Redman
Redman
San Francisco
Bill Walker, Phil McClusky, 1957 Road Rocket, Payne, Mysticbus
11018 Registered Users
franko 134
koan58 69
DavidP 63
reverb 50
1,149,412 mail-order LSR
Topics68,959
Posts691,096
Members11,018
37 registered members (Allan Gill), 2,049 guests, and 910 spiders.
Rating: 3
T10 GP2 Jet Block removal #783240 09/01/19 10:32 pm
Cali Kid Offline OP
I am about to rebuild the AMAL T10 GP2 carbs that came with my 1966 Spitfire. I have all the replacement parts and gaskets in hand. But I would like to make sure I understand the right way to remove the jet block so I can put the new gasket under it. I have the carb all apart and have removed all screws from the body. It looks like I could tap the bottom of the jet block with some thin dowels through the two screw holes on the bottom of the carb body. I tried this approach with some light tapping, but the jet blocks didn't budge. I didn't want to pound any harder in fear of breaking something. I read a thread for monoblocks where folks had heated up their carb in order to get the jet block out. Not sure if that's what is needed here or not. Any guidance in helping me understand the right way to get the jet blocks out is appreciated.
Re: T10 GP2 Jet Block removal [Re: Cali Kid] #783264 09/02/19 10:27 am
Blueboy Offline
I did this recently by warming the body with a hot air gun and then tapping a rod through the screw holes underneath bit by bit and alternating the hole.
The block is a very tight fit so care is needed to keep it moving squarely, and I ended up with slight damage to the threads, which was easily fixed by running a tap down them(2BA I think they were).
If I was doing it again I think I would make up some long shouldered screws and use them to drift it out.
Just a bit of advice.....it is not easy to get the block back in and aligned perfectly with the Venturi as there is no location peg or screw as on a Monobloc ...compounded by the tight fit of the two parts, I spent a lot of time on mine and I still don’t think it’s as well aligned as it was before I started......and I only had one to do!
Re: T10 GP2 Jet Block removal [Re: Blueboy] #783394 09/04/19 1:36 am
Cali Kid Offline OP
Thanks Blueboy. I'm glad to hear I was on the right track. Did you try any 3-in-1 oil or similar lubricant too or just the heat? I like the idea of the long shouldered screws to drift them out. If I can't find any I'll try a wood or plastic dowel to tap them out.
Re: T10 GP2 Jet Block removal [Re: Cali Kid] #783685 09/07/19 3:19 pm
Cali Kid Offline OP
I have successfully removed the two jet blocks by putting the carbs on my BBQ grill at ~90 C (200 F) for 5 mins with lid down. I used a bamboo chopstick narrowed down to fit into the jet block bolt holes. Then just did the same process as Blueboy recommend (tapping alternately between holes until out. Note I did put some 3-in-1 oil around the edge of the jet block post heating. This seemed help a bit. Now on to cleaning and reassembly.
Oh it looks like the jet-block gaskets may have been originally secured on with some kink of adhesive. Not sure but it looks that way. Could just be 53 years of dirt I suppose. Any thoughts on this is appreciated.
