Grappa Speziale
Grappa Speziale
Solihull, West midlands UK
Bargee, TBC, Vidane, BenM, New_Warrior
10663 Registered Users
franko 112
NickL 54
879,077 mail-order LSR
Topics66,603
Posts668,661
Members10,663
32 registered members (Airman49), 641 guests, and 577 spiders.
Voltage drop key on #772925
05/07/19 6:09 pm
05/07/19 6:09 pm
MA
Nick H Offline OP
Nick H  Offline OP
MA
My 12 volt battery is fine with no load. Reads 12.8 or even 13 when charged. When i turn the key on it drops to around 10 volts. A tail light and points are the only things in the circuit. If I disconnect the points, the voltage goes back up.
Do I have a bad battery?
1966 BSA Lightning
1967 Triumph "Choppa"
Re: Voltage drop key on [Re: Nick H] #772930
05/07/19 7:19 pm
05/07/19 7:19 pm
West Yorkshire
Allan Gill Online happy
Allan Gill  Online Happy
West Yorkshire
Yup!
Re: Voltage drop key on [Re: Nick H] #772973
05/07/19 11:45 pm
05/07/19 11:45 pm
MA
Nick H Offline OP
Nick H  Offline OP
MA
Thanks. They don't last long do they?
1966 BSA Lightning
Re: Voltage drop key on [Re: Nick H] #773005
05/08/19 6:25 am
05/08/19 6:25 am
West Yorkshire
West Yorkshire
If your not using the bike regular no, they don’t and it’s important to keep them charged up. Once they have failed it’s usually the end for most batteries. The other thing is if the charging system on the bike isn’t getting the battery up to full capacity then this will also shorten the life. But crucially, disconnect the battery and put it on charge soon as it’s not in use. They can then last a very long time, it only if the battery is at full charge.
Is it a dry cell (AGM), or traditional lead acid?
(Both above are similar but AGM has matting between the plates and are totally sealed, unlike the traditional battery where you can top them up.
Gel is different again and most people who think they have a Gel battery... often dont
Re: Voltage drop key on [Re: Nick H] #773311
05/11/19 1:17 am
05/11/19 1:17 am
Arizona Territory
Sinical Offline
Sinical  Offline
Arizona Territory
A standing charge of 12.8V with the bike not running is very good. After turning only the key on, it's normal for a gradual voltage drop, sometimes dropping to 11V or even 10V. If it's not dropping below 10V with key on, I wouldn't condemn the battery based on that alone.
Once the voltage drop stops and you turn the key off again, does the voltage return to 12.8V ? Does the bike fire-up without any problem ? Once running, does it idle at between 13.5V - 14.5V ?
1966 TR6R (stock)
1970 TR6R (chopped)
"Obsession Is What Lazy People Call Dedication"
