breeze1954
breeze1954
S.W. Pa.
Stormbringer, Noah from PA, DGW Auctioneers, GoTriples, Jan Hellinge
10830 Registered Users
franko 139
NickL 73
reverb 60
DavidP 58
975,112 mail-order LSR
Topics67,414
Posts677,585
Members10,830
59 registered members (Al Eckstadt), 280 guests, and 770 spiders.
Clutch nut size? #775296 05/31/19 11:10 pm
Nick H Offline OP
Working on a Lightning and I have 2 motors. Ordered part number 68-3300, clutch nut from an eBay seller that sells lots of British bike parts.
It doesn't fit either of my transmission main shafts. Seems to small.
Ordered another, same part from a Britbike forum sponsor, it is identical and doesn't fit.
Every reference says this should be 9/16" 20 tpi
(except the Greg Marsh fastener database which says 68-3300 is 13/16" 20 tpi)
Should I look for a 13/16" 20 tpi nut? Can't be that large.
I'm tempted to buy a 5/8" 20 tpi from British Tool and Fastener to see if it fits.
Anyone know what might be going on.
1966 BSA Lightning
1967 Triumph "Choppa"
Re: Clutch nut size? [Re: Nick H] #775333 06/01/19 6:21 am
I bought a couple and found the same problem, just wouldn’t start on the threads. It needed a tap running though (but not far enough through to thread onto the aero fit part ) also I had to put it in the large to create a leading edge like the originals as even after the tap had gone through it still wouldn’t start.
Re: Clutch nut size? [Re: Allan Gill] #775361 06/01/19 1:28 pm
Nick H Offline OP
This suggests these parts are defective, no?
I'll have to invest in a tap.
No lathe so maybe a reamer to create a leading edge.
Or better, find a used part.
1966 BSA Lightning
Re: Clutch nut size? [Re: Nick H] #775427 06/02/19 8:44 am
Agreed Nick, poorly made indeed even if they are using the right materials. I’d refrain from using a used one, only reason I changed mine was it wouldn’t hold torque anymore, soon as I opened the throttle hard the nut would unwind off its thread, although locktite might help but I try to refrain from using it in such application.
Re: Clutch nut size? [Re: Nick H] #775432 06/02/19 11:03 am
gavin eisler Online Content
I use blue nut lock on the clutch nut, never had any bother with it.
Re: Clutch nut size? [Re: Nick H] #775436 06/02/19 12:28 pm
triton thrasher Offline
I would always Loctite a clutch centre nut.
Re: Clutch nut size? [Re: Nick H] #775469 06/02/19 9:10 pm
kevin roberts Online Confused
Online Confused
i also.
the nut on the other end too
Re: Clutch nut size? [Re: Nick H] #775515 06/03/19 10:42 am
BSA_WM20 Offline
Blue for this little black duck as well
Re: Clutch nut size? [Re: Nick H] #775521 06/03/19 12:40 pm
interesting! I'always refrained from it as (on the A65) its a self locking nut, I did fit some locktite on a setscrew that was using a stover nut (looks like its been centre punched on 3 sides)
example of stover nut
Couldn't remove it again afterwards and had to drill the setscrew out. On mudguards I use locktite regardless of the nut type.
Re: Clutch nut size? [Re: Nick H] #775563 06/03/19 10:13 pm
NickL Online Content
Nothing worse than your nuts falling off eh?
I'd get on to the bloke who sold those nuts to you and tell him you want the mainshafts that go with them for free.
Sod messing about with taps unless he's paying for them.
A drop of blue loctite never hurts on the clutch centre nut and the crank one too.
Re: Clutch nut size? [Re: Nick H] #775567 06/03/19 11:14 pm
Irish Swede Offline
WHO is that eBay seller? What eBay alias does he go by?
They all use aliases anyway, so his personal name won't be mentioned.
Everyone on this site needs to know so we can stay away from dealing with him.
WAAAYYY too much of this goes on with eBay sellers.
Re: Clutch nut size? [Re: Nick H] #775569 06/03/19 11:19 pm
Nick H Offline OP
The eBay seller is "smmotorco" but I also bought one from site sponsor CBS. They claim to have used the nut on Triumphs with no issues and offered a refund if I returned it.
I wonder if Allan recalls where he purchased his.
1966 BSA Lightning
Re: Clutch nut size? [Re: Nick H] #775599 06/04/19 6:32 am
Just checked, April last year I got 2x from Draganfly. Having this problem since I’ve been in to Britbike’s I often don’t have the time to pee about sending stuff back and often just sort the problem my self as it’s much quicker. Draganfly have a lot of NOS parts and an easy to use site so I often buy from them.
As for the locktite, I wonder what the actual torque applied is when you add locktite to the threads as it suddenly becomes a lot higher than 60ft/lb.
