Topics68,247
Posts684,781
Members10,938
Most Online14,755 May 5th, 2019
53 registered members (Al Eckstadt),
488
guests, and 909
spiders. |
Key:
Admin,
Global Mod,
Mod
Which pipes for my '57 6T?
#776639
06/17/19 5:17 am
HawaiianTiger
Posts: 6,596 |
I've been studying the pipes available for my 6T but I can't seem to find out if I can get a set of 1 1/2 inch pipes for it. The Bonnie and T110 pipes for 58-59 are 1 1/2 but those bikes are generator equipped bikes and the alternator bikes need a bigger dip on the left to clear the larger primary cases. Also, I've seen 58-59 6T's with 1 1/2 pipes but I don't know whether they are stock or are from another model. Any info on this would be greatly appreciated. I'm tempted to get a set for 60-62 bikes on the hope that they will fit.....but it's kind of risky...
Cheers, Bill
Re: Which pipes for my '57 6T?
[Re: HawaiianTiger]
#776649
06/17/19 10:06 am
Ginge
Posts: 824 |
'57 wasn't the first alternator bike was it? ..... and yours would still be pre-unit. Anything from an earlier Thunderbird available? Otherwise eBay a ratty set of dynamo bike pipes and bend them to suit. Then get then fabricated in stainless perhaps.
'51 C11 in a '54 C10L frame..."The Bantam Eater" '70 Triumph Trophy 500. Bottom end rumble awaiting diagnosis '72 Triumph Tiger 650. Back on the road...
[Re: HawaiianTiger]
#776656
06/17/19 12:32 pm
Irish Swede
Posts: 3,279 |
Thunderbirds had alternators beginning in 1952.
Exhaust pipes on 1950s Triumphs were all 1-3/4" size until the necked-down 'performance' pipes were added to T110 models in 1958. Those pipes were 1-3/4" at the exhaust port and muffler, but 1-1/2" between those two points.
This was intended to have a "venturi effect" to speed the exhaust flow. I guess it works, because all Triumph pipes since then have been made this way.
[Re: Irish Swede]
#776665
06/17/19 2:11 pm
triton thrasher
Posts: 8,001 |
This was intended to have a "venturi effect" to speed the exhaust flow. I guess it works, because all Triumph pipes since then have been made this way. The narrower pipes would (approximately) continue the inside diameter of the head stubs.
[Re: HawaiianTiger]
#776681
06/17/19 6:48 pm
HawaiianTiger
Posts: 6,596 |
Yes, that this is why I would like to switch to 1 1/2 pipes. However, I can't seem to find out if the T110/T120 pipes would fit. I suspect not, which leaves me to experimentation and possible waste of money. Cheers, Bill
[Re: HawaiianTiger]
#776683
06/17/19 7:40 pm
triton thrasher
Posts: 8,001 |
Part of your problem is there are suppliers who will sell you pipes for an alternator Bonneville that don’t even fit an alternator Bonneville, never mind an older Thunderbird.
[Re: triton thrasher]
#776697
06/17/19 9:39 pm
HawaiianTiger
Posts: 6,596 |
[Re: HawaiianTiger]
#776711
06/17/19 11:59 pm
Posts: 3,307 |
Who is the go to Triumph exhaust pipe supplier? I need a set of the 1 1/2" pipes for my '59 T110.
[Re: HawaiianTiger]
#776715
06/18/19 12:27 am
Jon W. Whitley
Posts: 6,204 |
Bill,
I'm running later Unit pipes on my '57 6T and I didn't notice any problems in clearance and fit.
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
[Re: Jon W. Whitley]
#776724
06/18/19 2:01 am
HawaiianTiger
Posts: 6,596 |
Yes! Thanks Jon! Cheers, Bill
[Re: HawaiianTiger]
#776805
06/19/19 12:06 am
Jon W. Whitley
Posts: 6,204 |
Yes! Thanks Jon! Cheers, Bill You are welcome Bill ! I'll wheel it out in the next day or two and snap some pics for you.
