Servodyne
Servodyne
England
New BritBike book out!
No spark 850 mk3
#775382 06/01/19 4:56 pm
Hi, my 850 mk3 estart hasn't run for a while, it now has no spark when kicked or starter motor,it has got power to the points & coils if you open close points with driver it sparks?? Do I have maybe earth problem as no pulsing when turning over just continues feed thanks andy
Re: No spark 850 mk3
Andy davies #775408 06/01/19 11:47 pm
If it still has the points for the ignition (?), have you checked the gaps of the points as the points cam rotates.
If it sparks when you open the points with a screwdriver, there should be no reason it can't spark when the points cam opens the points ??
First sign of no spark, its nearly mandatory you try a set of NEW spark plugs.
Amazing how many maladies this can fix.
Once its running, try the old set - and put the newies back in the box for next time, or next tune up time...
Rohan #775424 06/02/19 7:24 am
Whats up andy ?
2 months ago this bike had a Boyer .
Have you rewired it with points ignition ?... and it has not started yet ?
quinten #775430 06/02/19 8:53 am
Hi no that was a trident, and the problem was the buyer box it's now good,this bike is a Norton 850 mk3 cheers andy
Andy davies #775445 06/02/19 3:53 pm
12v at coil?? points plate grounded ,? condenser?
bodine031 #775460 06/02/19 7:46 pm
A... Bike has stock wiring?
B... [edit] 12 volt negative positive ground .
C. .. 2 - 6volt coils
D...1 ballast resistor .
E...1 e-start/ solenoid
F....1 charged battery ... able to hold a load .
1. Locate the ballast resistor ( part 30 )
On your bike .
With key and kill on ,
Whats the voltage before (key side) and after (coil side) the ballast ?
2. What is the battery voltage ?
3 whats the battery voltage after a 5 sec E-start attempt ?
4. ( bonus question ) what's the voltage on the coil side of the ballast
During an e-start attempt ?
.[Linked Image]
quinten #775462 06/02/19 8:10 pm
Originally Posted by quinten
B... 12 volt negitive ground .
Standard would be positive earth/ground.
L.A.B. #775463 06/02/19 8:16 pm
Lol , yes you are correct...
I wish I could say I was asking a trick question... but the jokes on me ... i will edit .
Moderated by  Dave Comeau
