HawaiianTiger
HawaiianTiger
Greg Alexander, BBQ, Rick K, Fraz, Dave Tomz
10647 Registered Users
koan58 99
reverb 71
L.A.B. 56
854,589 mail-order LSR
Topics68,063
Posts673,870
Members10,647
Most Online5,714
Apr 16th, 2019
70 registered members (AML), 466 guests, and 233 spiders.
A65 alternator bracket mounting #765174
02/12/19 3:09 am
02/12/19 3:09 am
Chelmsford MA
MarcB Offline OP
MarcB  Offline OP
Chelmsford MA
I'm looking to install a 67-style alternator bracket to a case that has the multi-stepped studs.
Replace this:
With this:
And this:
Is it do-able? It seems that the 67 cases have a bit more surface for the bracket to sit on, but otherwise the parts fit.
Also, why is the stud tapped for two different sizes at one end? Does the bracket take a nut, then the stator sit against that? Why not have the stator nut also hold the bracket in place?
Does anyone have a good picture of this setup?
Thanks in advance
Re: A65 alternator bracket mounting [Re: MarcB] #765263
02/13/19 2:39 am
02/13/19 2:39 am
portland or
drunkenmonkz Online content
drunkenmonkz  Online Content
portland or
I was contemplating doing the same thing with my 64 im building. Following to see what people say.
Re: A65 alternator bracket mounting [Re: MarcB] #765291
02/13/19 3:25 pm
02/13/19 3:25 pm
Chelmsford MA
MarcB Offline OP
MarcB  Offline OP
Chelmsford MA
No responses yet, but I can't imagine it would do anything but help things out. It seems that the three self-standing studs have more potential for flex, that could cause contact between the rotor and stator. But that's just a theory and I might be over-engineering a solution to a non-existent problem, apart from protecting the cases from a loose chain.
Re: A65 alternator bracket mounting [Re: MarcB] #765303
02/13/19 5:07 pm
02/13/19 5:07 pm
Rich B Online happy
Rich B  Online Happy
Without looking at a set of cases that used the alternator support, memory says the cases were machined for the support to sit into the case. A standard 3 stud case wouldn't be machined.
I have run later cases with the support and early cases without. Do a good job at assembly making sure the gap on the alternator is consistent all the way around the stud arrangement works. The cup that was added to support the alternator or the cases with the alternator support cast in just reduce effort to install the stator since you are somewhat fixed in there the stator ends up.
Re: A65 alternator bracket mounting [Re: Rich B] #765313
02/13/19 7:05 pm
02/13/19 7:05 pm
Chelmsford MA
MarcB Offline OP
MarcB  Offline OP
Chelmsford MA
To install the bracket on the studs, is there a nut between the stator and the bracket, on the bigger portion of the stud? Hard to tell from the parts manual.
Re: A65 alternator bracket mounting [Re: MarcB] #765357
02/14/19 12:48 pm
02/14/19 12:48 pm
Chelmsford MA
MarcB Offline OP
MarcB  Offline OP
Chelmsford MA
After watching this video from Lowbrow Customs about putting the primary together on a triumph, I actually feel a bit better about just running the multi-stepped studs.
https://youtu.be/AwiEHtP0LcI
As long as I keep the parts in good working order, I guess it's not as big of a concern as I originally thought.
