KarlB
KarlB
Kent
New BritBike book out!
#775382 06/01/19 4:56 pm
Hi, my 850 mk3 estart hasn't run for a while, it now has no spark when kicked or starter motor,it has got power to the points & coils if you open close points with driver it sparks?? Do I have maybe earth problem as no pulsing when turning over just continues feed thanks andy
If it still has the points for the ignition (?), have you checked the gaps of the points as the points cam rotates.
If it sparks when you open the points with a screwdriver, there should be no reason it can't spark when the points cam opens the points ??
First sign of no spark, its nearly mandatory you try a set of NEW spark plugs.
Amazing how many maladies this can fix.
Once its running, try the old set - and put the newies back in the box for next time, or next tune up time...
Whats up andy ?
2 months ago this bike had a Boyer .
Have you rewired it with points ignition ?... and it has not started yet ?
Hi no that was a trident, and the problem was the buyer box it's now good,this bike is a Norton 850 mk3 cheers andy
12v at coil?? points plate grounded ,? condenser?
A... Bike has stock wiring?
B... [edit] 12 volt negative positive ground .
C. .. 2 - 6volt coils
D...1 ballast resistor .
E...1 e-start/ solenoid
F....1 charged battery ... able to hold a load .
1. Locate the ballast resistor ( part 30 )
On your bike .
With key and kill on ,
Whats the voltage before (key side) and after (coil side) the ballast ?
2. What is the battery voltage ?
3 whats the battery voltage after a 5 sec E-start attempt ?
4. ( bonus question ) what's the voltage on the coil side of the ballast
During an e-start attempt ?
.[Linked Image]
Originally Posted by quinten
B... 12 volt negitive ground .
Standard would be positive earth/ground.
Lol , yes you are correct...
I wish I could say I was asking a trick question... but the jokes on me ... i will edit .
Moderated by  Dave Comeau
