marinatlas
marinatlas
FRANCE- DINARD -BRITTANY
Loop, Filthy pup, Kevin Victor, Soupdragon, Gabby
10738 Registered Users
franko 121
reverb 53
DavidP 51
924,933 mail-order LSR
Topics67,180
Posts673,252
Members10,738
50 registered members (Allan Gill), 289 guests, and 851 spiders.
Page 2 of 2 1 2
Re: pre-monoblock 101 [Re: John Healy] #778418
07/11/19 10:00 pm
07/11/19 10:00 pm
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Rohan: It is in small writing easily overlooked at the bottom of the page.
It is also on a page that is not easily found by their search engine.
I think you have completely missed my point John,
given that I QUOTED that small text in a previous post !!
P.S. I don''t know how I posted something 3 times, now fixed.
PPS Why have we diverged into Monoblocs. ?
Fuel density could be the reason for those 3 notches, I'm not sure if replies are directed at this ??
Would alcohol fuel require a different float setting ?
Re: pre-monoblock 101 [Re: Richrd] #778450
07/12/19 9:35 am
07/12/19 9:35 am
West Yorkshire
Allan Gill Online happy
Allan Gill  Online Happy
West Yorkshire
Gasoline should be around the sg of 0.71 to 0.76, distilled water would have an sg of 1.0 (or 0.9982 to be more precice at 15*c), white spirit, diesel, and many solvents will have an sg of around 0.80 (methanol is 0.972) Thus us if you set your float height up using water or solvent, and use the liquid level to set the seat height, then soon as you switch to the lower density gasoline the float will sit more into the fuel thus the fuel level will be higher in the bowl, although not by a massive amout between methanol and gasoline.
Re: pre-monoblock 101 [Re: Richrd] #778463
07/12/19 1:07 pm
07/12/19 1:07 pm
John Healy Offline
John Healy  Offline
Yes, I changed the post.
Re: pre-monoblock 101 [Re: John Healy] #778503
07/12/19 10:23 pm
07/12/19 10:23 pm
West Yorkshire
West Yorkshire
No worries, I was hoping that I'd over looked something. I've removed mine as it serves no purpose.
Re: pre-monoblock 101 [Re: Richrd] #778531
07/13/19 6:11 am
07/13/19 6:11 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Another float needle with multiple notches.
(and imperfect focus...)
Although obviously not the same as previous.
I'm starting to wonder if this is an undocumented feature, rather than homemade modifications ?
Re: pre-monoblock 101 [Re: Richrd] #778686
07/15/19 3:17 am
07/15/19 3:17 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Something else I see which can vary is the different heights of collars(arrowed) under the mixing chamber.
This would rather alter the fuel height inside.
Anyone know how/why this may be, I'd think the carb on the right would be impossible to operate as is.
Would a different form of float bowl be required ? or ....
Re: pre-monoblock 101 [Re: Richrd] #778736
07/15/19 7:17 pm
07/15/19 7:17 pm
Springfield Nebraska
Richrd Online content OP
Richrd  Online Content OP
thanks for all this info.
the reason for the original post is that we are working on a rapide with new carbs and some problems. It ran great with Concentrics.
but with the new carbs there is a big stubble at 1/2 to 3/4 throttle, right where you'd expect the mains to be kicking in. Paul tried raising the needles but that makes it worse across the board.
and one carb does like to leak out the bottom.
Rich (last remaining member ThreeMustGetBeers)
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: pre-monoblock 101 [Re: Richrd] #778738
07/15/19 8:09 pm
07/15/19 8:09 pm
West Yorkshire
West Yorkshire
That leak could be the problem. Or do you have the correct float bowls for the cylinder they are being fitted to?
Re: pre-monoblock 101 [Re: Richrd] #778751
07/15/19 10:34 pm
07/15/19 10:34 pm
Magnetoman Online content
Magnetoman  Online Content
Based on too little information I'll go out on a limb and say your main jets are too large, causing the stumble because it is too rich, and raising the needle was the wrong thing to do since it only made it richer in the 1/2-3/4 range, which is before you'd expect the main jets to be kicking in. Along with this, either the float level of one carburetor is too high or, if the leak really is coming from the bottom and not just collecting there, the gasket at the bottom is leaking.
Page 2 of 2 1 2
