Walt
Walt
Tennessee
A65 stuttering at speed
#775516 06/03/19 10:46 am
Going crazy here.
So my lightning has a stuttering/lugging problem at about 3/4 throttle, around 4-4.5k rpms im guessing (no tach). It had been running good but after rebuilding the carbs it boggs down and stutters right about the point it should be taking off then as the rpms (painfully) increase it clears out and accelerates as it should.
Ive replaced inline fuel filters, pulled the carbs apart again and gave em a good spraying with carb cleaner, played with air/fuel mixture, dropped the needle, raised the needle, just bout everything i can think of and its making me nutters..
Oh, new battery, ignition switch and running pazon e.i. for reference.
Originally pulled the carbs cause i assumed original problem i was chasing was from the carbs sitting for a couple months woth fuel in and getting gummed up but was the failing battery.
What am i missing here?
Re: A65 stuttering at speed
drunkenmonkz #775519 06/03/19 12:20 pm
what happens if you have the bike in a lower gear and rev the engine through?
What do the plugs look like?
If you had said that the stuttering doesn't clear then i would have suggested the main jet has come loose or worse, come unscrewed and dropped into the bottom of the bowl (this can happen)
From experience, its most likely a coil issue but need info as above.
Allan G #775524 06/03/19 1:32 pm
It acts the same through all the gears. I was hoping for a loose main or something... but everything was righty tighty
Plugs are new and looked okay after running a bit but reading plugs is like voodoo magic, i dont understand how it works, it scares me a little and im likely to hurt myself or someone else so i try to stay away from the dark arts..
drunkenmonkz #775528 06/03/19 2:16 pm
what make are your coils/ coil(dual?)? do you have a spare (or one from another bike) which you can try?
as for the plugs, a simple they are black or bone white or "nice tan colour" would suffice, just a quick indicator as to if the mixture condition is very rich or very lean.
drunkenmonkz #775531 06/03/19 2:26 pm
How old your needle jets are ?
They are wearing out quickly.
drunkenmonkz #775532 06/03/19 2:34 pm
You have new electric parts, is the fuse the glass cylinder type or a blade, the glass type can do weird things with vibration. The fault you describe sounds like a bad connection somewhere, A hot wire from natt terminal to pazon will quickly rule this in or out.
Allan G #775536 06/03/19 4:03 pm
Not sure on coils brand. Bought them with the pazon few years back. Ill hunt for a spare. Plugs are tan/coffee color.
gavin eisler #775539 06/03/19 4:07 pm
Blade type. Ill have to check connections again..
Adam M. #775540 06/03/19 4:09 pm
Needle specs oit good and shows no signs of wear.
drunkenmonkz #775598 06/04/19 6:22 am
If you bought your coils from Pazon it is likely that they are PVL, which are about the best traditional style coils you can get. I bought some when I first got my bike on the road, looked identical to the pvl but weren’t and were cheaper. One failed after 300 miles. The both got replaced by PVLs and I never had another moments trouble, although the fault itself was had to track at the time. Like yours it would only happen at certain points.
drunkenmonkz #775651 06/05/19 3:03 am
Think i got it figured out. pazon wire was just loose enough on the coil to lose continuity while at the same rpms through all the gears. Tight enough to run great at idle and city cruising but the vibrations were enough to make it bounce around and feel like a fuel delivery issue.
Fingers crossed it is the issue. Short round the block couple times felt good..
Thanks y'all
drunkenmonkz #775657 06/05/19 6:26 am
If not do as Gavin suggested a while back.
Hard wire the pazon to the battery bypassing the ignition switch.
The BSA switches are not that great which is why I opt for ignition relays rather than running everything through the switch.
drunkenmonkz #775668 06/05/19 10:24 am
If your using spades, switch them to ring terminals and fit serrated washers under the nuts.
Which reminds me I really aught to loose some of my jumper wires on mine.....
drunkenmonkz #775673 06/05/19 11:35 am
Alternatively use pliers to nip up the gap in the spades so they grip better, well for a time anyway, ring terminals are a more permanent fix.
kommando #775677 06/05/19 1:17 pm
You can get female spades with locking tabs (which is why male spades have the little holes in)
