I have a B34 with alternator and a pointless ignition system [transistor]. The rotor is set at the retarded point so I need to know where to set the ignition up in the retarded point. How many degrees is there between the retarded point and fully advanced or inches or mm down the bore from TDC. Hope this make sense to some one. The Distributor is a Lucas model no40599A
