Kerry W
Kerry W
Middle East,
Jim Harding, Ronjsmith, larrys, Derek Krilow, John finn
10984 Registered Users
franko 80
NickL 58
DavidP 58
1,114,289 mail-order LSR
Topics68,618
Posts688,302
Members10,984
26 registered members (998John), 3,551 guests, and 919 spiders.
Trident oil pressure #781982 08/20/19 12:16 am
Curmudgeon Offline OP
Just installed a oil pressure gauge and it reads 80psi at idle, cold oil. Rev up the engine and gauge stops at 100psi so that's what the OPRV is set at. This seems a bit high to me and I'm wondering what you guys think. Thanks.
reliccycles.com
Re: Trident oil pressure [Re: Curmudgeon] #781984 08/20/19 12:24 am
Jerry Roy Offline
Warm the oil up to 180 deg F or so, and then check the pressure at idle and 4000 RPM.
That will tell you how the clearances are.
Re: Trident oil pressure [Re: Curmudgeon] #782010 08/20/19 4:15 am
I just installed the gauge from Triples Unlimited. Cold oil gives me 95psi. I was also surprised to see 80psi at close to idle with cold oil.
After yesterday's 20 mile ride the reading was 60psi at 4000rpm, 80psi at 6000rpm, and a little under 20psi at idle before I shut it off.
Oil temperature measured in the oil tank was 190 degrees when I got home. I have a thermostat on the oil cooler.
BTW: The Trident OPR valve is supposed to open at 75psi.
Re: Trident oil pressure [Re: Curmudgeon] #782013 08/20/19 4:41 am
tridentt150v Offline
That's normal, as David said, settles when warm.
Re: Trident oil pressure [Re: Curmudgeon] #782037 08/20/19 1:31 pm
DMadigan Offline
My factory manual gives "Pressure release operates 90 PSI" for the OPRV. Presumably when the valve starts to open so final pressure depends upon the flow.
Re: Trident oil pressure [Re: Curmudgeon] #782050 08/20/19 4:37 pm
Adam M. Offline
It's normal on the cold oil.
David P - your hot oil pressure figures are exactly like mine.
