old PJ
old PJ
Royal Berkshire
Carl Courson, Roddy Walsh, Mark Creighton, Alex Lynch, B Mac
10777 Registered Users
franko 129
NickL 62
DavidP 56
MarcB 52
949,843 mail-order LSR
Topics67,516
Posts675,799
Members10,777
72 registered members (Al Eckstadt), 427 guests, and 764 spiders.
'71 Lightning wiring routes #780461 08/03/19 8:32 pm
Scott56 Online Content OP
OP Online Content
I'm working on a '71 Lightning. Someone completely botched the wiring, ripped out the stock wiring harness and mickey-moused it so it would run but nothing else worked. I bought new main and headlight harnesses from Feked, but can't find any photos online of what a correctly installed harness should look like. I'm starting at the headlight, my question is this - is the entire headlight harness intended to end up in the headlight, except the wires to the front brake and oil pressure switches? I thought all the wiring from the handlebar switches would connect in there, but it seems kinda crowded for that. Or do the handlebar leads and connections to the main harness take place outside the headlight? Anyone got a pic?
Any help appreciated.
Scott in Maine
1960 A7, future project
Trying to get a friend's A65 running.....
Re: '71 Lightning wiring routes [Re: Scott56] #780482 08/03/19 11:59 pm
gavin eisler Offline
The bar switches join the main loom behind the headstock under the main tube.
The headlamp bucket has two holes for wiring , i pass the instrument light wires through the upper hole.
Re: '71 Lightning wiring routes [Re: gavin eisler] #780495 08/04/19 4:07 am
quinten Online Content
HandleBar wires . [Linked Image]
Headlight harness . [Linked Image]
Pics and write up snagged from ; https://www.bsaownersclub.co.uk/bsaoc_forum/index.php?topic=3177.0
Re: '71 Lightning wiring routes [Re: Scott56] #780506 08/04/19 8:03 am
BSA_WM20 Offline
Not only does the insulation pull back from the terminal exposing bare wire but the tubes ( females ) crack and the PVC outer sheath shrinkf from the heat so it is impossible to remove a wire without stripping the bullets off the wires.
If you look at the preliminary design drawings there was a B50 style electrics box included which was obviously deleted in production thus you end up withtat unholey mess.
Apart from that the colours fade so you have no idea which light coloured wires go where.
Then you get lots of oil fume ( from the breather ) so they get hot, & oily .
If you are going to keep it stock, get a fat push bike inner tube or a 125 motorcycle tube and slide all of the wires into it then tie off the ends.
Don't forget liberal amounts of contact grease to the terminals before assembly.
Re: '71 Lightning wiring routes [Re: Scott56] #780514 08/04/19 10:34 am
OP Online Content
Thank you! Very helpful, now I can press on....
Scott in Maine
Re: '71 Lightning wiring routes [Re: Scott56] #781773 08/17/19 8:41 pm
OP Online Content
So, I have the wiring harness complete, but I have some issues. I hooked up the battery to check lights, horn, turn signals, etc., and I have none of them. The oil pressure light comes on and the tail-light comes on. The oil pressure light dims when I turn the ignition switch to the second position to turn on the lights, but no action. It also makes some faint buzzing noise in the vicinity of the battery, zener diode or rectifier? Flasher box?
I took the left-hand handlebar switch apart, and there's continuity (like 2 ohms resistance) between the white at the ignition switch and the white at the handlebar switch. This is power to the switch, right? There's also continuity for the three light wires (UW, UR and U) between the switch and the connections in the headlight, so the loom connections are good. Same with purple for the horn. But curiously, inside the handlebar switch, there's no continuity (or lousy, like 50 ohms) between the white wire and the three light wires no matter what position the high/low beam switch or the ignition switch is in. Am I looking in the wrong place for a problem?
I pulled the entire wiring harness off and installed the main and headlight harness and a new ignition switch from Feked. So the only original wires left are from these handlebar switches. Any help appreciated...
Scott in Maine
Re: '71 Lightning wiring routes [Re: Scott56] #781820 08/18/19 3:42 am
Pull the white wire to the flasher and see what happens.
Re: '71 Lightning wiring routes [Re: Scott56] #781825 08/18/19 7:54 am
Allan Gill Online Happy
The wires for the lights will come from the main switch, not the white/white and yellow wires.
2 ohms is also quite poor is measured across the switch, assuming you have zero ohms when the 2 probes of the multimeter are touched.
Re: '71 Lightning wiring routes [Re: Scott56] #782015 9 hours ago
The white wire to the RH bar switch only supplies the horn and main-beam flash push buttons. The 'hot' lead for the lights is blue. Make sure that the rotating switch in the headlight shell is on. You say that the tail light is on, so you have voltage at the Brown/green wire. The switch in the shell connects the brown/green to the blue for the headlight.
Re: '71 Lightning wiring routes [Re: Scott56] #782035 1 hour ago
OP Online Content
Quinten - the flasher is bad, when I pulled the white wire the buzzing went away and I got the tail-light to work.
Allan Gill - the white wire goes to both handlebar switches, the oil pressure switch and light and through the front brake switch back to the stoplight, originating from the ignition switch. I assumed this white wire was hot to all these things powered through the handlebar switches when the key is in the second position (lights on, running). When you say 'main switch', are you talking about the switch on the headlight? I thought that just turned on and off the pilot light.
DavidP - hmm, the blue goes from the handlebar switch to the headlight switch and then to the pilot light. Are you saying somehow this gets back to powering the headlights? I don't see the connection on the wiring diagram.
The pilot light is the one thing I don't have installed because I'm waiting for the part.
Thanks for responses.
Scott in Maine
