Graham Ham
Graham Ham
South East England
T140 TS low compression
#783776 09/08/19 3:28 pm
Dr. Z Offline OP
I finally got the T140 running, but with a top speed of only 80 mph, so the first step was a compression check. The drive side cylinder was about 110 psi with 60 psi on the timing side. Next a quick check with a few cc's of oil in the TS cylinder gave 100 psi indicating a ring problem. After removing the cylinder barrel the only difference I noticed was a scuff mark on the TS piston,
At this point I will do a cylinder hone with new rings, but I have some concern about this mark.
Does this mark tell me anything about why the compression was low?
The mark feels smooth and both cylinders look good, so is it safe to use the same pistons?
Craig Zaspel
T100R
BSA A10
Re: T140 TS low compression
Dr. Z #783777 09/08/19 3:43 pm
Check that the rings aren’t sticky in their grooves.
Dr. Z #783828 09/09/19 2:55 am
Also what exhaust are you using...…...I can remember having a Trident with pattern Campbells mufflers that wouldn't do over 80....replaced with more open sports type mufflers and the same bike did over 110 mph easily [maybe could have got more, but didn't try]. Plus just felt more powerful all round.
If your bores measure up OK, using that piston again [with new rings] would be fine.
triton thrasher #783832 09/09/19 4:14 am
Dr. Z Offline OP
Thanks TT I will check that with the new rings.
Tridentt150v: I have short reverse cones with baffles on 2 inch exhaust pipes. The bores measured up OK at 40 over.
Thanks for the replies.
Craig Zaspel
T100R
BSA A10
Dr. Z #783833 09/09/19 5:58 am
I had Unity short reverse cones that were restrictive.
The simple test is to try the bike with no silencers.
Dr. Z #783842 09/09/19 11:37 am
Agreed re trying without silencers. I had Campbells megaphone shaped silencers on a T140 I bought once. Utterly gutless and would not go over 80. I took them off and it was as if it was supercharged, in comparison.
Dr. Z #783852 09/09/19 3:41 pm
I don't think the mufflers are the problem when has 60 psi compression in one cylinder.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2018 Kawasaki Z900RS
Dr. Z #783954 09/11/19 2:53 am
Dr. Z Offline OP
I will post the results when I get new rings, with and without silencers.
Craig Zaspel
T100R
BSA A10
Dr. Z #783969 09/11/19 10:39 am
Flip the head over and pour the CHamber full of lacquer thinner and see if it ends up in the ports, If so you also have a valve issue! I have seen lots that the piston scuffed like that and the comp wasnt much if any lower, I bet you have a valve issue. Prob some trash between the valve and seat. Good luck
Dr. Z #783970 09/11/19 10:48 am
Not sure if these were new rings or original, but if rings don't do the job of taking heat out of the piston, and transferring it to the cylinder wall you will get piston pick up.
What does the gudgeon/wrist pin look like? Any colouring on it?
I probably wouldn't worry about that scuff, but that's just me.
Dr. Z #784001 09/11/19 7:54 pm
Dr. Z Offline OP
JakeH, thinner stays in place with no sign of a leak.
Gringe, The pistons are 0.040 over, but I have no idea when it was rebored. Also the wrist pins look OK, and I will not worry about the scuff.
My long term plan for this is to make a 76 degree engine as a retirement project if I can retire. As Kent Shaun would say, "that is a big IF"
Craig Zaspel
T100R
BSA A10
Dr. Z #785160 09/23/19 2:33 am
Dr. Z Offline OP
New rings solved the compression problem. I have in the meantime noticed that the carbs only open to 3/4 instead of full throttle, so that is the next thing to work on. I have not yet tried TT's suggestion to run without silencers.
Craig Zaspel
T100R
BSA A10
Dr. Z #785174 09/23/19 7:51 am
If you take the silencers off wouldn't you have to increase the length of the pipes?
Dr. Z #785177 09/23/19 9:31 am
If the throttles don’t open, that will slow you down.
dave jones #785178 09/23/19 9:34 am
I don’t think it matters. They don’t have very scientific exhaust systems.
Dr. Z #785202 09/23/19 2:53 pm
I still don't get what taking the silencers off will prove. His problem was low compression which he has obviously solved. Ride it and enjoy it.
1974 Trident
htown #785210 09/23/19 3:51 pm
It will prove very noisy.
Dr. Z #785224 09/23/19 5:55 pm
Dr. Z Offline OP
It is fast and loud enough with silencers; moreover, my wife and neighbors would not like me running without silencers
Craig Zaspel
T100R
BSA A10
