline OP
Looking at their catalog I see two which would work if I can get the mount welded in the right spot.
The pipe from the collector to the meg on mine is 1.5" OD and 7.875" between welds.
The other consideration is clearance for the kick start. As it is my heel brushes the meg when I kick, just enough to scrape the paint.
BTW: The end cap is missing. I don't suppose this would have much effect, or would it?
DavidP #790333 11/17/19 2:41 pm
I have a Hyde 3 into 1 on my 74. Runs nice with no flat spots.Able to use the center stand. There is a fabricator in Houston, Tx called Jemco. They have been in business for years making 2 stroke expansion chambers. They have a minimal web site. Tho you can communicate with them. They might be able to help you out in making something you need. Like a collector or a set of head pipes.
DavidP #791338 11/26/19 5:34 am
DavidP Offline OP
After reading several posts about reading plugs I see that it usually takes several runs for any color to show on the plugs. So, I put the 106 jets back in. I also moved the needle clip to the top groove. Book says second groove, but I think the T160 used the top groove.
Took the bike out for a ride today, and no sign of the flat spot. A slight bit of popping on trailing throttle, but much better. Pulls smoothly out to 7K and runs smoothly at 4K.
DavidP #791360 11/26/19 12:37 pm
Good deal...so all you did was change the neele jet and neelde position? Apparently it was to rich...When properly reading plugs it should be done with new plugs if the old ones are dark from rich running...Need about 15 miles to get a good reading at part Throttle...Wide open through the gear up tp about 90 mph may give an adequate full power reading if you know what look for on the plug...And don't use the charts from online because most are from leaded gas days. Healy posted plug reading sticky in the BSA forum.
Moderated by  Allan G
