injunmort
injunmort
sugarloaf ny
Greg Alexander, BBQ, Rick K, Fraz, Dave Tomz
10647 Registered Users
koan58 102
reverb 70
L.A.B. 56
854,516 mail-order LSR
Topics68,062
Posts673,847
Members10,647
Most Online5,714
Apr 16th, 2019
73 registered members (Al Eckstadt), 408 guests, and 275 spiders.
BSA C15T #770838
04/12/19 11:23 am
04/12/19 11:23 am
australia
tiger_cub Offline OP
australia
Are these worth more than the standard C15? I have just been offered one missing engine internal parts for $600
1969 T100
1970 TR6C
1970 TR6R
Re: BSA C15T [Re: tiger_cub] #770847
04/12/19 12:56 pm
04/12/19 12:56 pm
In the UK yes, especially the early one in the Gooseneck frame as long as its genuine, the later one is in the competition frame also used with the B40 off road/B25 all/B44 all to 70, still worth more than a std C15 but not as much. Watch out for a C15T engine in a C15 Gooseneck frame without the brackets and C15T tinware trying to look all C15T.
Re: BSA C15T [Re: tiger_cub] #770962
04/13/19 11:30 pm
04/13/19 11:30 pm
The Northwoods... Michigan
Steve Erickson Offline
That is a hard question to answer, certainly for a non-Australian...
What is a C15 worth in Oz?
I'd say that, in the US anyway, they are two different markets, road compared to competition. Both very much a niche model, but almost apples/oranges. I think in the US that a $600 C15T needing internals would pretty much be a candidate strictly for competition, not at all sensible for making roadworthy and presentable for (limited) road use due to cost vs return. The T is much more rare, but not really reflected in "value".
Such a very practical question... all my logical responses would be the exact opposite of what I actually do. Unless you're enamored of the comp model, the roadapple Star is probably your better choice. I'd guess simply by your question that you aren't...
Re: BSA C15T [Re: tiger_cub] #770971
04/14/19 1:15 am
04/14/19 1:15 am
australia
australia
I had a look yesterday, seems OK, frame C15S 24XX, engine C15T 14XX, has a normal C15 oil tank though, still has front 20" wheel with original Trials Universals. He may have another one or two of them too.
1969 T100
1970 TR6C
1970 TR6R
Re: BSA C15T [Re: tiger_cub] #770985
04/14/19 6:26 am
04/14/19 6:26 am
australia
australia
I don't think there is much of a market for these bikes here in Aus, I was just thinking about building an off road fun bike, not really fully original. It will come with a spare engine so I will have all the parts and I will have the choice of about three part-dismantled bikes all up, some of which are also C15T by the looks of it.
1969 T100
1970 TR6C
1970 TR6R
Re: BSA C15T [Re: tiger_cub] #771000
04/14/19 12:13 pm
04/14/19 12:13 pm
They do look good restored.
But better used.
Re: BSA C15T [Re: tiger_cub] #771192
04/16/19 5:38 am
04/16/19 5:38 am
BSA_WM20 Offline
BSA_WM20  Offline
If you are thinking about making a dirt bike, then triple the warning about the gooseneck frame.
They are fine for Tirals which we don't do in OZ apart from a little in SA and slightly less in VIC.
If you try to get some air under the wheels, the bike will end up too long to fit in the trailer when you go home
Or with the front wheel hard up against the down tube if your off road skills are on par with mine.
Remember trials are all about going slow and maintaining balance.
I have always maintained one of the reasons for our high motorcyclist collision rates is kids scramble rather than trial.
Re: BSA C15T [Re: tiger_cub] #771259
04/16/19 11:34 pm
04/16/19 11:34 pm
australia
australia
I am aware that vintage trials is virtually defunct in Aus. In the 70s I did trials on a TR20 Cub back in UK, so the moment I saw the C15T frame I was thinking that some sort of brace was needed. It may not be possible with the standard tank though. I am only planning on using it on fairly easy terrain so I don't think the frame will be an issue, in Perth there are specific areas set aside for offroad riding. Apart from that, the spare engine is a side points model but if the C15T is anything like the Cub, the parts should mostly be able to fit in the existing cases, perhaps someone could let me know. That pic posted above looks really good! When I go through the parts I had better look out for that kickstart lever! I saw the sidestand was on the right on the one I looked at, but assumed someone had modified it
1969 T100
1970 TR6C
1970 TR6R
Re: BSA C15T [Re: tiger_cub] #771352
04/18/19 3:33 am
04/18/19 3:33 am
If it is to be an "off road fun bike", you might consider using the later sidepoints spare as your propulsion unit, much better in many respects... put your money and efforts into that engine, it would be an improvement and upgrade. Though the S frame has a weak steering head setup, it is the Scrambler frame of the era, not as strong as the later C comp frame, but still intended for off road use. Just be aware of the problem area.
Though an "adjustable" trail may be a nice advantage? Years ago I talked with an elderly English Trialer, who was very proud of his ability to set his angle with a "scaffold pole", apparently he had done it often. Doesn't sound advisable to me, but he seemed quite pleased with it...
Re: BSA C15T [Re: tiger_cub] #771369
04/18/19 11:08 am
04/18/19 11:08 am
UK Berks
AngloBike Online content
AngloBike  Online Content
UK Berks
Tiger cubs (as you're probably aware) had the swan necked frame and used braced tanks to hold the neck on.
Some tiger cub trials use an oil tank tube under the fuel tank as a brace although not sure if that set up would work in Oz?
The 3/5 ta used the same frame design and later introduced a brace under the tank as a bolt on, then later welded an extra tube in and changed the tank.
There may already be a part manufactured to brace a swan neck c15 frame ? Or it would be easy enough to make something?
Re: BSA C15T [Re: tiger_cub] #771371
04/18/19 11:23 am
04/18/19 11:23 am
It would be difficult to brace the neck using the stock tank... it has a shallow tunnel designed to snugly hug the top frame rail, no room on top or sides of the frame rail for bracing.
Back then BSA did offer an alloy tank option for these. It looked very much like a Victor tank, but it also had the shallow tunnel, so wouldn't help here. Even if you could find one. But... a later Victor tank (designed for the C frame) has a much deeper tunnel, and possibly would have enough clearance above the frame rail to allow a gusset to be fabbed? It would take a little fiddling, would end up looking essentially like the C15T with the optional alloy tank.
Re: BSA C15T [Re: Steve Erickson] #771524
Yesterday at 07:11 PM
Nova Scotia, Canada
koncretekid Offline
koncretekid  Offline
Nova Scotia, Canada
Victor tank sitting on a C15 frame. It looks as though a good gusset could be added without hitting the B44 tank.
Tom
Re: BSA C15T [Re: tiger_cub] #771573
16 hours ago
16 hours ago
Worth a thousand words, Tom.
