Google advert
Engnr_2001
Engnr_2001
Seattle, WA
Bill Davis, DGreear, KevKav, Joe B, tobbe53
10732 Registered Users
franko 121
DavidP 57
Rohan 52
reverb 48
920,525 mail-order LSR
Topics67,120
Posts672,713
Members10,732
53 registered members (998John), 341 guests, and 944 spiders.
Wenco Frame Triple Racer #776094
06/11/19 2:39 am
06/11/19 2:39 am
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Trying to get my Wenco frame triple together for the Cachuma rally. I decided to mount the fairing slightly farther forward for more clearance with the clip-ons. Changing the previous oil cooler to the stock cooler mounted horizontally the way the letterbox was originally done. This will need some ducting changes to bring the air up through the cooler into the headlamp box and out the internal side to the ports on the fairing sides.
Another use for the 3D printer is making brackets for test mounting the fairing. Much cheaper and faster to print off something and find it does not work for some reason than making metal parts.
The lower bracket rails should be dropped a little so there is more room for the cooler hoses to pass through.
The cooler has to be mounted to the bracket so the fairing can be removed and the cooler left in place.
This upper cowl has the headlight pocket made by Starbiker, the rest they copied off Bob Bailey's bike that he claimed at Ontario. Airtech has these molds now.
The headlight will be LED auxiliary lights remounted on a thinner heat sink.
Since lithium batteries have gotten cheaper I am mounting one in the tail cone and adding an E-starter. Kick starting was possible but having to fold the peg, unfold the kickstart lever then bring your knee up to your chest in full leathers to kick was not a quick getaway procedure.
Re: Wenco Frame Triple Racer [Re: DMadigan] #776110
06/11/19 11:24 am
06/11/19 11:24 am
Nova Scotia, Canada
koncretekid Offline
koncretekid  Offline
Nova Scotia, Canada
At the latest "Old Bike Ride" in Colorado, there was a modern Triumph Thruxton with an earlier Triumph racing fairing. The brackets were a work of art made from 1/2" steel tubing which snaked its way down to the lower front down tubes. Additional special brackets were made to support the headlight. The owner told us of the many hours it took to fabricate them using the trial and error method. Your printer may be the answer to speed up the process.
Will the printer print smooth enough tubes to be used as velocity stacks? I can see starting with a stack of various sizes and shapes to try on a flow bench (of which I only have a crude homemade one), or actually on the dyno if the tubes would take the vibration of a big single.
Tom
Re: Wenco Frame Triple Racer [Re: koncretekid] #776122
06/11/19 3:08 pm
06/11/19 3:08 pm
GrandPaul Offline
GrandPaul  Offline
Most printers, when the software settings are properly adjusted, can print quite smooth parts.
Also, if you use the correct media, it can make a permanent part, not just for testing!
Re: Wenco Frame Triple Racer [Re: DMadigan] #776125
06/11/19 3:26 pm
06/11/19 3:26 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
I already made a few velocity stacks shown here:
http://www.britbike.com/forums/ubbthreads.php/topics/754221/1
Using the right material, intake runners have been made. Of course if you have the right printer and deep pockets, SpaceX has been printing titanium and inconel parts for their rocket engines.
