GaryK227
GaryK227
Randolph, NJ
Psychorider, Shedengineering, Shayne Brown, Snow's Cycles, Scottboy
10858 Registered Users
franko 173
reverb 65
DavidP 56
NickL 56
1,005,598 mail-order LSR
Topics67,735
Posts679,872
Members10,858
49 registered members (Al Eckstadt), 332 guests, and 717 spiders.
A 10 Gearbox troubel #771197 04/16/19 9:31 am
expresidente Offline OP
hello folks
Was working on a friends bike lately. It is a BSA A 10 with swing arm frame. The gearboxes used to be bulletproof, as much as i know them. Must say that the bike must had have a very hard life, because he brought it back home from India. That was years ago and since he spend lots of money and effort to the bike. Had the complete box out and dismantled. Got new bearings, bushes, shafts slipped and all that stuff what was needed. He said that the third gear jumps out then and when, especially when riding with his wife. I did check the gears and changed them to a matching set for the third, because the old ones showed some wear. Also changed the shifter fork and checked the spring tension of the cam plate.The problem now is, that the third gear still jumps out under load. Any suggestions, what i should watch out for ?
Re: A 10 Gearbox troubel [Re: expresidente] #771201 04/16/19 11:55 am
kommando Offline
If you swapped out the 3rd gears then you missed out the sliding gear that slides across and locks 3rd gear to the shaft, if the dogs on that are worn then 3rd will still jump out.
Re: A 10 Gearbox troubel [Re: expresidente] #771202 04/16/19 12:24 pm
Rich B Online Happy
Not sure if you have seen this or not, it is a sticky in the GS forum
http://www.britbike.com/forums/ubbt...mission-info-swing-arm-models#Post713333
Re: A 10 Gearbox troubel [Re: kommando] #771206 04/16/19 12:49 pm
hy commando
Yes you are absolutely right. When i was saying that i changed the gears, i wanted to tell that i swapped the pinion gear and the sliding gear from the main shaft. I dont think the other 3. gear of the layshaft would cause the problems. Sorry if i described it not exact.
hy Rich
thanks for the link.
But i dont think it is a question of shimming the gears. but i could be wrong. And am willing to learn something new.
