BritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorThe Bonneville ShopBritBike Sponsor SteadfastCyclesBritBike SponsorBritBike Sponsor
Electric Starter Roller
sawtooth
sawtooth
New York
Dan87GT, B. Nicholson, AndrewQ, Jay999, davidlittle
10939 Registered Users
franko 81
DavidP 61
1,067,170 mail-order LSR
Topics68,261
Posts684,875
Members10,938
73 registered members (Alex Lynch), 1,049 guests, and 816 spiders.
battery polarity has reversed #775852 06/07/19 3:30 pm
Cbeard Offline OP
My 1968 A65L battery seems to have reversed polarity. Its always been used with pos. ground connection. What would make this happen? Thanks in advance for any reply.
Re: battery polarity has reversed [Re: Cbeard] #775856 06/07/19 4:16 pm
Gordo in Comox Online Content
What makes you think that the battery has changed polarity?
Re: battery polarity has reversed [Re: Cbeard] #775857 06/07/19 4:24 pm
Cbeard Offline OP
She wouldn't start. A friend that is better at electrics than me swapped the battery connections and she started 1st kick. The battery is old and won't hold a charge for long. About to install a new one. I checked out the wiring with a multimeter using instructions from britbike and it is a neg. ground system. The battery had enough voltage left to check its polarity and now it appears normal. Go figure.
Re: battery polarity has reversed [Re: Cbeard] #775859 06/07/19 4:26 pm
Cbeard Offline OP
Sorry I meant to say it is a positive ground.
Re: battery polarity has reversed [Re: Cbeard] #775863 06/07/19 5:29 pm
MarcB Offline
I don't think I understand what you're saying here:
What does "it appears normal" mean? Normal on a BSA is positive ground. Sounds to me like you had the battery connected incorrectly to begin with.
Can you describe exactly what you found? Do you mean that you found the ground wire (you checked that it was really the ground, right?) connected to the battery's positive terminal, moved it to the negative and the bike started? How did you determine that it was the ground?
We need clearer details to help you out here.
Re: battery polarity has reversed [Re: Cbeard] #775879 06/07/19 11:16 pm
BSA_WM20 Offline
Batteries do not , in fact a lead acid battery can not change polarity.
And as mark hs already stated, more accurate detailed information is needed.
You are there looking at the bike scratching your had.
W are here looking at a screen
Re: battery polarity has reversed [Re: BSA_WM20] #775886 06/08/19 12:47 am
quinten Online Happy
A battery can be "forced" to change its polarity
But it will-not/can-not happen on its own ... the change would have to be forced.
One way for this to happen is ...
A fullly flat battery
... will have both plates coated with lead sulfate ....PbSO4 ... in a water solution. .. the battery no longer has a polarity .
( just a + & - mark next to the terminals)
So if a charger is hooked up backwards ... the battery can charge backwards. ( the plus and minus labels will be backwards.)
( modern batteries are not formatted with neutral lead plates , able to switch polarities
without substantial penalty . )
So whatever charge you can force into a dead-battery , if done backwards , will likely only be a light charge
Re: battery polarity has reversed [Re: quinten] #775894 06/08/19 3:13 am
BSA_WM20 Offline
In theory it is possible, in practice it can not.
The actual positive & negative plates are made from different alloys and even without any paste will retain polarity.
Next the paste is never ever fully spent.
The surface just gets passivated by the sulphate.
This is how all those "miracle battery revivers" work.
They drastically over charge causing the plates to gas and knock the passivated surface off the plates and the battery is "good as new"
Well to be honest , if the sulpate blown off the plates that drops to the bottom does not end up shorting out the plates then you will have a goos as new battery of about 10% to 30% of the original capacity.
Most chargers will either blow the output transistors ( cheap ones ) or trip a safety relay ( expensive one ), if hooked up backwards.
Grid alloys are under perpetual development .
The last time I was associated with battery making was in the 80's but even then the alloy compositions changed almost with every batch.
We were experimenting with plating an overcoat over a Pb/Sb grid which looked very promising so the + & - plates could be cast from the same alloy then electroplated to turn them into + or - plates and the plating could be done simultaneously with the heat treatment.
The amount of over voltage required to force a battery into reverse polarity, even is dead flat would be quite substantial and way over what either the alternator or most automative charges could put out.
FWIW using a Pb/Sb grid allows more scrap lead to be used in the casting alloy which was the aim of the exercise, it also allowed Pb of a higher Cu level ( Cu is an impurity is grid alloys ) to be used and removing excess copper is a very expensive & chemically dirty process.
Re: battery polarity has reversed [Re: Cbeard] #775975 06/09/19 12:41 pm
Mark Z Offline
This is all very elucidating, but is in response to a confusing description of a problem and probably unrelated to what really happened.
I would think that hooking up a battery backwards would cause a dead short through the rectifier, and would either blow the fuse (if fused) or start melting wires... unless, that is, there wasn't enough poop left in the battery to generate heat.
Re: battery polarity has reversed [Re: Mark Z] #775989 06/09/19 5:26 pm
Allan Gill Online Happy
Did it accidentally many moons ago when running a bike on points. It ran although sounded a bit laboured, then when I revved the engine the fuse blew. If it was EI then who knows. I did fit a CDI unit to a bike which was supposed to be positive earth (for a negative earth bike) no mention of it in the bullet point instructions although had I followed the wiring diagram instead then it would have shown me. This nearly melted one of the wires to the box (low amperage wire too) was ok once set it to +VE
Re: battery polarity has reversed [Re: Cbeard] #776014 06/10/19 12:27 am
Mitch Offline
guessing the reason it started after the battery was switched was due to cleaning enough oxidation off the terminals to get a go. and ya, being reversed would have made a mess of the electrics if the battery had much ooph. but then, maybe it did and you just don't know it yet
