smitty
smitty
cleveland,ohio
New & Improved "BPF" LED Headlight Bulbs
#761491 01/04/19 5:19 pm
C.B.S Offline OP
Parts Dealer
Parts Dealer
British Pre-Focus LED Headlight Bulbs
British pre-focus LED bulbs are now better than ever..
Here's why:
-New "beam" design
-Brighter
-Dual Filament
-Non-polarity sensitive
For only $34.95 & free USA shipping you can have a bulb that actually lights up the road without any fear of not seeing or not being seen.
Our new BPF LED bulbs will do just the trick for all your night time riding come this spring.
Purchase your led bulbs today by clicking on the link below or clicking the banner above.
Link: https://www.classicbritishspares.co...ts/british-pre-focus-led-headlight-bulbs
Re: New & Improved "BPF" LED Headlight Bulbs
C.B.S #761521 01/04/19 9:23 pm
Ride safe today!
Ride safe today!
Looks very interesting..
BSAing you
Morgan Johansson
BritBike.com.
____________________
Join our British MotorCycle Forum on Facebook
C.B.S #761564 01/05/19 2:03 am
I'm happy with the 1st edition item I tried!! Planned to put them in the other bikes, great to "conserve" the battery charging on daylight running. Fit like it was made by OEM! So now it is even better!
C.B.S #761634 01/05/19 4:22 pm
C.B.S Offline OP
Parts Dealer
Parts Dealer
KC, I liked the 1st bulbs too but these are much better. The beam is more focused on the road where it should be.
C.B.S #761790 01/07/19 1:14 am
Sounds good. At least now you won't need to worry about a negative ground bulb getting into a positive ground box.
C.B.S #761936 01/08/19 5:12 pm
The specs say this bulb works for any + or - voltage from 6V on up so I just paid $35 to be the guinea pig to see if it actually does brighten the night on my ET-equipped Triumph. The AC output of the lighting coil means a "normal" single-polarity LED bulb only would be on half the time. While the flickering of a "normal" LED would become unnoticeable above a few thousand rpm, having only half the light output would be noticeable. This new bulb should stay on through the full oscillating cycle as well as be much brighter than a stator-limited incandescent bulb, but I'll have to see it it works out that way in practice, as well as if it has an acceptable beam profile.
Just this weekend I moved the Triumph to the back of the garage so it will be a while before I test the bulb. I hope by then I don't forget I have a different headlight bulb, and I hope the bulb actually works, because getting caught out at night with no output from a bulb would be way worse than its present feeble ET headlamp.
C.B.S #762105 01/09/19 10:14 pm
Just ordered one myself for the BSA A10. It has to be better than the candle on it now. Report to follow!
1960 BSA A10
2007 Suzuki Bandit
1957 A10
(Used to be a Triumph here)
71 Norton Commando
17 Triumph Bonneville
C.B.S #762106 01/09/19 10:19 pm
#irideslow
#irideslow
Same here, ordered one the other day.
Kurt
Magnetoman #762138 01/10/19 7:14 am
MM, PLEASE don't forget to post your results. The ET stands to benefit the most from these bulbs if they work... as you know. I might actually be able to see the next deer I bounce off of.
Steve Erickson #762325 01/12/19 12:33 am
Hold off until I have time to test them. Mine arrived today and even though I don't have time to do anything I took a little time anyway. I hooked one of its "filaments" to a power supply and the bulb begins to light up at 4V and seems to achieve full brightness at 5.8 V, at which point according to the power supply's ammeter it was drawing only ~1.5 A. The other filament behaved the same, although it drew ~1.8 A Although I'll instrument it properly for illumination, voltage, current and frequency response(*) when I get a chance, taking these at face value it only needs ~20 W to give full brightness from both filaments (and it certainly looks bright). That's less than 2/3 the power the E.T.'s lighting coils supply. That's the promising news.
Something to worry about is how irritating the flicker will be. If the filaments are "instant" on and off at the threshhold voltage, rather than taking at least ~5 msec.(*) to fade once they're on, there's a considerable part of the duty cycle when they will be off. On the other hand, an appropriate capacitor may easily take care of that. However, it also remains to be seen if the beam pattern is acceptable.
Anyway, having done only the most superficial of tests, at this point I'm cautiously optimistic this bulb could make our E.T. bikes forces to be reckoned with after the sun goes down. If so, it will remove the only factor where our E.T. systems aren't vastly superior to bikes having those wretched batteries that I hate so much.
(*) the voltage from the stator goes through 6 "zeros" per revolution so at 1800 rpm that happens 1800 revs/min x 1 min/60sec. x 6 zeros/rev = 180 zeros/sec or 1 zero every ~6 msec.
