twinspin
twinspin
Reading UK
Alex Lynch, B Mac, Lenz-a-lot, UncleYeti, harold2019
10774 Registered Users
franko 128
NickL 66
MarcB 53
947,603 mail-order LSR
Topics67,493
Posts675,613
Members10,774
69 registered members (Al Eckstadt), 448 guests, and 764 spiders.
71 T bolt project starter kit! #773636 05/14/19 2:27 am
Vetterdog Offline OP
https://cnj.craigslist.org/mcy/d/hillsborough-1971-bsa-a65t-project-200/6886563565.html
Had this sitting around for a while, realized I'll probably never get around to it. Offers considered!
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773640 05/14/19 3:03 am
hacksaw Offline
200 is a good starting point if the frame is straight. looks like it was hit.
Re: 71 T bolt project starter kit! [Re: hacksaw] #773677 05/14/19 12:41 pm
old mule Offline
Oh?
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773679 05/14/19 1:00 pm
Frame appears straight. I cant see any evidence of a crash. Footrests may have been bent during years of storage/ neglect. No scuffs dents or bends visible on frame, forks, bars etc. other than usual surface stuff.
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773685 05/14/19 1:45 pm
The good stuff is never local...
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773759 05/15/19 4:20 am
hacksaw Offline
foot pegs dont generally bend up like that. and that bent peg is the same side of the bike as the busted up front brake plate. so something happened. but i certainly take your word the frame is strait. i will be in central jersey, princeton i think, the weekend of june 8. if u still have it i would be interested in it.
curious, are those 1 inch bars? looks like a late 80's
HD style grip on the right side. somebody ran a left side throttle on this machine?
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773774 05/15/19 10:32 am
gavin eisler Offline
Rear seat loop looks bent down to me.
Re: 71 T bolt project starter kit! [Re: gavin eisler] #773798 05/15/19 2:12 pm
hacksaw Offline
looks that way to me too, but it could be just the photo angle. the guy says its straight. why lie?
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773824 05/15/19 7:25 pm
Bars could well be 1 ", the spacer shims for 7/8" are not fitted.
Still a good deal for the cases/ crank etc, these frames are strong, between the bent rests and the rear loop its had a bit of a tumble at some point, worth pressure testing.
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773827 05/15/19 7:55 pm
Tridentman Offline
BTW--the seller-- Dave Vetter--- is one of the good guys.
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773829 05/15/19 8:24 pm
I will look more closely at this tonight. It appears ok, with no obvious damage, but it's history is unknown to me. Got it as swap for some VW stuff way back. I see the rear loop in the pic and it does look off in that shot, and I agree it probably took some force to bend that footrest. Will report back. (Admittedly I am clearing out a bunch of stuff preparatory to a move so could have been more thorough checking this one out)
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773843 05/15/19 11:01 pm
OK, I feel like a tool. Just looked it over and the rear section is bent for sure. Center stand is bent, rear loop looks to be pushed down and to the side a bit, the section where the rear footrest attaches is also pushed in. The front section looks OK, as do the forks and triple trees. The handlebars sit a little off kilter too, it looks to be that the through bolt section of the mount is bent where it passes through the top clamp. On the positive, I located some engine parts that I had removed from the bottom end, including inner left side cover and hardware, oil pump (broken tacho tab) and a few other bits. But to balance the good, I looked at the motor closely and saw how dirty it is. Apparently water had gotten into the outer cover so there's some rust and residue. Does not look like water got into the case and there is no evidence of rust or water on the inside parts. I am in the process of updating the CL ad with more pics, since I gave up trying to post pics here. Last few are of motor interior, kind of hard to make out. I apologize for any confusion and/or misleading info I gave on this pile. On the whole I think the motor is alright for a rebuild and the frame could be fixed, as there are no severe bends, crumpled sections or even scrapes, gouges etc. That being said, I really just would like to see it all gone; as mentioned I will be moving soon.
Needless to say, this will lower my expectations as far as price is concerned!
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773856 05/16/19 12:59 am
Jon W. Whitley Offline
Are the frame and engine numbers matching ?
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773865 05/16/19 1:49 am
So far have been unable to find number on frame, other than what appears to be a casting # on steering head. (B44B41853) Nothing on gusset from frame to steering head. (I'm not an OIF Guy, sorry)
There are numbers on the bottom of the lower engine mounting lugs, but they don't appear to be VINs. (83 2109) ??
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773887 05/16/19 5:27 am
hacksaw Offline
how long before you move? as i said previous, i will be down your way weekend of june 8
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773894 05/16/19 8:31 am
Think the B44B number is someone trying to impersonate a 1968 B44 frame for DMV dodging/fraud etc
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773898 05/16/19 9:22 am
frame nos should be on LHS steering head gusset, they are faintly stamped at best, probably need a scuff with a sanding pad to show up.
Re: 71 T bolt project starter kit! [Re: Vetterdog] #773905 05/16/19 12:00 pm
I will look again tonight and sand a bit, but I saw nothing there last night, not even a hint. Hacksaw, I wont be moving until early July. (PM sent)
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Tridentman] #775973 06/09/19 10:53 am
britcyclenut Offline
Life premium member
Life premium member
Is the bike still available?
80 FLH
66 Triton
71 442
67 atlas
71 TR6R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #775992 06/09/19 6:03 pm
Yes it is. I had some inquiries but it's still here. I'm in Hillsborough, you?
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #775995 06/09/19 7:24 pm
Tridentman Offline
Hi Dave----FYI--- Fred (britcycleguy) is also one of the good guys.
Re: 71 T bolt project starter kit! [Re: Vetterdog] #776666 06/17/19 2:34 pm
Still here, several folks interested but so far no follow through. I may end up parting this out I guess. (More than it already is)
vdog
66 6T
67 A65L
72 T100R
Re: 71 T bolt project starter kit! [Re: Vetterdog] #776700 06/17/19 10:03 pm
choppadude Offline
Original craigslist as is gone, what is your asking price?
Re: 71 T bolt project starter kit! [Re: Vetterdog] #776815 06/19/19 4:29 am
hacksaw Offline
i was just in princeton junction and i forgot about this.
Re: 71 T bolt project starter kit! [Re: Vetterdog] #777400 06/27/19 1:21 pm
The engine has been sold, still have frame and front end left, willing to part out.
vdog
66 6T
67 A65L
72 T100R
Moderated by  Steve Erickson
