No Name Man
No Name Man
SE Ohio
SLK, E.Fox, 1hirider, Dan watt, Kevin Wils
10700 Registered Users
franko 136
NickL 49
896,392 mail-order LSR
Topics66,868
Posts670,756
Members10,700
43 registered members (AML), 297 guests, and 871 spiders.
Stock vs race a65 cam #770813
04/12/19 2:01 am
04/12/19 2:01 am
portland or
drunkenmonkz Offline OP
portland or
Hi, what would be the noticable difference between the srm race cam and the stock profile on a "stock" a65 thunderbolt. Advantages? Disadvantages?
Re: Stock vs race a65 cam [Re: drunkenmonkz] #770832
04/12/19 8:43 am
04/12/19 8:43 am
West Yorkshire
West Yorkshire
High revs, more torque, better acceleration. Its a really good cam and works well with small ports, I used mine with 1.125 radius tappets (had them ground, std is 1.25) you also want their race springs otherwise the standard ones will break.
Mine was fitted with a early lightning head with the small ports made smaller, and 928 carbs. It pulled in top gear from 1500rpm and just kept pulling.
Disadvantage is that if your looking for a more sedate bike then its not for you, I clocked the Lobe centres on mine and they were identical to the sifton 380 (from memory), a great cam if you want the bike to really go (or pull wheelies on stock gearing)
Re: Stock vs race a65 cam [Re: drunkenmonkz] #770840
04/12/19 11:52 am
04/12/19 11:52 am
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
Can't resist this one. The word 'race' should tell you something. You will need race springs which will accelerate wear in the valve train and this will mean frequent vale adjustments. Allan reground the lifters (around 200 bucks) which deceased the overlap. This would make it a bit less racey. A good move for a street bike. A standard T-Bolt head would limit the cam's ability to breath better at high rpm. So, some big bucks for not a whole bunch of poke.
Suggestion. Get springs from Ed V and follow instructions, then get out the degree wheel and make sure the cam is set properly and all lobes are within spec. You might also ask him about a big bore kit. Just an opinion of course. Cheers, PRT
Re: Stock vs race a65 cam [Re: drunkenmonkz] #771203
04/16/19 12:35 pm
04/16/19 12:35 pm
Mark Parker Offline
Mark Parker  Offline
Me either. I don't know if all Thunderbolts had the Spitfire profile cam, but latter ones did, BSA advertised this excellent cam as a 'race cam' and BSA had great cam designers. I read that the F1 Repco Brabhams that dominated in the '60s used BSA cam profiles.
A more racier cam will not improve the Thunderbolt much, if at all. The cylinder head makes the biggest difference to performance. All the racier cam is trying to do, is to get more air flowing into the engine, it manipulates the dynamics of the air as it travels through. It can bias the motor to produce it's power at higher rpm, ie if the inlet closes later, or if it has higher valve lift, a high speed inlet charge will keep filling the cylinder as the piston rises, more air to burn more power, to achieve the speed in the charge though it requires more rpm or more displacement. And as the head or more precisely the inlet ports are the limiting factor, you are addressing a cam that isn't any where near the limiting factor. The Spitfire cam will make good power to 9,000rpm if the head breaths well. And you need a well modified twin carb head for that.
Re: Stock vs race a65 cam [Re: drunkenmonkz] #771253
04/16/19 10:31 pm
04/16/19 10:31 pm
Irish Swede Offline
Irish Swede  Offline
Don't put a "race" anything into an A65 unless you plan to buy a better quality oil pump and connecting rods, and change the crankshaft oiling system to a quill-type end feed, like Triumphs use.
Re: Stock vs race a65 cam [Re: Mark Parker] #771291
04/17/19 11:52 am
04/17/19 11:52 am
West Yorkshire
West Yorkshire
Some one better tell Pushrod Tom about the crank.... I beleive he is still using a bush on the Hornet racer without issue, Isn't that right Tom?
Why do you need a better oil pump? it will output oil relative to the revs of the engine and most of the time at revs it will be blowing off oil pressure - not doubting though that its beneficial for any engine, same goes for the con rods, there is less dynamic pressure on the rods/pistons/cranks when thrashing a bike than when someones lugging a motor then opens the throttle without changing down.
From 66 I think all single carb 650's had the 473 cam. From using that cam (and liking it) it works well with small ports as it seems to widen the available torque range, granted im using a dual carb head instead of a single carb but at those rev ranges I doubt it would be any different for 1 or 2 carbs.
Keeping some changing in your pocket though, adding some keyways to your cam pinion and retarding the 473 cam a few degrees gives it a different charicteristic and more spritely, retard it too far and it'll give you a flat spot in the middle of it eek
Re: Stock vs race a65 cam [Re: Irish Swede] #771323
04/17/19 8:29 pm
04/17/19 8:29 pm
portland or
portland or
Srm oil pump, map connecting rods, kibblewhite valves and springs and an ard magneto. Havent changed to quill feed though. Trying to find someone local that can do that for me..
Re: Stock vs race a65 cam [Re: drunkenmonkz] #771326
04/17/19 8:52 pm
04/17/19 8:52 pm
Irish Swede Offline
Irish Swede  Offline
Then I guess you are ready for that "race cam."
Just don't count on beating any 500cc bike built after 1980.
Re: Stock vs race a65 cam [Re: drunkenmonkz] #771339
04/17/19 11:38 pm
04/17/19 11:38 pm
gavin eisler Offline
For cheap instant HP skim the head, use Castrol R, fit the the race cam , fit megas and a short bellmouth
Fit a strong spark, Your neighbours will hate you , but it will smell great when you wear it out and fit a quill feed /