Magnetoman #762348 01/12/19 7:29 am
Your worried about 50hz flicker at idle ?
C.B.S #762384 01/12/19 5:58 pm
I wouldn't have written what I did if I didn't have valid reasons to be concerned that it might be an issue with these bulbs on the road when operated on the AC from an E.T.'s lighting coils. However, rather than a pointless data-free argument now, wait until measurements provide the answer. Whether or not there are issues depends on if the phosphors used to make the light from these bulbs white(ish) have decay times >5 ms and/or the characteristics of the electrical circuitry the drives the bulb. It requires measurements to know.
Meanwhile, if someone wants to try one of these bulbs in their E.T. bike before I find the time to make the measurements, it's important is to test it on a dark, moonless night. It's under those conditions where stroboscopic effects, if any, will be most noticeable and most objectionable.
C.B.S #762450 01/13/19 2:06 pm
Received mine yesterday. While I can't give the kind of test results MM did, all I can say is it's BRIGHT and it barely made the amp meter flicker when turned on. It will be a few months before any road testing can happen but if the pattern it throws on the wall is any indication, it should be a big improvement.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
71 Norton Commando
C.B.S #762506 01/14/19 1:21 am
As a quick test, today I hooked the bulb to a Variac and cranked the dial to 6 V. Unfortunately, one of the beams flickered noticeably at the 120 Hz (equivalent to the stator's output at 2400 rpm). Interestingly, though, the other beam did not flicker.
Experiments to find a capacitor to eliminate the flickering are next, when time permits. I don't have any immediate need for a better light on my Triumph so this isn't at the top of my to-do list.
C.B.S #762570 01/14/19 6:51 pm
Who cares about flickering? There are gadgets sold designed to make your old incandescent blub "flicker" intentionally. It makes you much more visible to the cage drivers.
HawaiianTiger #762575 01/14/19 7:38 pm
Those pulsate the bulb at low frequency* during the day and are disabled at night. You wouldn’t want to ride at night with a strobe for a headlight.
* 4 Hz
C.B.S #773447 05/12/19 10:56 am
Got 2 myself......plus 2 x new 'Lucas' 7" reflectors. Thought I only ordered one lens but 2 turned up so I guess I have a spare smile
Needed the lens for the Trident, it presently has a Lucas sealed beam in it, which is a good light, but I always worry about 'what if it blows and I'm miles from home'...I can't replace the bulb. So the new reflector with the LED globe fixes that, cos if the LED burns out I can just buy a H4 or std type globe and go again.
Can't comment on how good they are just yet, Trident is getting a make over in the top end....new Beadling barrels.
C.B.S #773457 05/12/19 1:56 pm
Write some report about them after covering some miles.
HawaiianTiger #775670 06/05/19 10:35 am
I’d have to read up on the MOT manual as it’s been 3 years since I last did any testing, but from memory (in the UK at least) the bulbs should not be flickering for MOT regulation.
The other concern with a flickering light is those darn cage drivers may think that your flashing them and turn in front of you... it’s because of this that I stopped riding with lights on during day light hours. (Unless cutting through dense traffic then I put main beam on, not bright enough to dazzle anyone but it does get you noticed and fewer people change lanes in front of you)
C.B.S #775805 06/06/19 9:13 pm
I think there is at least one state here that is encouraging motorcyclists not only to ride with lights on (mandatory) but hat you leave the high beams on. During the day there doesn't seem to be a problem with blinding someone this way and may well allow the motorcyclist to be seen better than with just the low beam on.
I guess it really depends on where you ride. Where I ride, motorcycle accidents are kind of rare and fatalities down to one or two a year if that. I ride my British bikes with headlight on during daylight hours only when my charging system allows it, or on the highway. Around town, there is a constant discharge of the battery that will eventually get you stranded.
They both have switchable headlights whereas the Honda does not and also the law exempts old bikes in the daylight lights-on law.
My mantra, which has worked so far, is to ride like you are invisible anyway, which is at least sometimes true even with flashing high beams, orange vests, open pipes, you name it.
HawaiianTiger #780473 08/03/19 9:44 pm
love reading you stuff. here in Southern California freeway riding is not too popular mainly because of driver distraction and cars are so quite and fast now too many drivers are on auto pilot. Asleep at the wheel 75-80 in slow lane is dangerous. They tailgate and make me uncomfortable. L. A. is flat out nuts two or three accidents per day on average. I white line as a means of defense. I prefer two lanes off the beaten path for my riding.
Thanks for all your good advice in the past.
Scott Garland
Moderated by  Morgan aka Moderator
