Google advert
BRIT-FE
BRIT-FE
Lorton, VA
Bill Davis, DGreear, KevKav, Joe B, tobbe53
10732 Registered Users
franko 121
DavidP 57
Rohan 52
reverb 48
920,615 mail-order LSR
Topics67,120
Posts672,713
Members10,732
43 registered members (AndyB), 328 guests, and 929 spiders.
ign question #776231
06/12/19 12:02 pm
06/12/19 12:02 pm
Orlando fla/ shady valley Tn
bill50cal Online content OP
bill50cal  Online Content OP
who on here has experience with the Boyer micro power or micro digital ign. systems and what if any issues or positives with it.
windy
72 combat
switchbackcreek.com
Re: ign question [Re: bill50cal] #776240
06/12/19 2:03 pm
06/12/19 2:03 pm
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
Not a British bike (a BMW R75/7) but the Micro-Digital was noticeably better than the Boyer MkIII unit it replaced and is still working what must be about 25 years later.
Re: ign question [Re: bill50cal] #776250
06/12/19 5:13 pm
06/12/19 5:13 pm
kommando Offline
kommando  Offline
I have 2 bikes with the Red box Micro-digital, both run well, boxes must be 20 odd years old. The idle stabilisation is good at making sure the bike does not stall when stopping for red lights etc. There is a significant difference in timing between boxes so as soon as its fitted on the default timing strobe and adjust.
Re: ign question [Re: bill50cal] #776420
06/14/19 3:19 pm
06/14/19 3:19 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Windy I put my 2 cents on the BB MK-4 today down on the Triumph section. I'm satisfied with the product
Re: ign question [Re: bodine031] #776490
06/15/19 12:31 pm
06/15/19 12:31 pm
thanks for the answer BUT the MK4 is not the same as the micro series of ign's
windy
72 combat
switchbackcreek.com
Re: ign question [Re: bill50cal] #776496
06/15/19 1:54 pm
06/15/19 1:54 pm
triton thrasher Offline
Originally Posted by bill50cal
who on here has experience with the boyer micro power or micro digital ign. systems and what if any issues or positives with it.
If you haven’t already found bad reviews of the Micro Power, you haven’t done your homework.
Re: ign question [Re: bill50cal] #776675
06/17/19 4:57 pm
06/17/19 4:57 pm
Burlington VT
mikelucas Offline
mikelucas  Offline
Burlington VT
BSA A10 with K2F SRM/Boyer conversion. Blue box Boyer I think. I spent many years converting old marine engines to electronic ignition and have always found the engines to idle/run and start smoother then points. I love points in how they are classic engineering and are easy to work on and diagnose. But technology has it's place, and I'm comfortable trading off on the potential for a circuit board to fail. I only had two issues, one caused by a bad crimp on one of the leads, and the other on a 5 year old battery that was intermittently dropping below 11 volts. So not the Boyer's fault. Some notes I would add. Make sure the charging system and battery are in tip top shape, per Boyer you can go with a larger plug gap-with me they said .028-.032, check timing immediately after install and if possible set timing using a strobe/degree wheel set-up.
So yes, very happy with this ignition system and would recommend based on my experiences
Re: ign question [Re: mikelucas] #776709
06/17/19 11:18 pm
06/17/19 11:18 pm
just an FYI. this is not my first rodeo as i have used the rita, trispark and pazon sure fire on these bikes. i am looking for feed back on the MICRO red box units as Boyer claims idle stabilization where the pazon sure fire and MK 3 and 4 blue box does not. I am also familiar with the low voltage issues on the older analog units and battery and poor charging issues. i am asking because of the high failure rates i have had and witnessed with the trispark . it is good at holding a solid idle and runs great till it fails but i want something more reliable than this shake and bake ign.
windy
72 combat
switchbackcreek.com
Re: ign question [Re: bill50cal] #776717
06/18/19 12:33 am
06/18/19 12:33 am
Oceania
NickL Offline
NickL  Offline
Oceania
The 'Micro-Power' unit is a digital controller based on a small microprocessor, the timing
curve is modified to give an 'advance' feature at around 1000rpm it to help prevent cutting
out at idle when pulling up hard or similar. The curve is more linear than the analog types.
