GaryK227
GaryK227
Randolph, NJ
Psychorider, Shedengineering, Shayne Brown, Snow's Cycles, Scottboy
10858 Registered Users
franko 173
reverb 65
DavidP 56
NickL 56
1,005,598 mail-order LSR
Topics67,735
Posts679,872
Members10,858
49 registered members (Al Eckstadt), 332 guests, and 717 spiders.
Head steadies - a necessity? #767965 03/13/19 1:43 am
Al Eckstadt Online Content OP
OP Online Content
I'm trying to get back to working on Project 39-1/2 (see Brit Bike Specials) after about 6 months of being away from it. Now the weather is starting to lighten up and working in the garage will be possible. My next step is to make a bracket for head steadies off the rocker boxes - which are 1966 style boxes. So here are some questions.
I seem to remember reading that head steadies are important - so is leaving them off not an option?
Can I steady just one rocker box? Or do I need both rocker boxes held as on a stock 60's 650?
It's not going to be difficult, once I decide what I need. Maybe there are other questions I didn't ask that need to be considered.
Al
Al Eckstadt
Re: Head steadies - a necessity? [Re: Al Eckstadt] #767975 03/13/19 3:40 am
HawaiianTiger Offline
My understanding is that your exhaust ports will suffer without head steadies, and possibly the entire exhaust system. I have seen cylinders break right above the flange on bikes without head steadies.
There may be some benefit with regards to vibration and handling as well.
Re: Head steadies - a necessity? [Re: Al Eckstadt] #767993 03/13/19 10:43 am
Mike Baker Offline
You're putting the motor into a Benelli frame? Is there some place you've got in mind for a top steady? If so, I agree, it shouldn't be difficult to make one.
My take- use a head steady. I had an OIF motor in a dry frame without one and it was a buzzy ride. Finally made a steady and it calmed it down significantly. I'd connect both rocker boxes to some place on the frame. A piece of 3/32 steel would work fine - test fit, heat with a MAPP torch, bend, tweak, drill, tweak again, rinse, repeat. If it fits well without stressing anything there's little chance of fatigue failure.
Re: Head steadies - a necessity? [Re: Al Eckstadt] #767994 03/13/19 11:07 am
OP Online Content
Thanks Mike. Yes the Benelli/Mojave frame has a couple tubes across the top and a plate could be tucked in between them with a 90 degree bracket where I could attach a set of original Triumph steadies. But I might want to try a different style of mounting so it doesn't look so much like a stock Triumph.
Al
Al Eckstadt
Re: Head steadies - a necessity? [Re: Al Eckstadt] #767996 03/13/19 11:33 am
pushrod tom Offline
To bolster Mikes comments, head steady is very important for many reasons including prevention of frame fractures. PRT
Re: Head steadies - a necessity? [Re: Al Eckstadt] #767997 03/13/19 11:44 am
Hillbilly bike Offline
Head to frame mounts are bike dependent ,some have them, some don't...Eliminating the mount when required can cause issues mentioned above...Using a mount when none is required may create a problem... On a custom build using a Triumph 650, probably a good idea..
79 T140D, 96 900M Ducati ,2001 Sportster....On a bike you can out run the demons..
Re: Head steadies - a necessity? [Re: Al Eckstadt] #768033 03/13/19 9:03 pm
OP Online Content
Thanks prt and hb.
Got the boxes of tools and junk put away that were blocking my bike worktable since November when I left my last job. Next task - clean off the workbench.
Al Eckstadt
Re: Head steadies - a necessity? [Re: Al Eckstadt] #768046 03/13/19 11:15 pm
TrophyGuy Offline
This old engineer's guess is that head steadies are as much to protect the frame as the engine and exhaust. Tying the entire engine-frame assembly together makes for a much stiffer structure to resist bending loads. Almost all modern motorcycles work this way, using the engine as a stressed, load carrying member. My guess is that loads from the front suspension through the steering neck are pretty significant. Without head steadies in place bending loads from front suspension would cause larger deflections in the top and bottom frame members and larger bending moments at fixed points, especially the steering head and its notoriously crack prone welds. Whatever the case, Triumph/BSA found the weak points and fixes the hard way. They're pretty crude pieces of heavy wall pipe with flattened ends for attachment. Being painted black and tucked under the tank they're hardly visible.
