Les P
Les P
1972 Commando Rear Wheel RH Spacer Length ?
#780665 08/06/19 1:10 am
I need to know the length of the RH spacer measurement before I possibly - needlessly order one ?
1971 BSA A65 650 - Project
Re: 1972 Commando Rear Wheel RH Spacer Length ?
Jon W. Whitley #780687 08/06/19 4:10 am
A 73 850 is 1 & 3/8" there, with a non-precision ruler as the measuring device !
A 72 would be the same.? the parts books would confirm this.
This is with the speedo drive in place and correctly located, such that tightening
the axle locks the speedo drive at the appropriate angle for the speedo cable.
You can always use a stack of suitable washers to emulate the spacer, this is a surprisingly
precise way of figuring out what the spacer length(s) should be.
Rohan #780769 08/07/19 12:26 am
Yes, according to the parts books, '72 and '73 would be the same. Thanks for the measurement specs.
Jon W. Whitley #781001 08/09/19 10:33 am
well yes and no,if you search the forum its seems to vary as was pointed out about 4 yrs ago.im the original owner of my 850 mk1.the rear wheel ALWAYS was a real pain in the ass to install. finally after reading the discussion here i took it to a machinist and had it turned down about an 1/8''.cant remember exactly but it solved the problem..in the back and forth it was unclear whether the variation was the wheel width as seen by the axle or some variation in the swingarm width between the drop outs.as i wasnt the only one that knew about this issue,i suspect it may be more common than you think.my bike is also a '73
jaycee #781054 08/10/19 12:07 am
You had the spacer turned down an 1/8" ? Also, do you have the link for that conversation ?
Jon W. Whitley #781058 08/10/19 12:42 am
Don't know the link(s), but there has been a lot of chit chat that the swingarm widths
do vary a bit - whether this is in manufacturing or subsequent flexing. And this certainly
does make refitting the wheel sometimes a bit of a muscle exercise. Make sure the
speedo drive is correctly located though...
Which is why I suggested the stack of washers to find a suitable length of spacer...
Jon W. Whitley #781074 08/10/19 3:34 am
thats about right as i recall,seems the sane way out was to machine the spacer to fit properly once it was determined that all was assembled properly in the first place. no i dont know how to access it as the search function here and me dont get along.i said this, as although you didnt say, you JUST MIGHT be enjoying the same drama as myself. you could do as others have suggested and stack some washer's and have one made out of stainless bar stock and then of course be done with it.
jaycee #781147 08/11/19 12:16 am
that's about right as i recall,seems the sane way out was to machine the spacer to fit properly once it was determined that all was assembled properly in the first place. no i don't know how to access it as the search function here and me don't get along.i said this, as although you didn't say, you JUST MIGHT be enjoying the same drama as myself. you could do as others have suggested and stack some washer's and have one made out of stainless bar stock and then of course be done with it.
Good info and thank you both. Since I was able to determine that I definitely didn't have this spacer in my collection of parts, I ordered the spacer, 06-0324, so we shall see how it fits when it gets here.
Moderated by  Dave Comeau
