Tribsauk
Tribsauk
Death row next in line norfolk
Phil McClusky, 1957 Road Rocket, Payne, Mysticbus, T140v
11017 Registered Users
franko 136
koan58 69
DavidP 61
1,148,972 mail-order LSR
Topics68,940
Posts690,948
Members11,017
80 registered members (1957 Road Rocket), 2,224 guests, and 824 spiders.
New Amals already worn #783724 09/07/19 9:09 pm
Danam Online Content OP
OP Online Content
I recently purchased a new set of AMAL 626 carbs. I put them on and took a 50 mile ride, they worked great! Afterwards, I removed the slides and saw they look really scuffed. (See photo:
https://drive.google.com/file/d/1yi6LM_BT3_rzbxLI7KdNkAJIihkrJh6a/view?usp=sharing
What I'm concerned about, is if they look like this after only 50 miles, what are they going to look like after 500 miles? 5000 miles?
Re: New Amals already worn [Re: Danam] #783725 09/07/19 9:15 pm
kommando Online Content
They do not look like the anodised slides but the old ones cast in the same material as the body, they will last about 5000 miles and take the body with rhem. You also look as if you are not running air filters. So add air filters and get some new anodised slides and fit them before the bodies wear out.
Re: New Amals already worn [Re: Danam] #783726 09/07/19 9:17 pm
Allan Gill Online Happy
1) what were they like when fitted?
2) where did you get them from?
3) are you running air filters?
4) is there any chance the carb bodies are over tightened causing tighter clearances between slide and carb body?
I’ve ran open mouths on my carbs for a few years and never seen slide wear like that.
Re: New Amals already worn [Re: Danam] #783727 09/07/19 9:26 pm
OP Online Content
I was running velocity stacks, but it’s not like I was riding in dirt
Re: New Amals already worn [Re: Allan Gill] #783728 09/07/19 9:37 pm
OP Online Content
I got them new from Lowbrow Customs. I was sure not to over tighten the mounts.
Re: New Amals already worn [Re: Danam] #783744 09/08/19 1:22 am
NickL Offline
You don't need to be riding on dirt to get enough debris and crap in the inlets to score the slides and bodies.
Fit filters, it's worth it. Anodised slides are good but fit filters first.
Re: New Amals already worn [Re: Danam] #783750 09/08/19 2:12 am
DavidP Online Content
New slides on my T150. I had the carbs apart after maybe 70 miles and they showed a bit of wear even using the stock air filter.
But, these are in the old carb bodies.
Re: New Amals already worn [Re: Danam] #783760 09/08/19 8:35 am
BSA_WM20 Online Content
Unless the body was not finished properly & deburred then.
Each & every vertial scratch is a grain of grit that has wedged itself between the slide & the body.
If you want to use stacks then you have to accept the wear.
They are items specifically designed for racing where new carbs 3 times a year is SOP.
If you want to get an idea of just ho much junk is in the air then wet a white hanky and leave it sitting along sode a rod for a few hours.
It won't stay white for very long.
Re: New Amals already worn [Re: Danam] #783806 09/08/19 11:05 pm
koan58 Offline
They do wear heavily, but at 50 miles that is exceptional, and also the scratches being severe and from the very top, does suggest a certain lack of cleanliness on assembly.
I'd suggest thorough flushing with fuel or solvent, while rubbing the bearing surfaces very gently with something like fine wire wool to remove any embedded abrasive particles.
Also flush the rest of the carb parts, especially the underside of the top. It looks like muck was already in there, or has been drawn through the cable entries.
Wear usually shows as smoothish areas, that is grit.
Re: New Amals already worn [Re: Danam] #783809 09/08/19 11:44 pm
W
Wilfred Offline
W
Way back in the fifties, when scrambling on the Clipper, I smeared grease around the carb bell to see how much grit it would catch. At the end of the day, I'm sure I could have ground in the valves with what came off the bell......and that was in the winter when there wasn't much if any dust on the track. The 930 on the T100 had the rebore and brass sleeve 25 years ago and has had an air cleaner with regular filter changes ever since and is still working fine. Well over 30,000 road miles.
Cheers, Wilf
"It's about the ride..."
Re: New Amals already worn [Re: Danam] #783820 09/09/19 1:49 am
OP Online Content
Filters on order !!
Re: New Amals already worn [Re: Danam] #783839 09/09/19 11:18 am
Id order some hard anodised slides too.
Re: New Amals already worn [Re: Danam] #783861 09/09/19 5:59 pm
Andy Higham Online Content
The only metal that can be used on both parts of a sliding or rotating metal to metal bearing is cast iron
Re: New Amals already worn [Re: Andy Higham] #783900 09/10/19 10:28 am
The zinc on zinc is fine if the bike is used at least on day a week.
When they were designed tthe bikes were daily transport.
The zinc oxadizes and the zinc oxide is quite porous and adsorbs some fuel vapour which keeps it lubricated.
Only when they sit unused for months and over cleaned that the slides stick.
Just about all of the leaded copper base alloys are fine running against each other.
