royaloilfield
royaloilfield
Trenton, New Jersey
Alton Genorator without battery?
#784163 09/13/19 3:32 pm
Manx Offline OP
Helo folks,
I`m at the final stages of my rebuild on a Bsa B33 and a little confused.
I have bought a BTH 12v magdyno and this runs without the need for a battery.
I also have an Alton ac generator which came with a Podtronics 200W regulator/rectifier.
Alton do not recomend that I run the Alton without a battery but I am a little confused as to why?
I have to run daytime running lights and the Alton only gives out 90w and a peak max @ 150w so my confusion is why can`t I run without a battery like I do on my 2 strokes that run directly from the stator through a regulator to the lights?
1966 Rickman Metisse (a65)
1957 B33
1959 lambretta li 150
1960 lambretta li150
Re: Alton Genorator without battery?
Manx #784207 09/13/19 10:50 pm
You can run without a battery, the advice is probably given for people who have a coil ignition system.
Then the bike would be quite hard to start without a battery.
Just be aware your lights will dim at idle, i don't know what the coppers will think of that.
Manx #784241 09/14/19 10:03 am
you will want a capacitor in place or swap the pod tronics for a Boyer power box.
With no connection to a resistive source the Alton will over heat, causing the grease to run out of the bearings, you’ll only know because it will be howling, despite still charging.
The battery wire broke on my friends bike causing this issue, it would be similar to running without a battery at all.
Manx #784242 09/14/19 10:19 am
Your lights will go out at idle rpm, not just dim, unless your Alton is different from mine.
I don’t get the story about the Alton burning out because there was no battery. When the battery is fully charged, there is virtually zero DC current going anywhere from the regulator, so what would be different, were there no battery in place?
Altons have a long history of failing for any reason or no reason, so it’s hard to prove either way.
triton thrasher #784246 09/14/19 11:35 am
You have had trouble with them? What goes bad?
Hillbilly bike #784249 09/14/19 12:31 pm
I had a 3-phase version, which stopped charging. I sent it back and (eventually) got a replacement, which was single phase and with a reduction gear. It’s been fine, although it’s not properly made to fit a Triumph.
If you google Alton alternator, many of the results will be about failures and slow-going dealings with the maker.
Manx #784250 09/14/19 12:55 pm
Why do some people become obsessed about running without a battery?
Allan G #784300 09/14/19 11:55 pm
When a pod or a powerbox or any shunt regulator is controlling a pm alternator the shunting
does not present any greater load to the stator than running around 60% of maximum capacity.
The stator will warm up but will not be overloaded, it is like running the stator with the 2 or 3 output
wires twisted together, it will not harm the stator. Contrary to popular belief, it also does not present
a significantly greater mechanical load either. (Not with these old primitive ones anyway.)
Placing a capacitor in place of the battery would aid the starting of a coil ignition bike, it does not
really do anything else.
I tend to agree with Andy, these days a tiny battery can be stowed somewhere so easily and the
lights will work all the time.
NickL #784367 09/15/19 7:42 pm
Manx Offline OP
Ok. I can play by the book and add a small lipo battery.
On my 2 strokes the lights dim but are actually very good at speed.
If the lights will completely fade at a standstill, then that's not a good thing.
1957 B33
Manx #784374 09/15/19 8:33 pm
Will that work better or worse than a lead acid battery?
Don’t do anything for our sake. Try it with no battery if you like.
Manx #784439 09/16/19 4:40 am
Manx Offline OP
A ran a lithium battery in my A65. They keep their charge really well and are small/light.
I have fit a scrambles single seat and the standard battery carrier doesn't fit.
As I mentioned before, I run without the battery on my 2 strokes which do dim at a standstill but if they will almost turn off with the Alton, then I will need a battery.
1957 B33
Moderated by  Jon W. Whitley
