MotorEddy
MotorEddy
Lancashire, UK
Alex Lynch, B Mac, Lenz-a-lot, UncleYeti, harold2019
10774 Registered Users
franko 128
NickL 66
MarcB 53
947,603 mail-order LSR
Topics67,493
Posts675,613
Members10,774
71 registered members (Al Eckstadt), 449 guests, and 821 spiders.
Failing ignition switch #773680 05/14/19 1:03 pm
gavin eisler Offline OP
I know Brit ignition switches are sometimes dodgy.
My latest experience is worth a mention.
I recently fitted a Smiths electronic tach, this has an interesting characteristic, if the power is interrrupted when in service it resets to zero and remains there.
A couple of months ago it did this and the motor showed classic interrupted supply, running missing , backfires etc.
I checked the switch at the time , found a bad contact when testing on closed position , got fluctuating ohms. Blessed it with WD 40 , retested OK.
Fast forward to last night, tach died twice, no obvious miss fires.
Checked the switch again and found one of the terminals was loose where the contact was supposed to be rivetted to the blades terminal. Cleaned it up and soldered the blade to the contact. Tested OK.
I would never have noticed this if the tach was the normal mech type.
New switch on order.
Re: Failing ignition switch [Re: gavin eisler] #773683 05/14/19 1:44 pm
Didn’t you change the switch not too long ago Gavin?
Re: Failing ignition switch [Re: gavin eisler] #773691 05/14/19 2:28 pm
naw , i was going to get around to it, then forgot, now its getting the gumach.
Re: Failing ignition switch [Re: gavin eisler] #773763 05/15/19 5:26 am
I had a similar experience with my electronic tach recently, but it would go to 8 and stay there, then work for a while, then go to zero. Turned out to be a loose connection but not the main switch.
I used to carry a jumper with three male spades wired together to use in case of switch failure or if I lost the key.
Re: Failing ignition switch [Re: gavin eisler] #774762 05/26/19 1:47 pm
Stein Roger Offline
Some 4 pos switches will start to fail very quickly, the new one on the Trident lasted all of two seasons or only around 5000 km... (I have other bikes)
Thankfully I was prepared as I've done this a few times: http://www.nocnsw.org.au/technical/rebuild-lucas-ignition-switchtobetterthannew
Easy to do, and it really does become better than new.
Re: Failing ignition switch [Re: gavin eisler] #774788 05/26/19 7:13 pm
Thanks for the link.
I use the two position switch , its even more chintzy.
Re: Failing ignition switch [Re: gavin eisler] #774791 05/26/19 7:56 pm
Yeah Worzel and Aunt Sally will sort it out.
Re: Failing ignition switch [Re: gavin eisler] #774792 05/26/19 8:00 pm
I use the two position switch , its even more chintsy.
I think spelling matters. You don’t have to agree.
https://en.m.wikipedia.org/wiki/Chintz
Re: Failing ignition switch [Re: gavin eisler] #774797 05/26/19 10:07 pm
NickL Offline
These are suitable for tractors, so must be ok.
https://www.eBay.com.au/itm/Universal-Car-12V-Forklift-Tractor-Ignition-2Key-Switch-Lock-4-Position-unique/312025790007?hash=item48a62fb637:g:CQIAAOSwYxBaMhB5
Re: Failing ignition switch [Re: gavin eisler] #774838 05/27/19 9:57 am
thats a good looking switch, thanks Nick. might be a bit on the long side.
