SmoothPierre
SmoothPierre
South Lincolnshire, UK
drilled drums
#778401 07/11/19 7:26 pm
Novice poster
Novice poster
https://s1378.photobucket.com/user/...949s_zps8qnofkay.jpg.html?sort=3&o=1
https://s1378.photobucket.com/user/...950s_zpsquu4r43n.jpg.html?sort=3&o=0
"nothing lighter than a hole" apparently, so bought a 1 1/2" HSS carbide tipped hole cutter especially for the job. but on centre punching the first indent (of 6) on the inside of the SLS drum on my BSA A65, a cap just popped out - so i guess the easy provision for some extra fresh air was already built in??? weighing the 6 caps = 10.4 grams so not much of a diet there.
added some budgie mesh to keep critters out.
on to the rear
https://s1378.photobucket.com/user/...944s_zpsgm7u2kh1.jpg.html?sort=3&o=8
https://s1378.photobucket.com/user/...938s_zpskum4njdp.jpg.html?sort=3&o=9
the area available on the rear is smaller so i was planing on smaller holes. no indents on the rear so i made a template with 6 holes marked equidistant between the spline bolts. again, bought a brand new drill, fully expecting to burn it out on the cast iron. centre punched, then starting with a 4mm drill as a guide hole, i was surprised to have it bore straight through with little effort. jumping to the next size(s) up i noticed the metal wasn't producing the expected pasta curls of swarf but odd chips. the depth of the hole/thickness of the vertical face of the drum is only 5mm (the front is 7mm) but i expected a tougher material. it almost feels/looks like bakelite with a few iron filings thrown it just to make it metallic.
so finally my question: what is the rear drum of a 1966 BSA A65 made of?
i'm not confident to drill the now 14mm holes any bigger for fear of weakening the structure.
Re: drilled drums
betty plava #778416 07/11/19 9:46 pm
Could be cast steel, Norton Commandos rear brake hubs are cast steel. You can use a grind test on a piece to tell you if it's iron or steel.
https://en.m.wikipedia.org/wiki/Spark_testing
Moderated by  GrandPaul