I have an a65 in my workshop at the moment which has one fitted, it works very well.
You do need resistor plug caps or leads to use one though as most processor based units
will pick up radiated emi etc and this will play havoc with the cpu clock, causing erratic timing etc.
Fully shrouding/screening the device is always difficult but with resistor leads or caps it's ok.
Re: ign question [Re: bill50cal] #776833
06/19/19 11:22 am
06/19/19 11:22 am
West Yorkshire
West Yorkshire
To add to Nicks statement the Pazon surefire is an analogue instrument which is why it doesn’t have idle stabilisation. However the Altair is digital and equivalent to the red box and does have idle stabilisation. The smart fire is equal to their blue box system with micro low impedance coils.
Re: ign question [Re: Allan Gill] #776885
06/19/19 10:55 pm
06/19/19 10:55 pm
Onca again just more info that I already know. As the original post i am looking for real world experience with the digital Boyer.
windy
72 combat
switchbackcreek.com
Re: ign question [Re: bill50cal] #776891
06/19/19 11:22 pm
06/19/19 11:22 pm
Oceania
NickL Offline
NickL  Offline
Oceania
In short........
The owner of the bike in my workshop says it's very good and has been on the bike for 10+ years.
Re: ign question [Re: bill50cal] #776923
06/20/19 6:22 am
06/20/19 6:22 am
West Yorkshire
West Yorkshire
i am looking for feed back on the MICRO red box units as boyer claims idle stabilization where the pazon sure fire and MK 3 and 4 blue box does not.
Was just highlighting the point you made in this statement, made it seem like you didn’t know about the Altair as you made a direct comparable with the surefire.
Re: ign question [Re: bill50cal] #776932
06/20/19 11:27 am
06/20/19 11:27 am
Finger Lakes
Hillbilly bike Offline
Finger Lakes
Idle stabilization?. So the ignition jacks up the advance a bit to keep the idle steady? What is the reason for stalling after a stop? I have not expereinced this on properly tuned engine...
79 T140D, 96 900M Ducati ,2001 Sportster....On a bike you can out run the demons..
Re: ign question [Re: Hillbilly bike] #776934
06/20/19 12:30 pm
06/20/19 12:30 pm
West Yorkshire
West Yorkshire
Yup it does, like you I've never had this problem, but its a good sales point to those that want it.
Re: ign question [Re: bill50cal] #776964
06/20/19 11:25 pm
06/20/19 11:25 pm
i do know about the altair and again i have no experience with it either. one of the members on access is having kick back issues with his and waiting to see what he finds out about it. another reason i am looking at the micro digital is cost vs the micro power and altair along with the micro power using different coils.
HB the trispark with idle stablisation is a god send at hiding slightly worn carbs or other issues. with it you can have a rock solid idle at 1000 RPM. i removed a trispark after the third one failed, held a rock solid idle and with nothing changed but to a pazon sure fire it will not hold a consistent idle. and yes i am more than likely in need of new carbs but that is another issue i will deal with later.
windy
72 combat
switchbackcreek.com
Re: ign question [Re: bill50cal] #776975
06/21/19 6:23 am
06/21/19 6:23 am
West Yorkshire
West Yorkshire
Never had any kick back with mine when running the Altair. The only problem I had was the block where you screw the wires into on the board had a break or a poorly soldered joint, being about a year in from it’s 7.5 year warranty I contacted Andy at Pazon and he suggested I tried soldering the wires directly to the tracks. Soon as I touched the track with the soldering iron they peeled off the board so I reverted back to the surefire. If it wasn’t for that I was impressed with the ignition, the same board is used on the true fire ignition and that’s been spot on for many many years.
Any kick back is ultimately a carb issue, slides being too high or mixture too weak, I’ve had mine well over advanced and unless you open the throttle it won’t kick back with 10:1 compression.
