SReppel
SReppel
Abbeville, Louisiana
75 registered members (68 royalstar tony), 458 guests, and 737 spiders.
Simon J, Hwallman, Fumi, brennan devine, sivaraj
10615 Registered Users
franko 118
koan58 97
Mori55 82
reverb 65
NickL 58
832,892 mail-order LSR
Topics67,864
Posts672,276
Members10,615
Why waste a spark? #768139
03/14/19 11:00 pm
03/14/19 11:00 pm
MA
Nick H Online content OP
Nick H  Online Content OP
MA
While setting the points on my Triumph a question occurred to me. Why does the points cam have two lobes creating a "wasted spark"?
I have a feeling the answer is going to lead to a forehead slap for me.
1966 BSA Lightning
1967 Triumph "Choppa"
Re: Why waste a spark? [Re: Nick H] #768141
03/14/19 11:14 pm
03/14/19 11:14 pm
Mark Z Offline
Mark Z  Offline
None of the dwell cams I've looked at on BSA or Triumph twins have two lobes.
The "lobe" as it were is the high spot after the low flat spot where the coil "charges". After the points open, they may or may not stay open the rest of the way around the cam, but this will not produce a spark until they close once again at that "flat spot" and then open.
Re: Why waste a spark? [Re: Mark Z] #768144
03/14/19 11:27 pm
03/14/19 11:27 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
I think
What looks like the second lobe
is really just the end of the first Lobes open time .
Before the cam ramps down and the points close
To again
Dwell the coil .
For reference, the Google says :
The 4ca has 86 degrees of dwell ( closed degrees )
The 6ca has 160 degrees of dwell .
Re: Why waste a spark? [Re: Nick H] #768165
03/15/19 6:32 am
03/15/19 6:32 am
Points systems on Triumphs and practically all other British bikes were not wasted spark.
Re: Why waste a spark? [Re: quinten] #768208
03/15/19 9:36 pm
03/15/19 9:36 pm
MA
MA
Originally Posted by quinten
I think
To again
Dwell the coil .
Thanks, all. I see it now. That reference would be crankshaft degrees, yes?
1966 BSA Lightning
Re: Why waste a spark? [Re: Nick H] #768224
03/15/19 11:20 pm
03/15/19 11:20 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
, 160° is points cam degrees
Its a long dwell .
I dont have a points cam handy for reference .
Only this great pic . [Linked Image]
Notice how the timing side points are charging
and the Drive side points are past firing ...but still open
dwell refers to the point cam itself .,not the crank .
And the number of degrees the points are closed and charging the coils.
This speaks to why the cam looks like it has two firing lobes ... but it doesn't .
It's really a long 160° degrees of flattish arc , dwelling the coils , a high spot that brakes contact ... and a long slow ramp down .
The second lobe-like area , opposite the firing mark ... is the transition
where the points ( finish there open time ) and go back into dwell .
Re: Why waste a spark? [Re: Nick H] #768278
03/16/19 5:54 pm
03/16/19 5:54 pm
MA
MA
Thank you. That makes it crystal clear.
1966 BSA Lightning
Re: Why waste a spark? [Re: Nick H] #768382
03/17/19 11:14 pm
03/17/19 11:14 pm
MA
MA
Now that we've cleared that up, I'd like to take this another, related direction.
My frame has a nice built in mount for this type of coil:
Can I use a dual coil like this with points? Assuming proper impedence.
I've searched several posts here and elsewhere and still am not convinced. Usually the poster replies confuse the question (or I'm confused) or take it on a tangent but some claim to have done it.
The only way I can see it working is if you somehow isolated the points plate from ground and then wired the points in series - and then you would have a wasted spark.
One thing I have not been able to find is a wiring diagram of a setup that works.
Or how about a coil like this?
Any better?
Not much information available about these but I believe they are two coils in one package. Might work.
1966 BSA Lightning
