Jeff Covert
Jeff Covert
Benton, AR USA
Carl Courson, Roddy Walsh, Mark Creighton, Alex Lynch, B Mac
10777 Registered Users
franko 129
NickL 62
DavidP 56
MarcB 52
949,843 mail-order LSR
Topics67,516
Posts675,799
Members10,777
65 registered members (Al Eckstadt), 409 guests, and 727 spiders.
A question for Victor owners #780761 08/06/19 11:14 pm
MartinBuilt Online Content OP
OP Online Content
I'm putting together a mostly '68 Victor Special.
I've been picking up parts here and there, whenever i have a couple bucks.
Last week, I bought a QD rear, and just figured out it's a 19" wheel.( I was told it was an 18, and didn't check.)
Is there enough room for it?
I could go for a smaller tire, like a 3.50, if the diameter is a problem.
I think the scrambles c15s had a 19"rear wheel, but I don't know if any of the b44 models did.
Thanks, in advance.
Re: A question for Victor owners [Re: MartinBuilt] #780763 08/06/19 11:47 pm
The 68 VS lists a 400x18 Gold Seal a road tire. I have a 450X18 Knobby on a 69 VS and there is room to spare. However I do not have a chainguard so the side knobs are not a problem.
Even with the Knobby tire there is still more than 1/2 inch to spare at the front. Even more to the stock rear fender. Given that a 19 is only 1/2 more on the radius than the 18 tire I would think you would be ok wiht a road 400x19. You could measure the outside diameter of possible tires to see where the mid point would be in the swingarm.
This is the rear clearance.
Here is the front clearance to the swingarm cross bit.
Do you have a part number for the rim? If it is not for a VS wheel the rim offset might not be correct.
Re: A question for Victor owners [Re: Gordo in Comox] #780770 08/07/19 12:28 am
OP Online Content
Crap, I hadn't considered the offset.
I'll have to scrub it and see what the number says.
I think it might be an A7 Jones.
Re: A question for Victor owners [Re: MartinBuilt] #780777 08/07/19 3:16 am
Steve Erickson Online Content
Also check to see if the splines align on the QD, they weren't all the same.
Re: A question for Victor owners [Re: MartinBuilt] #780831 08/07/19 4:46 pm
C.B.S Offline
Parts Dealer
Parts Dealer
If it's a 19" it sounds like it came off the early Lightning / Thunderbolt Rocket models that had a 19" rear
I'm running a Shinko SR241 on my '65 B40 Enduro Star, I gad to "Clearance" the tire to prevent chain-guard rub
Re: A question for Victor owners [Re: MartinBuilt] #780840 08/07/19 7:07 pm
Allan Gill Online Happy
Or a pre 57 a/b series
Re: A question for Victor owners [Re: C.B.S] #780854 08/07/19 9:55 pm
OP Online Content
i have those tires here, waiting for my cub to emerge from it's boxes...
did you go 4.00, or 3.50?
I still have to look for numbers, and try to figure out what this wheel was on. No grease nipple, no speedo drive, splines mate up to the brake-plate/stub.
I have the rupert books, so i can probably check the offset against his numbers. I was going to put alloy fenders on it to save weight, so that at least shouldn't be a problem.
Re: A question for Victor owners [Re: MartinBuilt] #780858 08/07/19 10:25 pm
Martin: By no speedo drive do you mean there are no threads to accept the drive? If so that would mean it was made for a model that drove the speedo from the gearbox.
This photo shows a preunit wheel with no speedo drive threads. Missing is the pressed on tin cover to protect the bearing. Is this what you have?
(Yes I know the spokes are not tightened up)
Re: A question for Victor owners [Re: Gordo in Comox] #780864 08/07/19 11:40 pm
OP Online Content
i'm guessing yes.
i found a rim stamp WM2 19, but nothing visable on the hub. I would guess it's offset about 3/8" from center.
missing a couple spokes, both on the splined side, if anyone has some rattling around.
if it can be used, i might.
The proportions are good. I have a half-hub front wheel off an earlier bike that I'm hoping to use. It's got a 19"rim laced to it as well.
Re: A question for Victor owners [Re: MartinBuilt] #780867 08/08/19 12:16 am
bodine031 Offline
I have a 69 B-44VS since 198I set it up back then as a dirt bike off road only. The rear has a 4.60x18 ching-ching knobby with plenty of room. Tsubaki nickle plated 530 chain, Boyer EI, Kuni 30mm round slide, Tympanium reg/rect, Bikemaster gel electrolyte ytx-4 battery. Takes vibration better than any other type I have tried. MAP oil filter kit, Valvoline VR-1 60wt. Ford old style ATF for the primary and 90wt gear oil in trans. Honda dirt bike drum brake front end. Bike is a friggin blast to ride.
Re: A question for Victor owners [Re: MartinBuilt] #780871 08/08/19 12:46 am
Martin. Great. Your first photo shows the speed drive so it is a later wheel, not like mine above. It should work if you have a speedo drive unit to put onto it. Be careful if you try to take the speedo drive off. Some are LH and a few are RH threads. There should be a LH stamped somewhere, maybe on the hub, to give you a clue which way to turn it.
Re: A question for Victor owners [Re: MartinBuilt] #780877 08/08/19 2:33 am
WM2, as I recall was intended for 3.50 width max, anything wider went to WM3.
Re: A question for Victor owners [Re: MartinBuilt] #780879 08/08/19 2:44 am
C.B.S Offline
Parts Dealer
Parts Dealer
I'm running a 4.00 X 18 Shinko SR241 (rear) and 3.50 on the front
On my Enduro Star (C15C Frame) I had to make room on the rear, and the front barley fits
