Topics68,215
Posts684,534
Members10,936
Most Online14,755 May 5th, 2019
69 registered members (Alan_nc),
912
guests, and 895
spiders. |
Key:
Admin,
Global Mod,
Mod
Re: 71 T bolt project starter kit!
[Re: Vetterdog]
#773640
05/14/19 3:03 am
hacksaw
Posts: 898 |
200 is a good starting point if the frame is straight. looks like it was hit.
[Re: hacksaw]
#773677
05/14/19 12:41 pm
old mule
Posts: 854 |
[Re: Vetterdog]
#773679
05/14/19 1:00 pm
Vetterdog
Posts: 370 |
Frame appears straight. I cant see any evidence of a crash. Footrests may have been bent during years of storage/ neglect. No scuffs dents or bends visible on frame, forks, bars etc. other than usual surface stuff.
vdog 66 6T 67 A65L 72 T100R
[Re: Vetterdog]
#773685
05/14/19 1:45 pm
Allan Gill
Posts: 6,030 |
The good stuff is never local...
[Re: Vetterdog]
#773759
05/15/19 4:20 am
hacksaw
Posts: 898 |
foot pegs dont generally bend up like that. and that bent peg is the same side of the bike as the busted up front brake plate. so something happened. but i certainly take your word the frame is strait. i will be in central jersey, princeton i think, the weekend of june 8. if u still have it i would be interested in it.
curious, are those 1 inch bars? looks like a late 80's HD style grip on the right side. somebody ran a left side throttle on this machine?
[Re: Vetterdog]
#773774
05/15/19 10:32 am
gavin eisler
Posts: 4,771 |
Rear seat loop looks bent down to me.
71 Devimead A65 750 56 Norbsa 68 Longstroke A65 Cagiva Raptor 650 MZ TS 250 The poster formerly known as Pod
[Re: gavin eisler]
#773798
05/15/19 2:12 pm
hacksaw
Posts: 898 |
looks that way to me too, but it could be just the photo angle. the guy says its straight. why lie?
[Re: Vetterdog]
#773824
05/15/19 7:25 pm
gavin eisler
Posts: 4,771 |
Bars could well be 1 ", the spacer shims for 7/8" are not fitted. Still a good deal for the cases/ crank etc, these frames are strong, between the bent rests and the rear loop its had a bit of a tumble at some point, worth pressure testing.
[Re: Vetterdog]
#773827
05/15/19 7:55 pm
Tridentman
Posts: 4,579 |
BTW--the seller-- Dave Vetter--- is one of the good guys.
[Re: Vetterdog]
#773829
05/15/19 8:24 pm
Vetterdog
Posts: 370 |
I will look more closely at this tonight. It appears ok, with no obvious damage, but it's history is unknown to me. Got it as swap for some VW stuff way back. I see the rear loop in the pic and it does look off in that shot, and I agree it probably took some force to bend that footrest. Will report back. (Admittedly I am clearing out a bunch of stuff preparatory to a move so could have been more thorough checking this one out)
[Re: Vetterdog]
#773843
05/15/19 11:01 pm
Vetterdog
Posts: 370 |
OK, I feel like a tool. Just looked it over and the rear section is bent for sure. Center stand is bent, rear loop looks to be pushed down and to the side a bit, the section where the rear footrest attaches is also pushed in. The front section looks OK, as do the forks and triple trees. The handlebars sit a little off kilter too, it looks to be that the through bolt section of the mount is bent where it passes through the top clamp. On the positive, I located some engine parts that I had removed from the bottom end, including inner left side cover and hardware, oil pump (broken tacho tab) and a few other bits. But to balance the good, I looked at the motor closely and saw how dirty it is. Apparently water had gotten into the outer cover so there's some rust and residue. Does not look like water got into the case and there is no evidence of rust or water on the inside parts. I am in the process of updating the CL ad with more pics, since I gave up trying to post pics here. Last few are of motor interior, kind of hard to make out. I apologize for any confusion and/or misleading info I gave on this pile. On the whole I think the motor is alright for a rebuild and the frame could be fixed, as there are no severe bends, crumpled sections or even scrapes, gouges etc. That being said, I really just would like to see it all gone; as mentioned I will be moving soon.
Needless to say, this will lower my expectations as far as price is concerned!
[Re: Vetterdog]
#773856
05/16/19 12:59 am
Jon W. Whitley
Posts: 6,201 |
Are the frame and engine numbers matching ?
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
[Re: Vetterdog]
#773865
05/16/19 1:49 am
Vetterdog
Posts: 370 |
So far have been unable to find number on frame, other than what appears to be a casting # on steering head. (B44B41853) Nothing on gusset from frame to steering head. (I'm not an OIF Guy, sorry)
There are numbers on the bottom of the lower engine mounting lugs, but they don't appear to be VINs. (83 2109) ??
[Re: Vetterdog]
#773887
05/16/19 5:27 am
hacksaw
Posts: 898 |
how long before you move? as i said previous, i will be down your way weekend of june 8
[Re: Vetterdog]
#773894
05/16/19 8:31 am
Allan Gill
Posts: 6,030 |
Think the B44B number is someone trying to impersonate a 1968 B44 frame for DMV dodging/fraud etc
[Re: Vetterdog]
#773898
05/16/19 9:22 am
gavin eisler
Posts: 4,771 |
frame nos should be on LHS steering head gusset, they are faintly stamped at best, probably need a scuff with a sanding pad to show up.
[Re: Vetterdog]
#773905
05/16/19 12:00 pm
Vetterdog
Posts: 370 |
I will look again tonight and sand a bit, but I saw nothing there last night, not even a hint. Hacksaw, I wont be moving until early July. (PM sent)
[Re: Tridentman]
#775973
06/09/19 10:53 am
britcyclenut
Life premium member
Life premium member
Posts: 78 |
Is the bike still available?
80 FLH 66 Triton 71 442 67 atlas 71 TR6R
[Re: Vetterdog]
#775992
06/09/19 6:03 pm
Vetterdog
Posts: 370 |
Yes it is. I had some inquiries but it's still here. I'm in Hillsborough, you?
[Re: Vetterdog]
#775995
06/09/19 7:24 pm
Tridentman
Posts: 4,579 |
Hi Dave----FYI--- Fred (britcycleguy) is also one of the good guys. HTH
[Re: Vetterdog]
#776666
06/17/19 2:34 pm
Vetterdog
Posts: 370 |
Still here, several folks interested but so far no follow through. I may end up parting this out I guess. (More than it already is)
[Re: Vetterdog]
#776700
06/17/19 10:03 pm
choppadude
Posts: 155 |
Original craigslist as is gone, what is your asking price?
[Re: Vetterdog]
#776815
06/19/19 4:29 am
hacksaw
Posts: 898 |
i was just in princeton junction and i forgot about this.
[Re: Vetterdog]
#777400
06/27/19 1:21 pm
Vetterdog
Posts: 370 |
The engine has been sold, still have frame and front end left, willing to part out.
