Rhythm Oil
Rhythm Oil
So Cal
Bill Davis, DGreear, KevKav, Joe B, tobbe53
10732 Registered Users
franko 121
DavidP 60
Rohan 53
reverb 51
921,258 mail-order LSR
Topics67,126
Posts672,811
Members10,732
66 registered members (998John), 327 guests, and 845 spiders.
1967 A65 Lower Engine Mounting Bolt - Spacer #775997
06/09/19 8:02 pm
06/09/19 8:02 pm
Richmond, VA
jakejoseph Offline OP
Richmond, VA
So, after about 20 years of being a dream in a bunch of crates that I have moved at least once, I am finally getting to the reassembly of the BSA. I have the engine on its side, off of the floor with some 4x4s and am putting the frame around the engine.
I had the frame straightened by Wasco, and then powdercoated. I have cleaned the engine up, and polished the cases, and now am reassembling.
I bought new mounting bolts. The frame fits perfectly around the upper front mounting bolt. Slides in place with no side to side movement.
The lower mounting bolt has a gap in the clutch side (up in the picture), but no gap in the points side. I have the original mounting gear, and there was a spacer in there, which I have also attached.
I assume that the spacer needs to go in where the gap is (it fits - very tightly) before I tighten up the frame, but wanted to confirm this, as it has been 15 years since I pulled this apart.
When the frame is centered with the front bolt in place but the nuts not tightened, there is very little lateral movement - the front fits perfectly - so I can't shove the frame around to increase or decrease the gap shown.
Thanks for the advice
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776009
06/10/19 12:09 am
06/10/19 12:09 am
Yes, you have found the spot for the famous and sometimes mythical-seeming "Packing Piece". The gap IS there and that spacer IS meant to fill it up. If it's not, the bottom mount with either try to warp the frame or leave a gap.
Why it was designed that way, perhaps others can speculate ...
Orwell's "1984" was not meant to be an instruction manual.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776011
06/10/19 12:12 am
06/10/19 12:12 am
Jon W. Whitley Offline
Sounds like you are on the right track to me. The spacers should have a tight fit too keep from flexing the frame and causing undue stress on the frame which can of course possibly cause a crack and definitely increase vibration.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776015
06/10/19 12:39 am
06/10/19 12:39 am
Richmond, VA
Richmond, VA
So, I made a boo-boo - the piece can actually fit in both sides, you can get lateral movement of the frame. Sooo - Which side do I put it in?
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776020
06/10/19 1:16 am
06/10/19 1:16 am
leon bee Online content
leon bee  Online Content
Snug up all the other mounts, then do whatever it takes on that bottom bolt. That is, don't spread anything, don't decrease any gap just shim what's there.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776038
06/10/19 8:58 am
06/10/19 8:58 am
West Yorkshire
West Yorkshire
Best way would be to move the engine to either say and check the alignment of the sprockets. I’ve never hand any of the factory packing pieces but have shimmed mine with thick washers.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776047
06/10/19 11:54 am
06/10/19 11:54 am
Irish Swede Offline
Irish Swede  Offline
Welcome to the wonderful world of BSA, where every factory mistake was "adapted," instead of CORRECTED.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776088
06/11/19 12:21 am
06/11/19 12:21 am
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
My 66 with proper frame and engine numbers has a packing piece on each of the engine cases. probably each, half the thickness of the one in your photo.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: nert] #776120
06/11/19 2:44 pm
06/11/19 2:44 pm
Chelmsford MA
MarcB Offline
MarcB  Offline
Chelmsford MA
Same here: one spacer per side, though no way to know if they're original or correct.
First goal is to not flex the frame when tightening. Second is proper alignment.
Re: 1967 A65 Lower Engine Mounting Bolt - Spacer [Re: jakejoseph] #776124
06/11/19 3:26 pm
06/11/19 3:26 pm
Richmond, VA
Richmond, VA
Thanks all - I'm going to follow your suggestions, and then conduct a final alignment when the rear wheel and sprockets are installed. That spacer has enough thickness that the frame wont be sprung when tightened, so I will install it where it best fits when the other mounting bolts are snugged, and then when the rear wheel is installed, remove the lower bolt and shim for sprocket alignment.
